[Geomoose-users] List issue
Brent Fraser bfraser at geoanalytic.com
Fri Feb 19 11:06:35 EST 2010
My problem is that I'm not getting all the email posted to the list.  It may be
my mail server's problem, but maybe not ...
Brent Fraser
Matthew D. Syvertson wrote:
> Is anyone else having a problem where you get TWO of every email sent to
> the list.  This just started, so I need to know if its just me…
> /Matt Syvertson/
> GIS Coordinator
> Richland County, ND
> msyvertson at co.richland.nd.us <mailto:msyvertson at co.richland.nd.us>
> *From:* Len Kne [mailto:lkne at houstoneng.com]
> *Sent:* Thursday, February 18, 2010 9:23 AM
> *To:* 'FRANZ OKYERE'; geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Printing not working on my remote host
> (GM 2.0)
> Hi Franz
> You could try setting the server_name=localhost, this would be the same
> as giving it the internal IP address.  This probably is not going to fix
> the printing because:
> Web hosting services generally host multiple websites on a single IP
> address.  The web server looks at the header that is sent with the
> request to determine which virtual website to send it to.  When opening
> a page by IP address, the header contains the IP address as the server
> name, and thus goes to the default website.
> On our hosting server, we get around this by setting up a host entry
> which points to the internal IP address.  For example:
> internal-gm.houstoneng.com  192.168.1.1
> Then in settings.ini, server_name=internal-gm.houstoneng.com, which
> points the GeoMOOSE services to the correct internal IP address.  If
> your service provider could add this entry, that will hopefully allow
> printing.  Another diagnostic test is to make sure that WMS layers are
> printing as they should not be affected by this setting.
> Len
> *From:* FRANZ OKYERE [mailto:franzzoa at hotmail.com]
> *Sent:* Thursday, February 18, 2010 12:49 AM
> *To:* Len Kne; geomoose-users at lists.sourceforge.net
> *Subject:* RE: [Geomoose-users] Printing not working on my remote host
> (GM 2.0)
> I have tried you suggestion but I think you suspicion is rather
> true. The website is hosted on a shared server so I guess I will not be
> able to print! Any other suggestions- can I ask the host what the real
> IP address is instead of  the disguised ip infront of the firewall?
> Thanks
> Franz
> From: lkne at houstoneng.com
> To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> Date: Tue, 16 Feb 2010 09:11:22 -0600
> Subject: RE: [Geomoose-users] Printing not working on my remote host (GM
> 2.0)
> Try updating print.php and print_util.php from trunk or the GeoMOOSE 2.2
> download.  Then in settings.ini add the line:
> server_name=www.myghanasearch.com
> The server_name needs to be the FQN that the server will see itself as.
> That is, if from the server you ping www.myghanasearch.com
> <http://www.myghanasearch.com/>, it should resolve to the IP address of
> the server itself (not the IP address on the outside of the firewall).
> This gets a little trickier if your site is on a hosted server behind a
> firewall with multiple sites on the server.  Hopefully this is not the
> case and it will work with the steps above.
> Len
> *Sent:* Tuesday, February 16, 2010 8:40 AM
> *To:* geomoose-users at lists.sourceforge.net
> *Subject:* [Geomoose-users] Printing not working on my remote host (GM 2.0)
> Hi All,
> Please find attached the print.php, download.php, print_util.php and my
> settings.ini to see if you can figure out why I am able to print locally
> but  not able to print from the the website. I don't get any errors when
> I run getmapbook.php or run the
> www.myghanasearch.com/search/php/download.php.
> Thanks.
> Franz Okyere
> GIS Specialist
> Do you want a Hotmail account? Sign-up now - Free
> <http://clk.atdmt.com/UKM/go/197222280/direct/01/>
> We want to hear all your funny, exciting and crazy Hotmail stories. Tell
> us now <http://clk.atdmt.com/UKM/go/195013117/direct/01/>
> Download Intel&reg; Parallel Studio Eval
> Try the new software tools for yourself. Speed compiling, find bugs
> proactively, and fine-tune applications for parallel performance.
> See why Intel Parallel Studio got high marks during beta.
> http://p.sf.net/sfu/intel-sw-dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
