[Geomoose-users] List issue
Matthew D. Syvertson msyvertson at co.richland.nd.us
Fri Feb 19 11:56:09 EST 2010
Solved my problem with the list.  The problem was a duplicate rule in my "Rules wizard" in outlook which moved the item to a folder twice...
Matt Syvertson
GIS Coordinator
Richland County, ND
-----Original Message-----
Sent: Friday, February 19, 2010 10:15 AM
To: Brent Fraser; Matthew D. Syvertson
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] List issue
I'm having the same problems....  we may need to move servers.  Hopefully, we can get new stuff through OSGeo or something.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Matthew D. Syvertson <msyvertson at co.richland.nd.us>
> Sent: Fri, February 19, 2010 10:06:35 AM
> My problem is that I'm not getting all the email posted to the list.  It may be
> my mail server's problem, but maybe not ...
> Brent Fraser
> Matthew D. Syvertson wrote:
> > Is anyone else having a problem where you get TWO of every email sent to
> > the list.  This just started, so I need to know if its just me…
> > /Matt Syvertson/
> > GIS Coordinator
> > Richland County, ND
> > *From:* Len Kne [mailto:lkne at houstoneng.com]
> > *Sent:* Thursday, February 18, 2010 9:23 AM
> > *To:* 'FRANZ OKYERE'; geomoose-users at lists.sourceforge.net
> > *Subject:* Re: [Geomoose-users] Printing not working on my remote host
> > (GM 2.0)
> > Hi Franz
> > You could try setting the server_name=localhost, this would be the same
> > as giving it the internal IP address.  This probably is not going to fix
> > the printing because:
> > Web hosting services generally host multiple websites on a single IP
> > address.  The web server looks at the header that is sent with the
> > request to determine which virtual website to send it to.  When opening
> > a page by IP address, the header contains the IP address as the server
> > name, and thus goes to the default website.
> > On our hosting server, we get around this by setting up a host entry
> > which points to the internal IP address.  For example:
> > internal-gm.houstoneng.com  192.168.1.1
> > Then in settings.ini, server_name=internal-gm.houstoneng.com, which
> > points the GeoMOOSE services to the correct internal IP address.  If
> > your service provider could add this entry, that will hopefully allow
> > printing.  Another diagnostic test is to make sure that WMS layers are
> > printing as they should not be affected by this setting.
> > Len
> > *From:* FRANZ OKYERE [mailto:franzzoa at hotmail.com]
> > *Sent:* Thursday, February 18, 2010 12:49 AM
> > *To:* Len Kne; geomoose-users at lists.sourceforge.net
> > *Subject:* RE: [Geomoose-users] Printing not working on my remote host
> > (GM 2.0)
> > I have tried you suggestion but I think you suspicion is rather
> > true. The website is hosted on a shared server so I guess I will not be
> > able to print! Any other suggestions- can I ask the host what the real
> > IP address is instead of  the disguised ip infront of the firewall?
> > Thanks
> > Franz
> > From: lkne at houstoneng.com
> > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> > Date: Tue, 16 Feb 2010 09:11:22 -0600
> > Subject: RE: [Geomoose-users] Printing not working on my remote host (GM
> > 2.0)
> > Try updating print.php and print_util.php from trunk or the GeoMOOSE 2.2
> > download.  Then in settings.ini add the line:
> > server_name=www.myghanasearch.com
> > The server_name needs to be the FQN that the server will see itself as.
> > That is, if from the server you ping www.myghanasearch.com
> > , it should resolve to the IP address of
> > the server itself (not the IP address on the outside of the firewall).
> > This gets a little trickier if your site is on a hosted server behind a
> > firewall with multiple sites on the server.  Hopefully this is not the
> > case and it will work with the steps above.
> > Len
> > *Sent:* Tuesday, February 16, 2010 8:40 AM
> > *To:* geomoose-users at lists.sourceforge.net
> > *Subject:* [Geomoose-users] Printing not working on my remote host (GM 2.0)
> > Hi All,
> > Please find attached the print.php, download.php, print_util.php and my
> > settings.ini to see if you can figure out why I am able to print locally
> > but  not able to print from the the website. I don't get any errors when
> > I run getmapbook.php or run the
> > www.myghanasearch.com/search/php/download.php.
> > Thanks.
> > Franz Okyere
> > GIS Specialist
> > Do you want a Hotmail account? Sign-up now - Free
> > We want to hear all your funny, exciting and crazy Hotmail stories. Tell
> > us now
> > Download Intel® Parallel Studio Eval
> > Try the new software tools for yourself. Speed compiling, find bugs
> > proactively, and fine-tune applications for parallel performance.
> > See why Intel Parallel Studio got high marks during beta.
> > http://p.sf.net/sfu/intel-sw-dev
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
