[Geomoose-users] UTM to Google maps Mercator not transformable?
Brent Fraser bfraser at geoanalytic.com
Sat Feb 20 20:46:29 EST 2010
Franz
  GDAL should have no problem with those two coordinate systems.  It may
be a problem with your gdal configuration, or the command syntax you are
using.  Can you cut-and-paste the commandline and the error message into
an email message?
Brent Fraser
> Hello all,
> I know its weekend, but I can't chill if I don't get this straight. I need
> to transform my shapefiles from UTM zone 30N to Google's Mercator (EPSG
> 900913 default in GM). I used gdal to do the transformation and got the
> error that the two projections may not be transformable. Is this true?
> Does anyone know the most practical way to get my shapefiles in googles
> projection?
> Thanks a million.
> Franz Okyere
> GIS Specialist.
> _________________________________________________________________
> Tell us your greatest, weirdest and funniest Hotmail stories
> http://clk.atdmt.com/UKM/go/195013117/direct/01/------------------------------------------------------------------------------
> Download Intel® Parallel Studio Eval
> Try the new software tools for yourself. Speed compiling, find bugs
> proactively, and fine-tune applications for parallel performance.
> See why Intel Parallel Studio got high marks during beta.
> http://p.sf.net/sfu/intel-sw-dev_______________________________________________
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
