[Geomoose-users] UTM to Google maps Mercator not transformable?
FRANZ OKYERE franzzoa at hotmail.com
Sun Feb 21 09:33:12 EST 2010
Thanks Brent,
You were right. I forgot to run setenv.bat, I have to do always otherwise the tools will not work. So I processed the shapefile and I have a resulting shapefile, hopefully in Google's Mercator projection like so:
PROJCS["Google Maps Global Mercator",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator_2SP"],PARAMETER["standard_parallel_1",0],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
The  result is rather trimmed but I will firstly check if it overlays on the google layer.
Cheers
Franz
> Date: Sat, 20 Feb 2010 18:46:29 -0700
> Subject: Re: [Geomoose-users] UTM to Google maps Mercator not transformable?
> From: bfraser at geoanalytic.com
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Franz
> GDAL should have no problem with those two coordinate systems. It may
> be a problem with your gdal configuration, or the command syntax you are
> using. Can you cut-and-paste the commandline and the error message into
> an email message?
> Brent Fraser
> > Hello all,
> > I know its weekend, but I can't chill if I don't get this straight. I need
> > to transform my shapefiles from UTM zone 30N to Google's Mercator (EPSG
> > 900913 default in GM). I used gdal to do the transformation and got the
> > error that the two projections may not be transformable. Is this true?
> > Does anyone know the most practical way to get my shapefiles in googles
> > projection?
> > Thanks a million.
> > Franz Okyere
> > GIS Specialist.
> > _________________________________________________________________
> > Tell us your greatest, weirdest and funniest Hotmail stories
> > http://clk.atdmt.com/UKM/go/195013117/direct/01/------------------------------------------------------------------------------
> > Download Intel® Parallel Studio Eval
> > Try the new software tools for yourself. Speed compiling, find bugs
> > proactively, and fine-tune applications for parallel performance.
> > See why Intel Parallel Studio got high marks during beta.
> > http://p.sf.net/sfu/intel-sw-dev_______________________________________________
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
We want to hear all your funny, exciting and crazy Hotmail stories. Tell us now
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100221/74d6b3ca/attachment.html
More information about the Geomoose-users mailing list
