[Geomoose-users] popup service problem
FRANZ OKYERE franzzoa at hotmail.com
Mon Feb 22 00:25:56 EST 2010
 Hi Arapostathis,
If you intend to use google mercator projection then you need to convert the WGS 84 projection to google's mercator. I did that and it worked for me. Simply use the gdal or create you own projection under tools in ms4w, i.e if that is the software you are using. After that get the extents like you always do and use them, from qgis gis software, for example.
I guess the popups are showing up elsewhere because you are on two different projection systems.
Cheers.
Franz Okyere
Date: Mon, 22 Feb 2010 01:01:13 +0200
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] popup service problem
Hello,
   I have a problem using the popup service
When the service is enabled and I click a feature the popup opens in other place on the map (down left of the map window).
   I don't know if this happens because of my map file:
The map object has the google mercator projection and the layer has WGS 84 projection.
Could anyone help me?
Thanks a lot
E. Arapostathis
_________________________________________________________________
Tell us your greatest, weirdest and funniest Hotmail stories
http://clk.atdmt.com/UKM/go/195013117/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100222/473ab2e9/attachment.html
More information about the Geomoose-users mailing list
