[Geomoose-users] Need label opacity independent of vector layer
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Tue Jul 13 14:59:54 EDT 2010
I see there are three ways to do this, but I can only set individual
opacities with two entries in the mapbook unless they can be set in the
mapfile.  Jacob's Invisible = "true" in your .xml file, Bob and Brent
with no name in the mapbook and the mapfile.
jim
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, July 13, 2010 1:54 PM
To: Jim Dahl
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Need label opacity independent of vector
layer
I don't think so...
One entry in the mapbook (so only one GM "layer" with a checkbox):
<map title="Parcels" default="true">
     <file>./Parcels.map</file>
</map
but two LAYERs in the Parcels.map file, one with no NAME entry in the
CLASS so
its no included in the mapserver-generated legend.
Brent
Jim Dahl wrote:
>>From the responses, I see that it cannot be done without hacking or
>>GM2.
> Brent, your suggestion with the two opacities still will show two
> layers in the TOC.
> Sent: Tuesday, July 13, 2010 1:13 PM
> To: Jim Dahl
> layer
> Jim,
>    You could use mapserver's OPACITY setting in the map file.  Have
> two layers in the map file (with the same name, or set STATUS DEFAULT
> so they're both
> always on), one for the geometry (OPACITY 20) and one for the labels
> (OPACITY
> 100).  Of course GM's fade/unfade controls would have no knowledge of
> this, so
> that may be confusing to the end users...
> Brent
> Dan Little wrote:
>> This is/was a limitation in GeoMOOSE 1.X that we addressed in 2.X.
>> There is nothing in the standard code base that supports what you'd
>> like to do.  Brian/Len/Brent may have a hack they did to make it
>> work.
>>     *From:* Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>>     *To:* geomoose-users at lists.sourceforge.net
>>     *Sent:* Tue, July 13, 2010 10:47:56 AM
>>     *Subject:* [Geomoose-users] Need label opacity independent of
> vector
>>     layer
>>     I have a polygon layer in GM 1.x that has opacity of 20 but I
want
>>     opacity of labels 100.  I can create this effect with separating
>>     into two layers but I do not want to see the anno layer in the
>>     layers tab.  Can anyone guide me as to the solution.  If anno is
>>     separate layer, can the mapbook code be  - visibility="false" ?
>>     Jim Dahl, GISP
>>     GIS Coordinator
>>     Douglas County Public Works
>>     526 Willow Dr
>>     PO Box 398
>>     Alexandria MN 56308
>>     V 320-762-2933
>>        320-762-2999
>>     F 320-762-2998
>> This SF.net email is sponsored by Sprint
>> What will you do first with EVO, the first 4G phone?
>> Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
>> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
