[Geomoose-users] question on invisible layers
Brian Fischer bfischer at houstoneng.com
Mon Jul 26 15:19:15 EDT 2010
Jim this will only work if your using GM 2.2 and I know you are using 1.6.
I don't think you can do this with 1.6 without some customization to the code.  I think what you might be thinking of is the map report.  That did allow you to pass in the layers you wanted displayed on it.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Monday, July 26, 2010 2:05 PM
To: Jim Dahl
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] question on invisible layers
Jim,
  I think if you set
    STATUS OFF
in your map file it should work with your current config of using two map-source entries in the mapbook pointing to the same map file.
Brent
Jim Dahl wrote:
> Yes I want to get a return on the invisible layers, but do not them
> printed unless the visible ones are on.  Apparently there is no way to
> control which TURNED ON layers are printed.  I thought there was a
> setting whether to include on print.  I can not find it though.
> Some one must know what I am referring to.
> jim
> Sent: Monday, July 26, 2010 11:20 AM
> To: Jim Dahl
> Jim,
>    You shouldn't need to have two layers.  Unless you want GeoMoose to
> return the Identify information even if the layer is turned off (i.e
> not visible on the map)?
> Best Regards,
> Brent Fraser
> Jim Dahl wrote:
>> Hi,
>> I am putting in layers twice.  The first is so they can turn on to
>> look at.  The second one is so they are always turned and to make
>> them identifiable.  This seems to work OK, let me know if you are
> aware
>> of a potential problem. However, my problem is this - when you print
> the
>> PDF shows these layers and they cover up other objects.  I know there
> is
>> a file to set what gets printed but forget where it is.  Can someone
>> give me a suggestion?  thanks,
>> <group title="Postal Boundaries" expand="false" tip="Click to expand
>> and turn on/off selection of Layers">
>> <map title="Zip Codes" opacity="50" default="false" legend="true"
>> reference="false" tip="Postal Boundaries">
>> <file>/ms4w/apps/GeoMOOSE/douglas/maps_douglas/zip/postal.map</file>
>> </map>
>> <map title="Zip Codes identify" invisible="true" opacity="00"
>> default="true" legend="true" reference="false" tip="Postal
> Boundaries">
>> </map>
>> </group>
>> Jim Dahl, GISP
>> GIS Coordinator
>> Douglas County Public Works
>> 526 Willow Dr
>> PO Box 398
>> Alexandria MN 56308
>> V 320-762-2933
>>    320-762-2999
>> F 320-762-2998
>> The Palm PDK Hot Apps Program offers developers who use the Plug-In
>> Development Kit to bring their C/C++ apps to Palm for a share of $1
>> Million in cash or HP Products. Visit us here for more details:
>> http://ad.doubleclick.net/clk;226879339;13503038;l?
>> http://clk.atdmt.com/CRS/go/247765532/direct/01/
>> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
The Palm PDK Hot Apps Program offers developers who use the Plug-In Development Kit to bring their C/C++ apps to Palm for a share of $1 Million in cash or HP Products. Visit us here for more details:
More information about the Geomoose-users mailing list
