[Geomoose-users] Need help to link to image in php file
Bob Basques Bob.Basques at ci.stpaul.mn.us
Fri Jul 30 16:12:55 EDT 2010
Jim,
We did something similar here at the City, but used custom popups and an imagemap.  This is on version 0.99 of geomoose.  It's still going too and used regularly, see:  http://gis.ci.stpaul.mn.us/gis/gismo_public/html/  Zoom into a one or two block area until you can turn on the Address layer, which is controlled via a IMAGEMAP, then try activating the layer via the Visible layers tab, any of the layers in the visible layers tab with a blue background can be made active in the map (imagemap activation) by selecting their corresponding radio button in the Visible layers tab.
While I'm sure this is what you are looking for, it was a completely custom implementation with regard to the popups (which handle stacked points just fine BTW), this is something that never made it into later versions of GeoMoose, (I don't completely know why), and I'm afraid it's likely going to take some funding resources to (re)implement in the newer versions.  I do know that the OL integration required some rethinking of things in this regard related to popups (OL version vs non-OL versions)
I guess I'm not really helping with any of this other than to caution that the work was custom and not for the faint of heart.
bobb
>>> "Jim Dahl" <jim.dahl at mail.co.douglas.mn.us> wrote:
I believe it is! However, I am using GM 1.6.  I am not having luck trying to edit the php file.  I have up to 30 or more images per section and when I tried to stack 30 shape file points on top of each other the identify did not work.  What I want is to drive the image name by a field in the database, which is what this example must be doing.
jim
-----Original Message-----
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Friday, July 30, 2010 2:28 PM
To: geomoose-users at lists.sourceforge.net; Jim Dahl
Subject: Re: [Geomoose-users] Need help to link to image in php file
Jim,
Is this the kind of thing you are looking for?
  https://www.sharedgeo.org/Plone/viewer-docs/FindPDFMapsPoint.gif/image_view_fullscreen
  https://www.sharedgeo.org/Plone/viewer-docs/FindPDFMapsPolygon.gif/view
and the real interface:
  https://www.sharedgeo.org/datasets/RRV/html/current/geomoose.html
There was some discussion about putting this out a package for people to host themselves.  It's all linux though on the server side if that matters.
bobb
Hi, I have a section shape file that I have looking at an Access data base where there is a link to more than one image file per section.  So when you identify the section, up pops window in IE where I want to identify the record and click on it to view the image.  I would like to know if anyone cares to help me.
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
526 Willow Dr
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-762-2999
F 320-762-2998
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100730/b9fee78f/attachment.html
More information about the Geomoose-users mailing list
