[Geomoose-users] GeoMoose on Ubuntu 10.4 / FGS 9.5
Wes Cleland wcleland at vanburencity.org
Tue Jun 1 11:40:38 EDT 2010
Mark,
I have not been able to get the features to work yet. I can make a pdf
when I attempt to print (though it gives me errors before it builds the
pdf), but cannot generate a feature report. I have not attempted the
shapefile feature as of yet. I wanted to make the system stable before I
added extra features. When you re-installed GM did you configure it any
different? Just trying to get a good idea of how others are
troubleshooting in case I run into the same thing. I am using the newest
version of FGS9.5 that is available on MapTools.org, I believe it is the
version with 5.6.3. Yourself?
Wesley T. Cleland, GISP, CFM
GIS Coordinator
City of Van Buren, Arkansas
479-471-5025
"One ought never to turn one's back on a threatened danger and try to
run away from it. If you do that, you will double the danger. But if you
meet it promptly and without flinching, you will reduce the danger by
half. Never run away from anything. Never!"
 Winston Churhill
Sent: Tuesday, June 01, 2010 10:32 AM
To: Wes Cleland
Subject: GeoMoose on Ubuntu 10.4 / FGS 9.5
Wes,
I was able to make some ground on my Geomoose installation.  I
reinstalled FGS and now I can use the GeoMoose site, however some
features do not work.  I cannot make PDF maps, nor can I use any code
that creates shapefiles (such as buffering)
Were you able to get those functions working?  If so how?
Also did you use FGS 9.5 version  5.6.3,  5.4.2 or another?
Thank You
Mark Volz
GIS Specialist
Lyon County, MN
507-532-8218
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100601/059c63c4/attachment.html
More information about the Geomoose-users mailing list
