[Geomoose-users] Mouseover map area to show pop up or link
Brent Fraser bfraser at geoanalytic.com
Thu Jun 3 11:45:16 EDT 2010
Should we add Len's code to standard GeoMoose?  And expose it via something like:
<layer-controls>
	<layer-control name="popups"  service-name="popups"  layer-input="layer"
on="true" tip="Show Popups for %LAYER%"/>
	<layer-control name="maptips" service-name="maptips" layer-input="layer"
on="true" tip="Show MapTips for %LAYER%"/>
</layer-controls>
<service name="maptips" display="true">
	<url>php/popups.php</url>
	<step type="spatial" name="shape" line="false" polygon="false" point="false"
jump-start="true" default="hover">
		<header><![CDATA[
		Hover on the map to show a tip about the features.
		]]></header>
		<input type="hidden" name="layer"/>
	</step>
</service>
or something like that....
Brent
FRANZ OKYERE wrote:
> Thanks guys,
> I am going see how I can implement Len's solution in my current
> installation. I am going to try both options and see how it works. Len
> also gave this link earlier on
> :http://www.klamathdss.org/watershedviewer/# as an example of the
> identify tool being used with a popup. Any surprises, and I will get
> back and get some help. Thanks.
> Franz
> GIS Specialist
> Ghana
> From: lkne at houstoneng.com
> To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> Subject: RE: [Geomoose-users] Mouseover map area to show pop up or link
> Date: Thu, 3 Jun 2010 14:06:11 +0000
> One way would be to use OL Hover handler – see
> http://openlayers.org/dev/examples/hover-handler.html.  Basically it is
> going to make an ajax call to the identify service when the cursor
> hovers over a spot for a set time.  The script below works in my testing
> environment… it could be enabled as a tool or in onLoadedMapbook().
> Len
> // Hover support on WMS and MapServr layers
>                 var popup;
>                 OpenLayers.Control.Hover =
> OpenLayers.Class(OpenLayers.Control, {
>                 defaultHandlerOptions: {
>                     'delay': 500,
>                     'pixelTolerance': 20,
>                     'stopMove': false
>                 initialize: function(options) {
>                     this.handlerOptions = OpenLayers.Util.extend(
>                         {}, this.defaultHandlerOptions
>                     OpenLayers.Control.prototype.initialize.apply(
>                         this, arguments
>                     this.handler = new OpenLayers.Handler.Hover(
>                         this,
>                         {'pause': this.onPause, 'move': this.onMove},
>                         this.handlerOptions
>                 onPause: function(evt) {
>                                                 var feature =
> Map.getLonLatFromPixel(evt.xy);
>                                                 var url =
> '/php/identify.php?';
>                                                 var layersArray =
> GeoMOOSE.getVisibleLayers();
>                                                 layers =
> layersArray.join(':');
>                                                 var requestOptions =
> OpenLayers.Request.GET({
>        url: url,
>        params:
> {'shape': 'POINT(' + feature.lon + ' ' + feature.lat + ')',
> 'layers': layers,
> '_moosetime': (new Date()).getTime() },
>        async: false
> if(requestOptions.responseText) {
>        popup =
> new OpenLayers.Popup.FramedCloud("wms",
> Map.getLonLatFromPixel(evt.xy),
> null,
> requestOptions.responseText,
> null, false);
> Map.addPopup(popup);
>                 onMove: function(evt) {
>                                                 if (popup != null) {
>                                                 popup.destroy();
>                                                 popup = null;
>                     // if this control sent an Ajax request (e.g.
> GetFeatureInfo) when
>                     // the mouse pauses the onMove callback could be
> used to abort that
>                     // request.
>                 hover = new OpenLayers.Control.Hover();
>                 Map.addControl(hover);
>                 hover.activate();
> *From:* FRANZ OKYERE [mailto:franzzoa at hotmail.com]
> *Sent:* Wednesday, June 02, 2010 4:28 PM
> *To:* Geomooselist
> *Subject:* Re: [Geomoose-users] Mouseover map area to show pop up or link
> Thanks,
> But is geomoose not based on open layers? If it is then what we can do
> in open layers should be possible in geomoose, right? I really need to
> do this so if you can point me in the right direction and show me which
> of the javascript files I should be editing that would be nice.
> Franz
> Date: Wed, 2 Jun 2010 14:29:24 -0500
> From: Bob.Basques at ci.stpaul.mn.us <mailto:Bob.Basques at ci.stpaul.mn.us>
> To: bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>;
> franzzoa at hotmail.com <mailto:franzzoa at hotmail.com>
> CC: geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>
> Subject: Re: [Geomoose-users] Mouseover map area to show pop up or link
> All,
> Not on the feature(s), but the layer name/metadata icon in the side menu.
> bobb
>> >> Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> You mean by simply moving the cursor over the feature but not clicking it?
> Geomoose no (as far as I know). OpenLayers has a hover handler so we
> might be
> able to use that...
> Brent Fraser
> FRANZ OKYERE wrote:
>>  Hello all,
>>  I am using geomoose 2.2 and wish to do what google maps or bing maps are
>>  able to do- i.e. mouseover a location on the map and then get the popup
>>  showing up. Any ideas? Is such a thing possible at all in geomoose?
>>  Cheers.
>>  Franz
>>  GIS Specialist, Ghana.
>>  Get a free e-mail account with Hotmail. Sign-up now.
>>  _______________________________________________
>>  Geomoose-users mailing list
>>  Geomoose-users at lists.sourceforge.net
> <mailto:Geomoose-users at lists.sourceforge.net>
>>  https://lists.sourceforge.net/lists/listinfo/geomoose-users
> ThinkGeek and WIRED's GeekDad team up for the Ultimate
> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
> lucky parental unit.  See the prize list and enter to win:
> http://p.sf.net/sfu/thinkgeek-promo
> Get a new e-mail account with Hotmail - Free. Sign-up now.
> <http://clk.atdmt.com/UKM/go/197222280/direct/01/>
> Get a new e-mail account with Hotmail – Free. Sign-up now.
More information about the Geomoose-users mailing list
