[Geomoose-users] GeoMoose: problem with MapFile
Brent Fraser bfraser at geoanalytic.com
Wed Jun 9 11:03:22 EDT 2010
   After you install firebug, start Firefox. There will be a little bug icon on
the left side of the bottom status bar.  Click the bug to start Firebug, then
click on Firebug's "Net" menu item, then click on the Net  down arrow and the
"Enabled" choice.  This tells Firebug to display all the traffic between the
browser and  the various servers it communicates with.
   Type your mapping site's url into the Firefox and watch the firebug window.
There will be a list of GET requests, and under the Domain column you'll see at
least one request to your server.  Click the "+" to see all the details of the
request, then click on the request's "Response" tab to see how your server
responded to the browser's request.  Likely there will be a mapserver error message.
Best Regards,
Brent Fraser
Abel Ludba wrote:
> Re Hello Brent..
> Now, I'm running in my Win 7 and IIS and I got again the pink screen.
> I installed firebug.. but, how can I get arround.
> Thank you
> Abel
> *From:* Brent Fraser <bfraser at geoanalytic.com>
> *To:* Abel Ludba <abel.ludba at yahoo.ca>
> *Sent:* Tue, June 8, 2010 11:05:43 PM
> *Subject:* Re: GeoMoose: problem with MapFile
> Abel,
>   That's strange.  If you are intending to use Google and bing layers, you
> map projection must be EPSG:900913 (Google Mercator).  And if your
> spatial data specified in the Layer portion of the map file is not in
> that projection it must have a PROJECTION definition so mapserver can do
> the map projection.
> Brent
>>  Hello Brent,
>>  and thank you again.
>>  I found the problem: I think it's  a projection problem: I must use (ans I
>>  don't know why) the EPSG 45. It works..
>>  Best regards
>>  Abel
>>  ________________________________
>>  From: Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>>
>>  To: Abel Ludba <abel.ludba at yahoo.ca <mailto:abel.ludba at yahoo.ca>>
>>  Sent: Tue, June 8, 2010 4:19:23 PM
>>  Subject: Re: GeoMoose: problem with MapFile
>>  Abel,
>>  No problem but you may get more help sending your question to the
>>  GeoMoose users email list (go to GeoMOOSE home page http://geomoose.org/
>>  and look for the Mailing List link under the "More Information" section.
>>  The pink screen is the Openlayers component saying it didn't get an
>>  image from mapserver.  There are lots of reasons for this: IIS security,
>>  syntax problems in the map file, incorrect coordinate system definition,
>>  etc.
>>  Use Firefox's Firebug plugin to see what the server is returning.
>>  Best Regards,
>>  Brent Fraser
>> > Hello Brent.
>> > Excuse me to write to your professional email, but I'm having  a serious
>> > problem (started last week) and I can't figure out how I get rid of it.
>> > I'm trying to develop an Interactive atlas with GeoMoose.
>> > I can display WMS, google, bing, etc.  layers. When I try to display
>> > MapServer's  layers I get a pink screen even with files (shape and
>> > mapfile) provided with geomoose. Could you please help?
>> > I'm runnig on Windows 7 and IIS 7.
>> > Thank you.
>> > Regards.
>> > Abel.
More information about the Geomoose-users mailing list
