[Geomoose-users] Layer functions
Brent Fraser bfraser at geoanalytic.com
Thu Jun 10 12:53:11 EDT 2010
The correct example for the movable divs is
http://dev.geoext.org/trunk/geoext/examples/popup.html.  Click the one dot in
the center of the map, then in the popup window click the sideways pushpin icon
to enable dragging the popup window.
Brent Fraser wrote:
> Len,
>    That's good news!  A couple of the things I like (I think..) about GeoExt is
> the fact you can move the DIV/results windows around in the browser
> (http://dev.geoext.org/trunk/geoext/examples/print-extent.html), and the ability
> to select the printing extent
> inet(http://dev.geoext.org/trunk/geoext/examples/print-extent.html).
>    Maybe we can use the concepts without using the code...
> Brent
> Len Kne wrote:
>> I have been working towards getting jQuery (and any other js libraries) to fit into GeoMOOSE as a user extension.  Where these libraries can really help out is when processing data returned from a service.  For example, when you do a query and get more than a couple matching records, displaying the information in the tab makes it difficult to interpret the results.  Putting the results into a tabular format, in a DIV that can take more space than the tabs allow, is a much easier way for people to get the information.  jQuery and the other libraries make the creation of tables much easier.  They do add dependencies and increase the size of the js file, but this has to be balanced with the speed that the application can be developed and functionality they provide.  As a user extension, the developer can decide if the library is a appropriate for the application.
>> I wish I had some public facing examples of the jQuery with GeoMOOSE to share, but so far all of the applications using the library are password protected.  There will be some public ones soon...
>> Len
>> -----Original Message-----
>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>> Sent: Wednesday, June 09, 2010 1:25 PM
>> To: Brian Fischer
>> Cc: GeoMOOSE Users List
>> Subject: Re: [Geomoose-users] Layer functions
>> Brian Fischer wrote:
>>> Brent,
>>> Take a look at this site http://klamathdss.org/watershedviewer/, expand a layer group, then click on the layer name.  You'll notice the icons display below the layer name.  We essentially created an icon toggle because we were running out of screen space to put the icons next to the layer.  You'll see there are a couple extra icons already there like metadata and identify.  It wouldn't be hard to add the "zoom to" function.  I'm not a big fan of right-click menu's in web apps either.
>> Your implementation is a good compromise; I like it!
>>> In regards to the GeoEXT.  This has been a discussion topic for a while.  Len has used JQuery now for a couple of our projects.  For example he has the open attribute table working for search results.  It's pretty nice.  It's not a public app, but we could show you if you want to see how it works sometime.  Just shoot us an email offline. This fits nicely in with the user extension concept Dan started in the last version of GM.
>> I'm just looking for a way forward to add functionality to GM without re-coding the wheel.  Sounds like jQuery would at least supply the hub (but not the tire) ;)
>> Brent
>>> Brian Fischer, CFM  GIS Project Manager Houston Engineering, Inc.
>>> Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
>>> From: Dan Little [mailto:danlittle at yahoo.com]
>>> Sent: Tuesday, June 08, 2010 7:56 PM
>>> To: Brent Fraser; GeoMOOSE Users List
>>> Some thoughts:
>>>  - The "zoom tos" are really not all that hard to add and could be done with layer-controls.  Layer-controls are designed to provide extra "icons" next to each layer and have some type of useful functionality.
>>>  - Export to Shapefile only works for specific datasets and security/customization is usually a concern with this type of functionality.
>>>  - I tend to highly dislike right-click menus because they obscure functionality from users.
>>>  - GeoExt is a bad idea:
>>>    * Ext is another major dependencies.
>>>    * The dual-license of Ext would require people putting GeoMOOSE in a production environment to pay the Ext license.
>>> ----- Original Message ----
>>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>>> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>>>> Sent: Mon, June 7, 2010 12:32:34 PM
>>>> Subject: [Geomoose-users] Layer functions
>>>> I've been thinking about the Catalog tab, the list of layers, and
>>>> layer functions.
>>> Some layer functions I'd like to see:
>>>     (From
>>>> Quantum GIS:)
>>> - Zoom to Layer Extent
>>> - Zoom to best scale (for
>>>> raster)
>>> - Open Attribute Table
>>> - Save as Shapefile (and other
>>>> formats?)
>>> - Properties: metadata, symbology, attributes
>>> So some
>>>> questions:
>>> - should we consider adding more icons to the layer entries to do
>>>> more things?
>>> - should these icons be configurable (is that the intent of
>>>> <layer-controls>?)
>>> - should we move (at least some of) the icons to a
>>>> right-click menu?
>>> - should we adopt GeoExt to supply the Catalog
>>>> container/functions?
>>> Thanks!
>>> Brent
>>>> Fraser
>>> ThinkGeek
>>>> and WIRED's GeekDad team up for the Ultimate
>>> GeekDad Father's Day Giveaway.
>>>> ONE MASSIVE PRIZE to the
>>> lucky parental unit.  See the prize list and
>>>> enter to win:
>>> http://p.sf.net/sfu/thinkgeek-promo
>>> Geomoose-users
>>>> mailing list
>>>> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lis
>>>> t
>>>> s.sourceforge.net
>>>> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users"
>>>> target=_blank
>>> -------- ThinkGeek and WIRED's GeekDad team up for the Ultimate
>>> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.  See the prize list and enter to win:
>>> Geomoose-users mailing list
>> ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
