[Geomoose-users] query.php configuration confusion
Johan Forsman Johan.Forsman at LA.GOV
Wed Jun 16 15:08:24 EDT 2010
All:
Two issues to seek advice on this afternoon.
Platform is GM2.2, using webmaps as base with EPSG:900913 in the mapbook and settings.ini files. Source data is in EPSG:26915, being projected on-the-fly by MapServer to EPSG:900913. All layers I have render very nicely in all the right spots.
Issue 1:
I would like to use the new query.php function to search several tables in my PostGIS from one dialog. I have looked at the examples in the documentation but it appears I am not fully comprehending the syntax.
I have 5 layers I wish to search, each has its own table in PostGIS.
6 of the layers/tables have 2 identical fieldnames I wish to be able to search on, "pwsid" and "sysname".
The remaining table has two fields I wish to be able to search on, "regowner" and "newid" (ignore layer4 for now).
I used the "query.php" block from the demo mapbook and added/replaced my own layers.
When I test the query layer0 and layer1 are turned on in the map, but results are only returned for layer0.
I have a <input type...layer? for each layer.
I have a <input type...template? for each layer entry, but they all use value="itemquery" since each layer definition in the referenced mapfiles have unique templates defined there.
I am suspecting the problem lies somewhere with the "fieldname0" and "value0" parameters? In fieldname0 I have included all 4 of the fields, from 5 different tables, I wish to be able to specify the search from.
At the bottom of this message I have placed the query.php block as it looks currently. Please ignore the square footage bit; it's remaining from the demo, and I don't have an immediate need for the boolean functions.
I have been unable to stitch together a series of input types that covers the bases. Does someone on the list have a query block to share that does this that I may model mine after?
Issue 2:
All the layers plot where they should, but the highlights from the query results plot in Algeria. To emphasise, ONLY the highlights plot in the wrong place.  Clearly a projection error, but where? This also happens with the old itemquery.php since I switched from using EPSG:26915 in my mapbook to EPSG:900913.
Thanks for taking the time!
And I do apologize for the rudimentary XML skills that are apparently absent in my mapbook.
/Johan.
	<service name="search_facilities">
		<url>php/query.php</url>
		<step type="input">
			<input type="hidden" name="highlight" value="true"/>
			<input type="hidden" name="mode" value="search"/>
			<input type="hidden" name="layer0" value="wells/sdwis_wells"/>
			<input type="hidden" name="layer1" value="surfacewater/intakes"/>
			<input type="hidden" name="layer2" value="surfacewater/treatmentplants"/>
			<input type="hidden" name="layer3" value="storage/all"/>
			<input type="hidden" name="layer4" value="wells/swap_wells"/>
			<input type="hidden" name="layer5" value="wells/ldotd_all"/>
			<input type="hidden" name="template0" value="itemquery"/>
			<input type="hidden" name="template1" value="itemquery"/>
			<input type="hidden" name="template2" value="itemquery"/>
			<input type="hidden" name="template3" value="itemquery"/>
			<input type="hidden" name="template4" value="itemquery"/>
			<input type="hidden" name="template5" value="itemquery"/>
			<input type="select" name="fieldname0" title="Search By:">
				<option value="sysname">System Name</option>
				<option value="pwsid">PWSID</option>
				<option value="regowner">Registered owner</option>
				<option value="newid">Well id number</option>
			</input>
			<input type="select" name="comparitor0" title="That: ">
				<option value="like-icase">Contains</option>
				<option value="right-like-icase">Begins With</option>
				<option value="eq-str">Matches Exactly</option>
			</input>
			<input type="user" name="value0" title=""/>
			<input type="hidden" name="fieldname1" value="FIN_SQ_FT"/>
			<input type="select" name="operator1">
				<option value="or">OR</option>
				<option value="and">AND</option>
			</input>
			<input type="select" name="comparitor1" title="Having Fin. Sq. Ft. ">
				<option value="gt">Greater Than</option>
				<option value="eq">Equal To</option>
				<option value="lt">Less Than</option>
			</input>
			<input type="user" name="value1" title=""/>
		</step>
	</service>
More information about the Geomoose-users mailing list
