[Geomoose-users] Highlight projection issue
Johan Forsman Johan.Forsman at LA.GOV
Thu Jun 17 15:33:14 EDT 2010
Followup to my own message.
I have confirmed that the link returned by the javascript snippet below contains the correct extent IF interpreted as the original EPSG:26915 projection.
In other words somewhere along the way the bounds are not reprojected.
If I use a single water well in my PostGIS (that uses EPSG:26915) as example:
Stored coordinates are 748178.83, 333429.45 in NAD83 UTM15N.
Mapserver projects those to EPSG:900913 and obtains -10066017.27, 3517260.50 according to my Geomoose interface, which uses 900913. This is the correct location.
If I use my Geomoose interface and check the location in Algeria, it is indeed in agreement with the UTM numbers above.
To reiterate, all locations plot in the correct location, the highlight is now in the correct location, but the query-generated link appears to use the unprojected EPSG:26915 coordinates, taking me to Algeria.
What can I do?
Thanks!
Johan.
> -----Original Message-----
> From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
> Sent: Thursday, June 17, 2010 11:17 AM
> To: geomoose-users at lists.sourceforge.net
> Subject: [Geomoose-users] Highlight projection issue
> All:
> Focusing on the itemquery/highlight.map projection issue now. I thought I
> had it covered, but the plot has thickened.
> Making the changes described below indeed fixed the highlight problem, but
> there is still an underlying issue.
> If I click on the link generated by the
> javascript:GeoMOOSE.changeLayerUrl('highlight',...
> GeoMOOSE.zoomToExtent(662056.373600,3344506.451400,662056.373600,3344506.4
> 51400)
> function in the template file it zooms to the same spot in Algeria that
> the highlight was previously placed.
> There is clearly something sinister going on with the source of that
> extent.
> Where can I look / what info can I provide to help troubleshoot this?
> Or am I simply overlooking something embarrassingly simple?
> Thanks!
> Johan.
> > Sent: Thursday, June 17, 2010 8:03 AM
> > To: Len Kne; geomoose-users at lists.sourceforge.net
> > Subject: Re: [Geomoose-users] query.php configuration confusion
> > Ok, I found a solution to the highlight issue.
> > Adding the 900913 projection block to the MAP section in highlight.map
> did
> > not by itself change anything. However, if I also added the projection
> > that the data is stored as in the LAYER definition in the highlight.map
> > files it worked.
> > To summarize, to make the query and select highlighting work, in my
> case,
> > when the data is stored in a different projection than what is used in
> the
> > final output, the highlight.map files must look similar to this:
> > MAP
> > PROJECTION
> > 	"init=epsg:900913"
> > END
> > TRANSPARENT true
> > SYMBOL
> > 	NAME 'circle'
> > 	TYPE ellipse
> > 	POINTS
> > 		1 1
> > 	END
> > 	FILLED true
> > END
> > LAYER
> > 	PROJECTION
> > 		"init=epsg:26915"
> > 	END
> > 	NAME 'points'
> > 	TYPE POINT
> > 	STATUS DEFAULT
> > 	CLASS
> > 		SYMBOL 'circle'
> > 		COLOR 0 255 255
> > 		SIZE 16
> > 	END
> > END
> > > From: Len Kne [mailto:lkne at houstoneng.com]
> > > Sent: Wednesday, June 16, 2010 3:47 PM
> > > To: Johan Forsman; geomoose-users at lists.sourceforge.net
> > > Subject: RE: query.php configuration confusion
> > > Your parameters look right.  How about this -  queryitem, query and
> > select
> > > create a temp shape file with the results and then use a built in map
> > file
> > > to show the results.  Look for highlight.map in htdocs/php/itemquery
> > > and/or htdocs/php/select.  In the MAP object of the file, add the
> 900913
> > > projection information.  This should re-project the highlight results
> > > before returning them to GeoMOOSE.
> > > Len
> > > Sent: Wednesday, June 16, 2010 3:37 PM
> > > Hi Len, thanks for the response.
> > > On Issue 1  suspected that was it. I will attempt to craft an expanded
> > > section for each layer I wish to query.
> > > On Issue 2:
> > > Settings.ini contains
> > > 	projection=EPSG:900913
> > > Mapbook contains
> > > 	<param name="projection">EPSG:900913</param>
> > > Mapfiles contain
> > > 	PROJECTION
> > > 		"init=epsg:900913"
> > > 	END
> > > at the top, and
> > > 	PROJECTION
> > > 		"init=epsg:26915"
> > > 	END
> > > for each layer.
> > > Did I miss something?
> > > Thanks!
> > > /Johan.
> > > > Sent: Wednesday, June 16, 2010 3:22 PM
> > > > Hi Johan
> > > > Issue 2 - check conf/settings.ini to see what the projection is set
> > to.
> > > > Server-based services use this value for the projection, while
> client-
> > > > based services use the mapbook.
> > > > For issue 1, I think you are going to need "fieldnameX" for each
> layer
> > > > you are querying.  As your service is now configured, I would expect
> > > > it to only query Layer0 using fieldname0 and value0.  I do not
> believe
> > > > you will be able to query across multiple layers with one value
> > > > without some custom coding of query.php.
> > > > Len
> > > > Sent: Wednesday, June 16, 2010 2:08 PM
> > > > Subject: [Geomoose-users] query.php configuration confusion
> > > > All:
> > > > Two issues to seek advice on this afternoon.
> > > > Platform is GM2.2, using webmaps as base with EPSG:900913 in the
> > > > mapbook and settings.ini files. Source data is in EPSG:26915, being
> > > > projected on- the-fly by MapServer to EPSG:900913. All layers I have
> > > > render very nicely in all the right spots.
> > > > Issue 1:
> > > > I would like to use the new query.php function to search several
> > > > tables in my PostGIS from one dialog. I have looked at the examples
> in
> > > > the documentation but it appears I am not fully comprehending the
> > > syntax.
> > > > I have 5 layers I wish to search, each has its own table in PostGIS.
> > > > 6 of the layers/tables have 2 identical fieldnames I wish to be able
> > > > to search on, "pwsid" and "sysname".
> > > > The remaining table has two fields I wish to be able to search on,
> > > > "regowner" and "newid" (ignore layer4 for now).
> > > > I used the "query.php" block from the demo mapbook and
> added/replaced
> > > > my own layers.
> > > > When I test the query layer0 and layer1 are turned on in the map,
> but
> > > > results are only returned for layer0.
> > > > I have a <input type...layer? for each layer.
> > > > I have a <input type...template? for each layer entry, but they all
> > > > use value="itemquery" since each layer definition in the referenced
> > > > mapfiles have unique templates defined there.
> > > > I am suspecting the problem lies somewhere with the "fieldname0" and
> > > > "value0" parameters? In fieldname0 I have included all 4 of the
> > > > fields, from 5 different tables, I wish to be able to specify the
> > search
> > > from.
> > > > At the bottom of this message I have placed the query.php block as
> it
> > > > looks currently. Please ignore the square footage bit; it's
> remaining
> > > > from the demo, and I don't have an immediate need for the boolean
> > > functions.
> > > > I have been unable to stitch together a series of input types that
> > > > covers the bases. Does someone on the list have a query block to
> share
> > > > that does this that I may model mine after?
> > > > Issue 2:
> > > > All the layers plot where they should, but the highlights from the
> > > > query results plot in Algeria. To emphasise, ONLY the highlights
> plot
> > > > in the wrong place.  Clearly a projection error, but where? This
> also
> > > > happens with the old itemquery.php since I switched from using
> > > > EPSG:26915 in my mapbook to EPSG:900913.
> > > > Thanks for taking the time!
> > > > And I do apologize for the rudimentary XML skills that are
> apparently
> > > > absent in my mapbook.
> > > > /Johan.
> > > > 	<service name="search_facilities">
> > > > 		<url>php/query.php</url>
> > > > 		<step type="input">
> > > > 			<input type="hidden" name="highlight"
> value="true"/>
> > > > 			<input type="hidden" name="mode" value="search"/>
> > > > 			<input type="hidden" name="layer0"
> > > > value="wells/sdwis_wells"/>
> > > > 			<input type="hidden" name="layer1"
> > > > value="surfacewater/intakes"/>
> > > > 			<input type="hidden" name="layer2"
> > > > value="surfacewater/treatmentplants"/>
> > > > 			<input type="hidden" name="layer3"
> value="storage/all"/>
> > > > 			<input type="hidden" name="layer4"
> > > > value="wells/swap_wells"/>
> > > > 			<input type="hidden" name="layer5"
> > > > value="wells/ldotd_all"/>
> > > > 			<input type="hidden" name="template0"
> > > > value="itemquery"/>
> > > > 			<input type="hidden" name="template1"
> > > > value="itemquery"/>
> > > > 			<input type="hidden" name="template2"
> > > > value="itemquery"/>
> > > > 			<input type="hidden" name="template3"
> > > > value="itemquery"/>
> > > > 			<input type="hidden" name="template4"
> > > > value="itemquery"/>
> > > > 			<input type="hidden" name="template5"
> > > > value="itemquery"/>
> > > > 			<input type="select" name="fieldname0"
> title="Search
> > > By:">
> > > > 				<option value="sysname">System Name</option>
> > > > 				<option value="pwsid">PWSID</option>
> > > > 				<option value="regowner">Registered
> owner</option>
> > > > 				<option value="newid">Well id
> number</option>
> > > > 			</input>
> > > > 			<input type="select" name="comparitor0"
> title="That: ">
> > > > 				<option value="like-icase">Contains</option>
> > > > 				<option value="right-like-icase">Begins
> > > With</option>
> > > > 				<option value="eq-str">Matches
> Exactly</option>
> > > > 			</input>
> > > > 			<input type="user" name="value0" title=""/>
> > > > 			<input type="hidden" name="fieldname1"
> > > > value="FIN_SQ_FT"/>
> > > > 			<input type="select" name="operator1">
> > > > 				<option value="or">OR</option>
> > > > 				<option value="and">AND</option>
> > > > 			</input>
> > > > 			<input type="select" name="comparitor1"
> title="Having
> > > Fin. Sq. Ft.
> > > > 				<option value="gt">Greater Than</option>
> > > > 				<option value="eq">Equal To</option>
> > > > 				<option value="lt">Less Than</option>
> > > > 			</input>
> > > > 			<input type="user" name="value1" title=""/>
> > > > 		</step>
> > > > 	</service>
> > > > ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad
> > > > Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.
> > > > See the prize list and enter to win:
> > > > http://p.sf.net/sfu/thinkgeek-promo
> > > > _______________________________________________
> > > > Geomoose-users mailing list
> > > > Geomoose-users at lists.sourceforge.net
> > > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
> > lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
