[Geomoose-users] Identify Attributes on a WMS
Miller, Elizabeth (DOT) Elizabeth.Miller at state.mn.us
Fri Jun 18 10:58:25 EDT 2010
Thanks for the insight! It looks like the identify.php is getting the x and y (for the clicked point) as well as the 26915 from the configuration of the map. I tried defining the projection of the wms layer in the mapbook (projection="EPSG:4326") but that doesn't seem to override how identify.php is getting the point location and the projection.
I wonder if I should go back to trying to describe the layer with a mapfile? Any thoughts?
(By the way, this problem is handled successfully in ArcMap, where the identify tool is able to get the correct attribute response even when the wms is reprojected.)
Thanks again,
Liesa
Sent: Thursday, June 17, 2010 11:15 AM
To: Miller, Elizabeth (DOT); Brian Fischer; geomoose-users at lists.sourceforge.net
Subject: RE: Identify Attributes on a WMS
This works...
http://www.datafinder.org/wmsconnector/com.esri.wms.Esrimap/MN_MetroGIS_DataFinder_WMS_Recreation_Tourism?&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&WIDTH=100&HEIGHT=100&X=50&Y=50&EXCEPTIONS=application/vnd.ogc.se_xml&LAYERS=bikeways&QUERY_LAYERS=bikeways&BBOX=-94,44.5,-92,45.6&SRS=EPSG:4326&INFO_FORMAT=text/html&FEATURE_COUNT=100
Strange, because in the GetFeatureInfo it looks like 26915 is supported.
Len
From: Miller, Elizabeth (DOT) [mailto:Elizabeth.Miller at state.mn.us]
Sent: Thursday, June 17, 2010 9:56 AM
To: Brian Fischer; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Identify Attributes on a WMS
So, I've been working on this for a couple months now - still no luck! I've stopped using a mapfile and I now have my wms only as a source in my mapbook file. I am hitting the wms on the map with the identify tool and I am trying to get the identify.php to send the proper GetFeatureInfo request so that it can populate the wms_record.html. As an example, I am using the wms services at www.datafinder.org<http://www.datafinder.org>. The url that the identify.php is building for my request is this:
http://www.datafinder.org/wmsconnector/com.esri.wms.Esrimap/MN_MetroGIS_DataFinder_WMS_Recreation_Tourism?&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&WIDTH=100&HEIGHT=100&X=50&Y=50&EXCEPTIONS=application/vnd.ogc.se_xml&LAYERS=bikeways&QUERY_LAYERS=bikeways&BBOX=508702.025,4993206.245,508902.025,4993406.245&SRS=EPSG:26915&STYLES=&INFO_FORMAT=application/vnd.ogc.gml
As you can see if you hit this url, I am not getting any attribute information back. Any ideas why? Is there something missing from my request?
(Yes, the wms layer is queryable.)
Thanks for your help!
Liesa Miller
MnDOT Metro District
From: Brian Fischer [mailto:bfischer at houstoneng.com]
Sent: Thursday, April 22, 2010 12:17 PM
To: Miller, Elizabeth (DOT); geomoose-users at lists.sourceforge.net
In your mapfile that you are trying to identify on are you using?
                                METADATA
                                                'wms_record'    'identify_parcel.html'
                                END
I believe that is what tells the GeoMOOSE code to make a WMS identify request versus a MapServer identify request.  Have you look to see what firebug is return for results?  When I look through the identify.php code it appears to all be in there, but it is looking for the wms_record parmater in the mapfile.
Like I said I have not tried to use this feature myself but it is suppose to be supported.  Hope this helps you debug it a little bit more.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
Sent: Thursday, April 22, 2010 11:52 AM
Thanks Brian,
Yep, the WMS source should have attributes available for request. Here's my current METADATA code. As you can see, I think I've thrown everything but the kitchen sink in there. If you have any ideas or see any glaring errors let me know.
LAYER...
   METADATA
      "wms_identify" "identify_data.html"
      "wms_record" "identify_data.html"
      "wms_title" "layertitle"
      "wms_srs" "EPSG:26915"
      "wms_name" "layername"
      "wms_server_version" "1.1.1"
      "wms_format" "image/gif"
      "wms_styles" ""
      "wms_exceptions" "application/vnd.ogc.se_inimage"
      "wms_request" "GetMap"
      "wms_request" "GetFeatureInfo"
      "wms_include_items" "all"
      "wms_feature_info_mime_type" "text/html"
    END
    DUMP TRUE
    TEMPLATE '/ms4w/.../identify_data.html'
    TOLERANCE 3
...END
Sent: Wednesday, April 21, 2010 3:43 PM
Liesa,
First thing you will have to figure out is if the WMS source has setup any attributes to return with a getinfo wms request.  It should be published in the GetCapbilities if it is.  Not all WMS servers are setup by default to return all attributes.
I have never tried to use the identify with a WMS data source, but I believe Dan added support for it.  I have seen there are configuration settings for the html templates in settings.ini file.
Sent: Wednesday, April 21, 2010 3:07 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Attributes on a WMS
I'm looking for help in setting up an identify on a wms layer. I am using a mapfile to bring in the layer rather than setting up the connection in the mapbook. Does anyone have an example of how to do this? I would like to be able to click with the identify tool on the layer and return attributes in an html template.
Thanks!
Liesa Miller
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100618/e2f661e4/attachment.html
More information about the Geomoose-users mailing list
