[Geomoose-users] Highlight projection issue
Johan Forsman Johan.Forsman at LA.GOV
Fri Jun 18 11:14:01 EDT 2010
I decided to project the source data to the intended webmap projection and just store it that way. Everything is more-or-less in order now and there is a minor performance improvement without the on-the-fly projection.
Thanks for the pointers.
> -----Original Message-----
> From: Len Kne [mailto:lkne at houstoneng.com]
> Sent: Thursday, June 17, 2010 4:26 PM
> To: Johan Forsman; geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Highlight projection issue
> So it looks like there is some work to be done with GeoMOOSE services to
> fully support querying layers in projections different than GeoMOOSE...
> Since you are using PostGIS, you could do the transformation there with
> st_transform().  The re-projection can also happen on the service-side of
> the service or on the client-side with a GeoMOOSE user extension. This
> should work:
> TransformAndZoomExtension = new OpenLayers.Class(GeoMOOSE.UX.Extension, {
>         srcPrj: new OpenLayers.Projection('EPSG:26915'),
>         load: function() {
>         zoom: function(minx,miny,maxx,maxy) {
>                 var bounds = new
> OpenLayers.Bounds(minx,miny,maxx,maxy).transform(this.srcPrj,Map.projectio
> n);
>                 Map.zoomToExtent(bounds);
>         CLASS_NAME: "TransformAndZoomExtension"
> GeoMOOSE.UX.register('TransformAndZoomExtension');
> transformAndZoom = new TransformAndZoomExtension();
> Look at http://www.geomoose.org/docs/user_extensions.html for details on
> adding a user extension to GeoMOOSE.
> Then in your template, you would point to
> transformAndZoom.zoom([shpminx],[shpminy],[shpmaxx],[shpmaxy]);
> Len
> From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
> Sent: Thursday, June 17, 2010 2:33 PM
> To: geomoose-users at lists.sourceforge.net
> Followup to my own message.
> I have confirmed that the link returned by the javascript snippet below
> contains the correct extent IF interpreted as the original EPSG:26915
> projection.
> In other words somewhere along the way the bounds are not reprojected.
> If I use a single water well in my PostGIS (that uses EPSG:26915) as
> example:
> Stored coordinates are 748178.83, 333429.45 in NAD83 UTM15N.
> Mapserver projects those to EPSG:900913 and obtains -10066017.27,
> 3517260.50 according to my Geomoose interface, which uses 900913. This is
> the correct location.
> If I use my Geomoose interface and check the location in Algeria, it is
> indeed in agreement with the UTM numbers above.
> To reiterate, all locations plot in the correct location, the highlight is
> now in the correct location, but the query-generated link appears to use
> the unprojected EPSG:26915 coordinates, taking me to Algeria.
> What can I do?
> Thanks!
> Johan.
> > Sent: Thursday, June 17, 2010 11:17 AM
> > Subject: [Geomoose-users] Highlight projection issue
> > All:
> > Focusing on the itemquery/highlight.map projection issue now. I
> > thought I had it covered, but the plot has thickened.
> > Making the changes described below indeed fixed the highlight problem,
> > but there is still an underlying issue.
> > If I click on the link generated by the
> > javascript:GeoMOOSE.changeLayerUrl('highlight',...
> > GeoMOOSE.zoomToExtent(662056.373600,3344506.451400,662056.373600,33445
> > 06.4
> > 51400)
> > function in the template file it zooms to the same spot in Algeria
> > that the highlight was previously placed.
> > There is clearly something sinister going on with the source of that
> > extent.
> > Where can I look / what info can I provide to help troubleshoot this?
> > Or am I simply overlooking something embarrassingly simple?
> > Thanks!
> > Johan.
> > > Sent: Thursday, June 17, 2010 8:03 AM
> > > To: Len Kne; geomoose-users at lists.sourceforge.net
> > > Subject: Re: [Geomoose-users] query.php configuration confusion
> > > Ok, I found a solution to the highlight issue.
> > > Adding the 900913 projection block to the MAP section in
> > > highlight.map
> > did
> > > not by itself change anything. However, if I also added the
> > > projection that the data is stored as in the LAYER definition in the
> > > highlight.map files it worked.
> > > To summarize, to make the query and select highlighting work, in my
> > case,
> > > when the data is stored in a different projection than what is used
> > > in
> > the
> > > final output, the highlight.map files must look similar to this:
> > > MAP
> > > PROJECTION
> > >     "init=epsg:900913"
> > > END
> > > TRANSPARENT true
> > > SYMBOL
> > >     NAME 'circle'
> > >     TYPE ellipse
> > >     POINTS
> > >             1 1
> > >     END
> > >     FILLED true
> > > END
> > > LAYER
> > >     PROJECTION
> > >             "init=epsg:26915"
> > >     END
> > >     NAME 'points'
> > >     TYPE POINT
> > >     STATUS DEFAULT
> > >     CLASS
> > >             SYMBOL 'circle'
> > >             COLOR 0 255 255
> > >             SIZE 16
> > >     END
> > > END
> > > > Sent: Wednesday, June 16, 2010 3:47 PM
> > > > Subject: RE: query.php configuration confusion
> > > > Your parameters look right.  How about this -  queryitem, query
> > > > and
> > > select
> > > > create a temp shape file with the results and then use a built in
> > > > map
> > > file
> > > > to show the results.  Look for highlight.map in
> > > > htdocs/php/itemquery and/or htdocs/php/select.  In the MAP object
> > > > of the file, add the
> > 900913
> > > > projection information.  This should re-project the highlight
> > > > results before returning them to GeoMOOSE.
> > > > Len
> > > > Sent: Wednesday, June 16, 2010 3:37 PM
> > > > Hi Len, thanks for the response.
> > > > On Issue 1  suspected that was it. I will attempt to craft an
> > > > expanded section for each layer I wish to query.
> > > > On Issue 2:
> > > > Settings.ini contains
> > > >   projection=EPSG:900913
> > > > Mapbook contains
> > > >   <param name="projection">EPSG:900913</param>
> > > > Mapfiles contain
> > > >   PROJECTION
> > > >           "init=epsg:900913"
> > > >   END
> > > > at the top, and
> > > >   PROJECTION
> > > >           "init=epsg:26915"
> > > >   END
> > > > for each layer.
> > > > Did I miss something?
> > > > Thanks!
> > > > /Johan.
> > > > > Sent: Wednesday, June 16, 2010 3:22 PM
> > > > > Hi Johan
> > > > > Issue 2 - check conf/settings.ini to see what the projection is
> > > > > set
> > > to.
> > > > > Server-based services use this value for the projection, while
> > client-
> > > > > based services use the mapbook.
> > > > > For issue 1, I think you are going to need "fieldnameX" for each
> > layer
> > > > > you are querying.  As your service is now configured, I would
> > > > > expect it to only query Layer0 using fieldname0 and value0.  I
> > > > > do not
> > believe
> > > > > you will be able to query across multiple layers with one value
> > > > > without some custom coding of query.php.
> > > > > Len
> > > > > Sent: Wednesday, June 16, 2010 2:08 PM
> > > > > Subject: [Geomoose-users] query.php configuration confusion
> > > > > All:
> > > > > Two issues to seek advice on this afternoon.
> > > > > Platform is GM2.2, using webmaps as base with EPSG:900913 in the
> > > > > mapbook and settings.ini files. Source data is in EPSG:26915,
> > > > > being projected on- the-fly by MapServer to EPSG:900913. All
> > > > > layers I have render very nicely in all the right spots.
> > > > > Issue 1:
> > > > > I would like to use the new query.php function to search several
> > > > > tables in my PostGIS from one dialog. I have looked at the
> > > > > examples
> > in
> > > > > the documentation but it appears I am not fully comprehending
> > > > > the
> > > > syntax.
> > > > > I have 5 layers I wish to search, each has its own table in
> PostGIS.
> > > > > 6 of the layers/tables have 2 identical fieldnames I wish to be
> > > > > able to search on, "pwsid" and "sysname".
> > > > > The remaining table has two fields I wish to be able to search
> > > > > on, "regowner" and "newid" (ignore layer4 for now).
> > > > > I used the "query.php" block from the demo mapbook and
> > added/replaced
> > > > > my own layers.
> > > > > When I test the query layer0 and layer1 are turned on in the
> > > > > map,
> > but
> > > > > results are only returned for layer0.
> > > > > I have a <input type...layer? for each layer.
> > > > > I have a <input type...template? for each layer entry, but they
> > > > > all use value="itemquery" since each layer definition in the
> > > > > referenced mapfiles have unique templates defined there.
> > > > > I am suspecting the problem lies somewhere with the "fieldname0"
> > > > > and "value0" parameters? In fieldname0 I have included all 4 of
> > > > > the fields, from 5 different tables, I wish to be able to
> > > > > specify the
> > > search
> > > > from.
> > > > > At the bottom of this message I have placed the query.php block
> > > > > as
> > it
> > > > > looks currently. Please ignore the square footage bit; it's
> > remaining
> > > > > from the demo, and I don't have an immediate need for the
> > > > > boolean
> > > > functions.
> > > > > I have been unable to stitch together a series of input types
> > > > > that covers the bases. Does someone on the list have a query
> > > > > block to
> > share
> > > > > that does this that I may model mine after?
> > > > > Issue 2:
> > > > > All the layers plot where they should, but the highlights from
> > > > > the query results plot in Algeria. To emphasise, ONLY the
> > > > > highlights
> > plot
> > > > > in the wrong place.  Clearly a projection error, but where? This
> > also
> > > > > happens with the old itemquery.php since I switched from using
> > > > > EPSG:26915 in my mapbook to EPSG:900913.
> > > > > Thanks for taking the time!
> > > > > And I do apologize for the rudimentary XML skills that are
> > apparently
> > > > > absent in my mapbook.
> > > > > /Johan.
> > > > >         <service name="search_facilities">
> > > > >                 <url>php/query.php</url>
> > > > >                 <step type="input">
> > > > >                         <input type="hidden" name="highlight"
> > value="true"/>
> > > > >                         <input type="hidden" name="mode"
> value="search"/>
> > > > >                         <input type="hidden" name="layer0"
> > > > > value="wells/sdwis_wells"/>
> > > > >                         <input type="hidden" name="layer1"
> > > > > value="surfacewater/intakes"/>
> > > > >                         <input type="hidden" name="layer2"
> > > > > value="surfacewater/treatmentplants"/>
> > > > >                         <input type="hidden" name="layer3"
> > value="storage/all"/>
> > > > >                         <input type="hidden" name="layer4"
> > > > > value="wells/swap_wells"/>
> > > > >                         <input type="hidden" name="layer5"
> > > > > value="wells/ldotd_all"/>
> > > > >                         <input type="hidden" name="template0"
> > > > > value="itemquery"/>
> > > > >                         <input type="hidden" name="template1"
> > > > > value="itemquery"/>
> > > > >                         <input type="hidden" name="template2"
> > > > > value="itemquery"/>
> > > > >                         <input type="hidden" name="template3"
> > > > > value="itemquery"/>
> > > > >                         <input type="hidden" name="template4"
> > > > > value="itemquery"/>
> > > > >                         <input type="hidden" name="template5"
> > > > > value="itemquery"/>
> > > > >                         <input type="select" name="fieldname0"
> > title="Search
> > > > By:">
> > > > >                                 <option value="sysname">System
> Name</option>
> > > > >                                 <option
> value="pwsid">PWSID</option>
> > > > >                                 <option
> value="regowner">Registered
> > owner</option>
> > > > >                                 <option value="newid">Well id
> > number</option>
> > > > >                         </input>
> > > > >                         <input type="select" name="comparitor0"
> > title="That: ">
> > > > >                                 <option value="like-
> icase">Contains</option>
> > > > >                                 <option value="right-like-
> icase">Begins
> > > > With</option>
> > > > >                                 <option value="eq-str">Matches
> > Exactly</option>
> > > > >                         </input>
> > > > >                         <input type="user" name="value0"
> title=""/>
> > > > >                         <input type="hidden" name="fieldname1"
> > > > > value="FIN_SQ_FT"/>
> > > > >                         <input type="select" name="operator1">
> > > > >                                 <option value="or">OR</option>
> > > > >                                 <option value="and">AND</option>
> > > > >                         </input>
> > > > >                         <input type="select" name="comparitor1"
> > title="Having
> > > > Fin. Sq. Ft.
> > > > >                                 <option value="gt">Greater
> Than</option>
> > > > >                                 <option value="eq">Equal
> To</option>
> > > > >                                 <option value="lt">Less
> Than</option>
> > > > >                         </input>
> > > > >                         <input type="user" name="value1"
> title=""/>
> > > > >                 </step>
> > > > >         </service>
> > > > > ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad
> > > > > Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental
> unit.
> > > > > See the prize list and enter to win:
> > > > > http://p.sf.net/sfu/thinkgeek-promo
> > > > > _______________________________________________
> > > > > Geomoose-users mailing list
> > > > > Geomoose-users at lists.sourceforge.net
> > > > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > > Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.
> ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's
> Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.  See the prize
> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
> lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
