[Geomoose-users] query.php performance advice sought
Brent Fraser bfraser at geoanalytic.com
Tue Jun 22 23:36:06 EDT 2010
It could be mapserver's processing of the query.    See
http://trac.osgeo.org/mapserver/ticket/3069
Try mapserver v5.6
Best Regards,
Brent Fraser
> Hi Len, thanks for the PgAdmin suggestion; I hadn't thought to do the SQL
> there to test, only checked with a row filter. Here is the result of a
> simple SELECT query to find all the records with syspop between 0 and
> 5000.
> SELECT gid, pwsid, sysname, pwstype, syspop, parish, dhhregion, sysstatus,
>        other_sysn, sourcetype, sourcecoun, facid, facname, other_facn,
>        wellregid, constr_dat, facstatus, facstatus_, lat, lon, datum,
>        location_d, moreinfo, staticleve, groutingde, welldepth, welldiam,
>        point_x, point_y, wkb_geometry
>   FROM webmaps_sdwis_wells
>   WHERE (syspop > 0 and syspop < 5000);
> Total query runtime: 241 ms.
> 3294 rows retrieved.
> I would submit that postgres is working ok with that runtime.
> I tested a brief version of your template suggestion by pointing to a
> simple html that only returns a record id. With that I get back 3294 rows
> of records in my "Search results" tab in 43 seconds. With my swanky
> formatted template it takes 5 minutes and 35 seconds to get the same
> results back.
> That's hard data that seems to suggest that it's the templating that
> consumes all the time and resources.
> Looks like a workaround is prescribed, and I need to learn how to make the
> right links from the result list to the "more info" template.
> Thanks for the help!
> /Johan.
>> -----Original Message-----
>> From: Len Kne [mailto:lkne at houstoneng.com]
>> Sent: Tuesday, June 22, 2010 4:38 PM
>> To: Johan Forsman; geomoose-users at lists.sourceforge.net
>> Subject: RE: query.php performance advice sought
>> Johan
>> Something seems wrong with the performance when accessing the Postgres
>> DB.
>> You say there are only 4000 records, unless there are a million
>> attributes, seems like that should be a really quick query.  Have you
>> tried running the query from the command line or PGAdmin to see how it
>> performs?
>> If you have a large number of records with a large mapserver template,
>> it
>> is going to take some time to get that data to the client.  Could you
>> have
>> a simple template that returns just the syspop attribute and then have a
>> link to make a follow-up query if details are needed?
>> Another thing to check out is FastCGI, I seen some performance boost
>> using
>> it.
>> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html#f-
>> fastcgi
>> Len
>> From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
>> Sent: Tuesday, June 22, 2010 3:06 PM
>> To: geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] query.php performance advice sought
>> Please pardon the prior incomplete post; I inadvertently pressed "send"
>> rather than "save draft". Blame it on the streaming World Cup coverage
>> online. Here is the more complete version.
>> Preemptive apologies for a long post. I have attempted to collect enough
>> data for the collective to have a chance at theorizing.
>> I am attempting to use the new query.php to extract a subset of a
>> PostGIS
>> table based on integer values stored in the "syspop" field. My service
>> definition looks like this at the moment (I made a copy of the original
>> query.php and changed the name to allow for troubleshooting without
>> risking destroying the original, hence the different script name):
>> 	<service name="advanced_search">
>> 		<url>php/query_sdwp.php</url>
>> 		<step type="input">
>> 			<input type="hidden" name="highlight" value="false"/>
>> 			<input type="hidden" name="mode" value="search"/>
>> 			<input type="hidden" name="layer0"
>> value="wells/sdwis_wells"/>
>> 			<input type="hidden" name="template0"
>> value="itemquery"/>
>> 			<input type="hidden" name="fieldname0" value="syspop"/>
>> 			<input type="user" name="value0" title="Population is
>> greater than"/>
>> 			<input type="hidden" name="comparitor0" value="gt"/>
>> 			<input type="hidden" name="operator1" value="and"/>
>> 			<input type="hidden" name="fieldname1" value="syspop"/>
>> 			<input type="user" name="value1" title="and less than"/>
>> 			<input type="hidden" name="comparitor1" value="lt"/>
>> 		</step>
>> 	</service>
>> It's not pretty but it works. Sort of. I am having problems with the
>> performance to such extent it's not usable. I have made some attempts to
>> quantify this below. It's not scientific, but it is illustrative.
>> Relevant stats:
>> Server hardware is 2 x 2.0 GHz Xeon, 3 GB RAM. It's a repurposed Dell
>> PowerEdge 4600, I think.
>> Server OS is Ubuntu Server 9.10.
>> GeoMoose 2.2 in FGS 9.5 with MapServer 5.4.2.
>> Dataset of interest is a point set with 4100 total records, stored in
>> PostGIS on the same server. An index on the syspop field has no
>> discernible effect on the performance.
>> During testing I was the only user on the server.
>> I turned off highlighting so the query would only run once.
>> I ran two scenarios:
>> 1) syspop >5000 and syspop <10000
>> 2) syspop >0 and syspop <5000
>> I observed the server process list to determine where the CPU time was
>> being spent.
>> I uncommented the existing diagnostic lines in query.php to verify the
>> request and the result count for both scenarios and they are both
>> correct.
>> I increased the php timeout to 10 minutes and the php memory to 128 megs
>> to stop those errors from interfering. I am logging the php errors and
>> file is now clear with no errors.
>> These are the results for the two scenarios:
>> Search Layer: wells/sdwis_wells
>> Template: itemquery
>> FILTER: syspop > 5000 and syspop < 10000 Total Results: 306 Stop watch
>> time to completion: 13 seconds Time spent by postgres: 7 seconds with
>> CPU
>> at 88% Time spent by httpd: 6 seconds with CPU at 92%
>> Template: itemquery
>> FILTER: syspop > 0 and syspop < 5000
>> Total Results: 3323
>> Stop watch time to completion: 5.5 minutes!
>> Time spent by postgres: 30 seconds with CPU at 88% Time spent by httpd:
>> 5
>> minutes with CPU at 92%
>> With that CPU usage I'd say stuff is going on, but what? SQL-wise this
>> is
>> a very simple query, is it not?
>> My baseline comparison is that for both scenarios a SQL query from
>> Access
>> 2007 on my workstation on the linked table from the server, or a row
>> filter from PgAdmin, returns the expected results instantaneously.
>> Apples
>> and oranges I know, but perhaps confirmation that the database can work
>> quickly and serve the expected results in no time flat?
>> I tried a MapServer direct URL query, with a simple template to just
>> list
>> the record IDs in the browser like so:
>> .../cgi-
>> bin/mapserv?map=/opt/fgs/apps/geomoose2/maps/sdwp/wells/wells_webmaps.map&
>> layers=sdwis_wells&mode=itemnquery&qlayer=sdwis_wells&qitem=syspop&qstring
>> =(syspop > 5000 and syspop < 10000)
>> This returns the 306 records to the browser window in 3 seconds with
>> barely a blip in the server CPU usage.
>> Direct URL query with syspop > 0 and syspop < 5000:
>> Returns the 3323 records to the browser window in 35 seconds with server
>> CPU (postgres) at 85%. A respectable portion of that time is
>> transferring
>> the data to the browser window.
>> If those URL queries are representative of what GM is doing, then I'd
>> say
>> that the 30-second mark is as fast as MapServer can query the PostGIS
>> and
>> return the results on this system, but what in the world is going on
>> during those other 5 minutes? I know GM building the formatted results
>> with the template, but what else? Is there a way to tell?
>> Very oddly with the URL queries: The mapfile contains a FILTER
>> "sysstatus
>> = 'Active'" directive to only include the active records. If that
>> directive is absent the URL query works, but if it is present I receive
>> and error: "Content-type: text/html msDrawMap(): Image handling error.
>> Failed to draw layer named 'sdwis_wells'". Depending on what numbers I
>> use
>> for the lower and upper bounds I can get some records returned before
>> the
>> error. MapServer bug? MapServer feature? PEBKAC? Just weird?
>> I don't know that there is anything I can do, but please feel free to
>> opine at will; I am fresh out of ideas. My coding skills are worse than
>> non-existent; they are dangerous, and regrettably there is no budget for
>> that shiny new 26 GHz Core i13, which surely would address some part of
>> this.
>> Sorry about the long post. After this, I'm thinking it's noon
>> somewhere...
>> /Johan.
>> Johan Forsman
>> Geologist
>> Safe Drinking Water Program
>> Louisiana Department of Health and Hospitals Office of Public Health
>> Telephone: 225.342.7309
>> Telefax: 225.342.7303
>> ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's
>> Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.  See the
>> prize
>> list and enter to win:
>> http://p.sf.net/sfu/thinkgeek-promo
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
> lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
