[Geomoose-users] Mouseover map area to show pop up or link
franzzoa at hotmail.com franzzoa at hotmail.com
Wed Jun 23 04:19:29 EDT 2010
Hi all,
I have succeeded in implementing your code on a polygon data set but with
point data I think there is probably an issue. There seem to be a
fundamental problem that I am not aware of. I have checked and rechecked the
templates, the mapfile and as for the code its the same. There is something
probably funny with the querybypoint as opposed to querybyshape? Any idea
Len (its kinda your brain child?)?
Franz
Sent: Thursday, June 03, 2010 4:40 PM
To: "'Brent Fraser'" <bfraser at geoanalytic.com>
Cc: "Geomooselist" <geomoose-users at lists.sourceforge.net>
Subject: Re: [Geomoose-users] Mouseover map area to show pop up or link
> Performance seems ok, you can try it at
> http://dev.houstoneng.net/geomoose.html.  Hover over a parcel for 1 second
> and you should get a popup.  It's different than passing over a marker in
> OL because the handler is triggered after a pause in mouse movement vs.
> going over the marker.  The downside is there will be a lot of calls back
> to the server (could be an issue on a high use app) and in the case of
> parcels, the number of popups could get annoying to the person looking at
> the map.  Might work better with point data.
> Len
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, June 03, 2010 10:05 AM
> To: Len Kne
> Cc: Geomooselist
> Len,
> That's impressive!  How's the performance?
> Brent
> Len Kne wrote:
>> One way would be to use OL Hover handler - see
>> http://openlayers.org/dev/examples/hover-handler.html.  Basically it
>> is going to make an ajax call to the identify service when the cursor
>> hovers over a spot for a set time.  The script below works in my
>> testing environment... it could be enabled as a tool or in
>> onLoadedMapbook().
>> Len
>> // Hover support on WMS and MapServr layers
>>                 var popup;
>>                 OpenLayers.Control.Hover =
>> OpenLayers.Class(OpenLayers.Control, {
>>                 defaultHandlerOptions: {
>>                     'delay': 500,
>>                     'pixelTolerance': 20,
>>                     'stopMove': false
>>                 initialize: function(options) {
>>                     this.handlerOptions = OpenLayers.Util.extend(
>>                         {}, this.defaultHandlerOptions
>>                     OpenLayers.Control.prototype.initialize.apply(
>>                         this, arguments
>>                     this.handler = new OpenLayers.Handler.Hover(
>>                         this,
>>                         {'pause': this.onPause, 'move': this.onMove},
>>                         this.handlerOptions
>>                 onPause: function(evt) {
>>                                                 var feature =
>> Map.getLonLatFromPixel(evt.xy);
>>                                                 var url =
>> '/php/identify.php?';
>>                                                 var layersArray =
>> GeoMOOSE.getVisibleLayers();
>>                                                 layers =
>> layersArray.join(':');
>>                                                 var requestOptions =
>> OpenLayers.Request.GET({
>>        url:
>> url,
>>        params:
>> {'shape': 'POINT(' + feature.lon + ' ' + feature.lat + ')',
>> 'layers': layers,
>> '_moosetime': (new Date()).getTime() },
>>        async:
>> false
>> if(requestOptions.responseText) {
>>        popup
>> = new OpenLayers.Popup.FramedCloud("wms",
>> Map.getLonLatFromPixel(evt.xy),
>> null,
>> requestOptions.responseText,
>> null, false);
>> Map.addPopup(popup);
>>                 onMove: function(evt) {
>>                                                 if (popup != null) {
>>                                                 popup.destroy();
>>                                                 popup = null;
>>                     // if this control sent an Ajax request (e.g.
>> GetFeatureInfo) when
>>                     // the mouse pauses the onMove callback could be
>> used to abort that
>>                     // request.
>>                 hover = new OpenLayers.Control.Hover();
>>                 Map.addControl(hover);
>>                 hover.activate();
>> *From:* FRANZ OKYERE [mailto:franzzoa at hotmail.com]
>> *Sent:* Wednesday, June 02, 2010 4:28 PM
>> *To:* Geomooselist
>> *Subject:* Re: [Geomoose-users] Mouseover map area to show pop up or
>> link
>> Thanks,
>> But is geomoose not based on open layers? If it is then what we can do
>> in open layers should be possible in geomoose, right? I really need to
>> do this so if you can point me in the right direction and show me
>> which of the javascript files I should be editing that would be nice.
>> Franz
>> Date: Wed, 2 Jun 2010 14:29:24 -0500
>> From: Bob.Basques at ci.stpaul.mn.us <mailto:Bob.Basques at ci.stpaul.mn.us>
>> To: bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>;
>> franzzoa at hotmail.com <mailto:franzzoa at hotmail.com>
>> CC: geomoose-users at lists.sourceforge.net
>> <mailto:geomoose-users at lists.sourceforge.net>
>> link
>> All,
>> Not on the feature(s), but the layer name/metadata icon in the side menu.
>> bobb
>>> >> Brent Fraser <bfraser at geoanalytic.com
>> <mailto:bfraser at geoanalytic.com>> wrote:
>> You mean by simply moving the cursor over the feature but not clicking
>> it?
>> Geomoose no (as far as I know). OpenLayers has a hover handler so we
>> might be able to use that...
>> Brent Fraser
>> FRANZ OKYERE wrote:
>>>  Hello all,
>>>  I am using geomoose 2.2 and wish to do what google maps or bing maps
>>> are  able to do- i.e. mouseover a location on the map and then get
>>> the popup  showing up. Any ideas? Is such a thing possible at all in
>>> geomoose?
>>>  Cheers.
>>>  Franz
>>>  GIS Specialist, Ghana.
>>> ---  Get a free e-mail account with Hotmail. Sign-up now.
>>>  _______________________________________________
>>>  Geomoose-users mailing list
>>>  Geomoose-users at lists.sourceforge.net
>> <mailto:Geomoose-users at lists.sourceforge.net>
>>>  https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> -------- ThinkGeek and WIRED's GeekDad team up for the Ultimate
>> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental
>> unit.  See the prize list and enter to win:
>> http://p.sf.net/sfu/thinkgeek-promo
>> Get a new e-mail account with Hotmail - Free. Sign-up now.
>> <http://clk.atdmt.com/UKM/go/197222280/direct/01/>
> lucky parental unit.  See the prize list and enter to win:
More information about the Geomoose-users mailing list
