[Geomoose-users] Mouseover map area to show pop up or link
FRANZ OKYERE franzzoa at hotmail.com
Wed Jun 23 15:33:01 EDT 2010
Nay,
Well that is weird.. But try changing selectable="true" for the tool in your mapbook and lets see. If that does not work your only option will be to write a small function that capitalises on the identify button unchecked property (advanced for me though).
You need to also make sure that your code is not sitting within onLoadMapbook function. Cheers.
Franz
To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
Date: Wed, 23 Jun 2010 10:16:49 -0500
Subject: RE: [Geomoose-users] Mouseover map area to show pop up or link
Thanks Franz! It works. The pop-ups are turned on only when I
select the Identify button. But they don’t disappear when some other tool
is selected.
Any ideas on how to turn off the pop-up hover when the identify
button is unselected?
Thanks
Nayna
[mailto:franzzoa at hotmail.com]
Sent: 22 June 2010 15:07
To: Geomooselist
Subject: Re: [Geomoose-users] Mouseover map area to show pop up or link
Nayate,
I think (I have not tried it out) you first need to go to the mapbook
and change the following line
<tool name="identify" title="Identify"
type="service" service="identify"
cursor="url('cursors/identify2.cur'),auto"/>
to
type="javascript" selectable="true">
   GeoMOOSE.popIdentify(arguments);
  </tool>
Then in compiled.js write the popIdentify function such that it is within the
window.Geomoose constructor?
All the best.
Franz
GIS Specialist
Ghana
To: geomoose-users at lists.sourceforge.net
Date: Tue, 22 Jun 2010 13:20:21 -0500
I tried this code out in my geomoose application by inserting
the code in the onLoadedMapbook() in complied.js and it works well.
Any hints on how I could be enabled as a tool?  I’m
trying to get this functionality activated only when I select the identify
tool.
[mailto:lkne at houstoneng.com]
Sent: 03 June 2010 09:06
To: 'FRANZ OKYERE'; Geomooselist
One way would be to use OL Hover handler – see http://openlayers.org/dev/examples/hover-handler.html.
Basically it is going to make an ajax call to the identify service when the
cursor hovers over a spot for a set time.  The script below works in my testing
environment… it could be enabled as a tool or in onLoadedMapbook().
Len
// Hover support on WMS and MapServr layers
var popup;
OpenLayers.Control.Hover = OpenLayers.Class(OpenLayers.Control,
                defaultHandlerOptions:
'delay': 500,
'pixelTolerance': 20,
'stopMove': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
                    this.handler
= new OpenLayers.Handler.Hover(
this,
{'pause': this.onPause, 'move': this.onMove},
this.handlerOptions
onPause: function(evt) {
var feature = Map.getLonLatFromPixel(evt.xy);
var url = '/php/identify.php?';
var layersArray = GeoMOOSE.getVisibleLayers();
layers = layersArray.join(':');
var requestOptions = OpenLayers.Request.GET({
url: url,
params: {'shape': 'POINT(' + feature.lon + ' ' + feature.lat + ')',
'layers': layers,
'_moosetime': (new Date()).getTime() },
async: false
if(requestOptions.responseText) {
popup = new OpenLayers.Popup.FramedCloud("wms",
Map.getLonLatFromPixel(evt.xy),
null,
requestOptions.responseText,
null, false);
Map.addPopup(popup);
onMove: function(evt) {
if (popup != null) {
popup.destroy();
popup = null;
// if this control sent an Ajax request (e.g. GetFeatureInfo) when
// the mouse pauses the onMove callback could be used to abort that
// request.
hover = new
OpenLayers.Control.Hover();
Map.addControl(hover);
hover.activate();
Sent: Wednesday, June 02, 2010 4:28 PM
To: Geomooselist
Thanks,
But
is geomoose not based on open layers? If it is then what we can do in open
layers should be possible in geomoose, right? I really need to do this so if
you can point me in the right direction and show me which of the javascript
files I should be editing that would be nice.
Franz
Date: Wed, 2 Jun 2010 14:29:24 -0500
To: bfraser at geoanalytic.com; franzzoa at hotmail.com
CC: geomoose-users at lists.sourceforge.net
All,
Not
on the feature(s), but the layer name/metadata icon in the side menu.
bobb
>>> Brent Fraser <bfraser at geoanalytic.com>
wrote:
You mean by simply moving the cursor over
the feature but not clicking it?
Geomoose no (as far as I know). OpenLayers has a hover handler so we might be
able to use that...
Brent Fraser
FRANZ OKYERE wrote:
> Hello all,
> I am using geomoose 2.2 and wish to do what google maps or bing maps are
> able to do- i.e. mouseover a location on the map and then get the popup
> showing up. Any ideas? Is such a thing possible at all in geomoose?
> Cheers.
> Franz
> GIS Specialist, Ghana.
> Get a free e-mail account with Hotmail. Sign-up now.
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit.  See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
Get
a new e-mail account with Hotmail - Free. Sign-up now.
Get
now.
_________________________________________________________________
http://clk.atdmt.com/UKM/go/197222280/direct/01/
Do you have a story that started on Hotmail? Tell us now
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100623/d811216f/attachment.html
More information about the Geomoose-users mailing list
