[Geomoose-users] query.php performance advice sought
Dan Little danlittle at yahoo.com
Sat Jun 26 04:00:47 EDT 2010
I would also check firebug to see what the return time is for the script.  This very well may be the browser taking a long time to render the HTML.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: bfraser at geoanalytic.com
> Cc: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Tue, June 22, 2010 10:50:55 PM
> Subject: Re: [Geomoose-users] query.php performance advice sought
> Ok, disregards my comment below.  Based on your emails the likely cause
> is
the query PHP and mapscript.
Brent
> It could be
> mapserver's processing of the query.    See
> http://trac.osgeo.org/mapserver/ticket/3069
> Try mapserver
> v5.6
> Best Regards,
> Brent
> Fraser
>> Hi Len, thanks for the PgAdmin suggestion; I
> hadn't thought to do the
>> SQL
>> there to test, only checked
> with a row filter. Here is the result of a
>> simple SELECT query to
> find all the records with syspop between 0 and
> 5000.
>> SELECT gid, pwsid, sysname, pwstype, syspop,
> parish, dhhregion,
>> sysstatus,
> other_sysn, sourcetype, sourcecoun, facid, facname,
> other_facn,
>>        wellregid, constr_dat,
> facstatus, facstatus_, lat, lon, datum,
> location_d, moreinfo, staticleve, groutingde, welldepth,
> welldiam,
>>        point_x, point_y,
> wkb_geometry
>>   FROM webmaps_sdwis_wells
> WHERE (syspop > 0 and syspop < 5000);
>> Total query
> runtime: 241 ms.
>> 3294 rows retrieved.
>> I
> would submit that postgres is working ok with that
> runtime.
>> I tested a brief version of your template
> suggestion by pointing to a
>> simple html that only returns a record
> id. With that I get back 3294
>> rows
>> of records in my
> "Search results" tab in 43 seconds. With my swanky
>> formatted
> template it takes 5 minutes and 35 seconds to get the same
>> results
> back.
>> That's hard data that seems to suggest that it's
> the templating that
>> consumes all the time and
> resources.
>> Looks like a workaround is prescribed, and I
> need to learn how to make
>> the
>> right links from the
> result list to the "more info" template.
>> Thanks for the
> help!
>> /Johan.
>>> -----Original
> Message-----
>>> From: Len Kne [mailto:
> ymailto="mailto:lkne at houstoneng.com"
> href="mailto:lkne at houstoneng.com">lkne at houstoneng.com]
>>> Sent:
> Tuesday, June 22, 2010 4:38 PM
>>> To: Johan Forsman;
> ymailto="mailto:geomoose-users at lists.sourceforge.net"
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net
> Subject: RE: query.php performance advice sought
> Johan
>>> Something seems wrong with the performance
> when accessing the Postgres
>>> DB.
>>> You say there
> are only 4000 records, unless there are a million
>>> attributes,
> seems like that should be a really quick query.  Have you
> tried running the query from the command line or PGAdmin to see how
> it
>>> performs?
>>> If you have a large
> number of records with a large mapserver template,
> it
>>> is going to take some time to get that data to the
> client.  Could you
>>> have
>>> a simple template
> that returns just the syspop attribute and then have
> a
>>> link to make a follow-up query if details are
> needed?
>>> Another thing to check out is FastCGI, I
> seen some performance boost
>>> using
> it.
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html#f-
> fastcgi
>>> Len
> -----Original Message-----
>>> From: Johan Forsman [mailto:
> ymailto="mailto:Johan.Forsman at LA.GOV"
> href="mailto:Johan.Forsman at LA.GOV">Johan.Forsman at LA.GOV]
> Sent: Tuesday, June 22, 2010 3:06 PM
>>> To:
> sought
>>> Please pardon the prior incomplete post;
> I inadvertently pressed "send"
>>> rather than "save draft". Blame
> it on the streaming World Cup coverage
>>> online. Here is the more
> complete version.
>>> Preemptive apologies for a
> long post. I have attempted to collect
>>> enough
> data for the collective to have a chance at
> theorizing.
>>> I am attempting to use the new
> query.php to extract a subset of a
>>> PostGIS
>>> table
> based on integer values stored in the "syspop" field. My service
> definition looks like this at the moment (I made a copy of the
> original
>>> query.php and changed the name to allow for
> troubleshooting without
>>> risking destroying the original, hence
> the different script name):
> <service name="advanced_search">
>     <url>php/query_sdwp.php</url>
>         <step type="input">
>             <input type="hidden"
> name="highlight" value="false"/>
>         <input type="hidden" name="mode"
> value="search"/>
> name="layer0"
>>> value="wells/sdwis_wells"/>
> name="template0"
> value="itemquery"/>
>         <input type="hidden" name="fieldname0"
> value="syspop"/>
>     <input type="user" name="value0" title="Population
> is
>>> greater than"/>
>         <input type="hidden" name="comparitor0"
> value="gt"/>
>         <input type="hidden" name="operator1"
> value="and"/>
>         <input type="hidden" name="fieldname1"
> value="syspop"/>
>         <input type="user" name="value1"
> title="and less than"/>
>     <input type="hidden" name="comparitor1"
> value="lt"/>
> </step>
> </service>
>>> It's not pretty but it works.
> Sort of. I am having problems with the
>>> performance to such
> extent it's not usable. I have made some attempts
> to
>>> quantify this below. It's not scientific, but it is
> illustrative.
>>> Relevant stats:
> Server hardware is 2 x 2.0 GHz Xeon, 3 GB RAM. It's a repurposed
> Dell
>>> PowerEdge 4600, I think.
>>> Server OS is
> Ubuntu Server 9.10.
>>> GeoMoose 2.2 in FGS 9.5 with MapServer
> 5.4.2.
>>> Dataset of interest is a point set with
> 4100 total records, stored in
>>> PostGIS on the same server. An
> index on the syspop field has no
>>> discernible effect on the
> performance.
>>> During testing I was the only user
> on the server.
>>> I turned off highlighting so the
> query would only run once.
>>> I ran two
> scenarios:
>>> 1) syspop >5000 and syspop
> <10000
>>> 2) syspop >0 and syspop
> <5000
>>> I observed the server process list to
> determine where the CPU time was
>>> being
> spent.
>>> I uncommented the existing diagnostic
> lines in query.php to verify the
>>> request and the result count
> for both scenarios and they are both
> correct.
>>> I increased the php timeout to 10
> minutes and the php memory to 128
>>> megs
>>> to stop
> those errors from interfering. I am logging the php errors and
> file is now clear with no errors.
>>> These are the
> results for the two scenarios:
>>> Search Layer:
> wells/sdwis_wells
>>> Template: itemquery
>>> FILTER:
> syspop > 5000 and syspop < 10000 Total Results: 306 Stop
> watch
>>> time to completion: 13 seconds Time spent by postgres: 7
> seconds with
>>> CPU
>>> at 88% Time spent by httpd: 6
> seconds with CPU at 92%
>>> Search Layer:
> wells/sdwis_wells
>>> Template: itemquery
>>> FILTER:
>>> Total Results:
> 3323
>>> Stop watch time to completion: 5.5 minutes!
> Time spent by postgres: 30 seconds with CPU at 88% Time spent by
> httpd:
>>> 5
>>> minutes with CPU at
> 92%
>>> With that CPU usage I'd say stuff is going
> on, but what? SQL-wise this
>>> is
>>> a very simple
> query, is it not?
>>> My baseline comparison is that
> for both scenarios a SQL query from
>>> Access
>>> 2007
> on my workstation on the linked table from the server, or a row
> filter from PgAdmin, returns the expected results
> instantaneously.
>>> Apples
>>> and oranges I know, but
> perhaps confirmation that the database can work
>>> quickly and
> serve the expected results in no time flat?
>>> I
> tried a MapServer direct URL query, with a simple template to
> just
>>> list
>>> the record IDs in the browser like
> so:
>>> .../cgi-
> bin/mapserv?map=/opt/fgs/apps/geomoose2/maps/sdwp/wells/wells_webmaps.map&
> layers=sdwis_wells&mode=itemnquery&qlayer=sdwis_wells&qitem=syspop&qstring
> =(syspop > 5000 and syspop < 10000)
>>> This
> returns the 306 records to the browser window in 3 seconds with
> barely a blip in the server CPU usage.
>>> Direct
> URL query with syspop > 0 and syspop < 5000:
>>> Returns the
> 3323 records to the browser window in 35 seconds with
> server
>>> CPU (postgres) at 85%. A respectable portion of that time
> is
>>> transferring
>>> the data to the browser
> window.
>>> If those URL queries are representative
> of what GM is doing, then I'd
>>> say
>>> that the
> 30-second mark is as fast as MapServer can query the PostGIS
> and
>>> return the results on this system, but what in the world is
> going on
>>> during those other 5 minutes? I know GM building the
> formatted results
>>> with the template, but what else? Is there a
> way to tell?
>>> Very oddly with the URL queries:
> The mapfile contains a FILTER
>>> "sysstatus
> 'Active'" directive to only include the active records. If that
> directive is absent the URL query works, but if it is present I
> receive
>>> and error: "Content-type: text/html msDrawMap(): Image
> handling error.
>>> Failed to draw layer named 'sdwis_wells'".
> Depending on what numbers I
>>> use
>>> for the lower
> and upper bounds I can get some records returned before
> the
>>> error. MapServer bug? MapServer feature? PEBKAC? Just
> weird?
>>> I don't know that there is anything I can
> do, but please feel free to
>>> opine at will; I am fresh out of
> ideas. My coding skills are worse than
>>> non-existent; they are
> dangerous, and regrettably there is no budget
> for
>>> that shiny new 26 GHz Core i13, which surely would address
> some part of
>>> this.
>>> Sorry about
> the long post. After this, I'm thinking it's noon
> somewhere...
>>> /Johan.
>>> Johan Forsman
> Geologist
>>> Safe Drinking Water Program
>>> Louisiana
> Department of Health and Hospitals Office of Public Health
> Telephone: 225.342.7309
>>> Telefax:
> 225.342.7303
>>> ThinkGeek and WIRED's GeekDad team up for the Ultimate
> GeekDad Father's
>>> Day Giveaway. ONE MASSIVE PRIZE to the lucky
> parental unit.  See the
>>> prize
>>> list and
> enter to win:
> http://p.sf.net/sfu/thinkgeek-promo
>>> Geomoose-users
> mailing list
> ymailto="mailto:Geomoose-users at lists.sourceforge.net"
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
> target=_blank
> >https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> GeekDad
> Father's Day Giveaway. ONE MASSIVE PRIZE to the
>> lucky parental
> unit.  See the prize list and enter to win:
> href="http://p.sf.net/sfu/thinkgeek-promo" target=_blank
>> Geomoose-users
> mailing list
> target=_blank
> GeekDad Father's
> lucky parental unit.  See
> Geomoose-users mailing
> list
> target=_blank
ThinkGeek
GeekDad Father's Day Giveaway.
lucky parental unit.  See the prize list and
> enter to win:
Geomoose-users
> mailing list
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
More information about the Geomoose-users mailing list
