[Geomoose-users] Fwd: Doubt about QUERY
Levy Carvalho levycm at gmail.com
Mon Jun 28 10:00:55 EDT 2010
I'm using the tag <!-MapServer Template -> in my templates and I'm using
Geomoose version 1.6.1 soon, and not own the file settings.ini . Do you have
any other opnion?
2010/6/24 Len Kne <lkne at houstoneng.com>
A couple things to check:
> 1.       Make sure the root path is set properly in conf/settings.ini.
> This value is used by the server-side services.
> 2.       Make sure your template file begins with <!—MapServer Template
> 3.       Comment out the error_reporting(E_ERROR | E_PARSE) line in the
> service, maybe get a more helpful error message.
> Len
> *From:* Levy Carvalho [mailto:levycm at gmail.com]
> *Sent:* Wednesday, June 23, 2010 1:53 PM
> *To:* geomoose-users at lists.sourceforge.net
> *Subject:* [Geomoose-users] Doubt about QUERY
> Hello,
> I have a doubt and would like your help. I have a web application running
> on Windows using MapServer+GEOMOOSE+POSTGRES/PostGIS provides that all
> residents of a neighborhood. In the application, the user can click on a
> particular resident and see various information about this resident. Works
> perfectly. When this app was migrated to Linux, I encountered a problem.
> Clicking the resident, the mapserver returns the following message:
> msQueryByPoint (): Search returned no results. No matching record (s) found.
> I could look at the DEBUG that the app instead of request the information
> regarding the coordinates of the clicked point, it captures coordinate
> completely different.
> Can someone help me solve this?
> thanks!
> obs: I am attaching the debug file.
> Levy Carvalho Melo
Levy Carvalho Melo
Levy Carvalho Melo
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100628/669ef6ae/attachment.html
More information about the Geomoose-users mailing list
