[Geomoose-users] Question about polygon queries
Brent Fraser bfraser at geoanalytic.com
Tue Mar 23 09:36:23 EDT 2010
Dan,
   Good point.  When Sacha said "the area of each type that falls inside my
custom polygon", I thought that was referring to calculating the area (e.g.
square kilometers) of each type in the input polygon.
Brent
Dan Little wrote:
> Is this just a type of select query using a drawn polygon? If so, I thought that was demonstrated in the demo...
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: Sacha Black <sacha.black at gmail.com>
>> Cc: geomoose-users at lists.sourceforge.net
>> Sent: Sun, March 14, 2010 8:58:37 PM
>> Subject: Re: [Geomoose-users] Question about polygon queries
>> Sacha,
>   As far as I know, Geomoose has no capability to do
>> this.  While there
> are some tools in Geomoose to draw a polygon, you
>> would need to write
> some server-side scripting (for example, in PHP) to take
>> the drawn
> polygon and do an Intersection on the soils layer, possibly using
>> the
> OGR_G_Intersection function in GDAL's OGR API (although I'm not
>> sure
> that function is available through MS4W's OGR PHP library).
> Best
>> Regards,
> Brent Fraser
>> I have a soils layer and I can use Geomoose
>> information tool to query
>> (by point or rectangle) a soil polygon or
>> polygons to get the soil
>> types. I would like to find out if it is
>> possible to draw an arbitrary
>> (non-rectangular) polygon and use that
>> polygon to get a list of the
>> sail types, and the area of each type that
>> falss inside my custom
>> polygon.
>> I know how to construct
>> the queries I need to run in PostGIS, but what
>> I don't know how to do is
>> how to draw & pass the custom query area
>> from GeoMoose to PostGIS.
>> Is this currently possible? Where would I
>> look if I were trying to add
>> this functionality?
>> thanks for any suggestions,
>> Sacha
>> Download Intel® Parallel Studio Eval
>> Try the new software tools for
>> yourself. Speed compiling, find bugs
>> proactively, and fine-tune
>> applications for parallel performance.
>> See why Intel Parallel Studio got
>> high marks during beta.
>> http://p.sf.net/sfu/intel-sw-dev
>> Geomoose-users mailing
>> list
>> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
>> target=_blank
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Download
> Try the new software tools for yourself.
> proactively, and fine-tune applications for
> See why Intel Parallel Studio got high marks during
>> beta.
> Geomoose-users
>> mailing list
>> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
More information about the Geomoose-users mailing list
