[Geomoose-users] Display Join Fields in an Item Query
Brian Welch Brian.Welch at CI.NORTHFIELD.MN.US
Wed Mar 31 17:57:49 EDT 2010
Using GM 1.6 at the moment:
I am trying to pull field values from a join table (just a simple CSV file joined to my parcel shapefile) in order to provide access to utility account information on my Information tab of GeoMoose. When I try to pull the data from a field in the joined table in my itemquery.html file I get only the join field name I put into the HTML code (e.g. Test_Value). From what I can tell from the MapServer documentation the syntax for a join field is JOINNAME_FIELDNAME.
I've created the join in my parcel map file and the parcel layer still displays, so I think my join syntax is correct. I haven't thought of another way to test whether the join worked or not, but assuming it has, can I pull field values from the joined table in an Item Query?
In other words, does the GeoMoose Item Query count as a MapServer query that will activate the join?
Thanks.
Brian
Brian Welch, GIS Technician
City of Northfield
Northfield, MN 55057
507-645-3027
This message and any attachments may contain confidential and /or proprietary information and is intended for the person / entity to whom it was originally addressed.  Any use by others is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100331/8108b9bd/attachment.html
More information about the Geomoose-users mailing list
