[Geomoose-users] Scalebar & Measure
Brent Fraser bfraser at geoanalytic.com
Mon May 3 11:03:42 EDT 2010
Paul, Len,
   Our scale problem is a (mostly) map projection issue.  All map projections
introduce distortions in trying to represent a round(ish) Earth on a flat plane.
  Mercator is no different: it is like wrapping an up-right cylinder around the
Earth, projecting light from the center onto the cylinder
(http://en.wikipedia.org/wiki/Mercator_projection).  As you can imagine the
distortions get "worse" the further from the equator.   The distortions can be
modeled as a Point Scale Factor.  At the equator the Point Scale Factor is 1.0,
at latitude 60 degrees North (or South), the scale factor is 0.5!
   So what's the solution?  Here's mine:
   1. Enhance Proj4 (and Proj4js) to return the Point Scale factor (given the
projection and a location)
   2. Enhance MapServer and Openlayers to use the Point Scale Factor in
calculating distances and scale.
I'm trying to drum up interest, but so no takers....
   http://osgeo-org.1803224.n2.nabble.com/Point-Scale-factor-service-td4938743.html
http://osgeo-org.1803224.n2.nabble.com/Re-3265-Scale-dependent-layer-switching-error-with-Mercator-td4966902.html
Best Regards,
Brent Fraser
Len Kne wrote:
> The scale bar issue with the web Mercator projection is a limitation of
> OpenLayers, the application GeoMOOSE 2.x uses to render the map frame.
>   There has been discussion on the OpenLayers site about providing a
> patch (this link offers a patch http://trac.openlayers.org/ticket/1890 )
> in the next version 2.9.  I’m sure GM will upgrade to OL 2.9, but not
> sure there is any schedule in place to do this.
> The cursor issue is also kind of fun because it seems each browser
> handles the custom icons differently.  Here’s the attribute in the
> mapbook which defines the query for the Identify service:
> cursor="url('cursors/identify2.cur') 9 9,url('cursors/identify2.cur'),auto"
> This makes three attempts to draw the cursor, the first offsets the
> mouse click 9 pixels from the top and the left.  Firefox can use this
> value and seems to line the mouse click up pretty good with the
> crosshair.  However, IE cannot handle the offset adjustment, so it reads
> the second cursor definition.  There are tools like AT File Mole which
> can be used to edit the hotspot of a cursor.  Attached is the latest
> version I have been using for Identify service, again this seems to line
> the crosshair up pretty well with the mouse click.  If you are using
> Safari or Chrome, these setting don’t seem to work at all and I would
> recommend not using customer cursors with those browsers.
> Len
> *From:* Wirth, Paul [mailto:Paul.Wirth at kniferiver.com]
> *Sent:* Saturday, May 01, 2010 9:03 PM
> *To:* 'geomoose-users at lists.sourceforge.net'
> *Subject:* [Geomoose-users] Scalebar & Measure
> Two questions:
> 1.       I have a web Mercator application, and I noticed that the
> scalebar does not display the correct distance.  For instance, when the
> scalebar shows a distance of 20 miles, it measures only 13.8 miles.  I
> know the measure tools are working correctly, so I assume this is a
> scalebar issue.  Any thoughts on how to fix this?
> 2.       I think this question was asked before, but I can’t seem to
> find it on the e-mail list.  With the measure tools, the cursor does not
> start measuring at the “crosshairs” when the user clicks, but rather in
> the NW quadrant of the crosshairs.  Is there a way to change it so the
> measure start point will be on the crosshairs?
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
