[Geomoose-users] Feature Report
Dan Little danlittle at yahoo.com
Wed May 12 18:43:32 EDT 2010
Mark,
Have you checked the conf directory to make sure all the paths are correct?
>From: Mark Volz <MarkVolz at co.lyon.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wed, May 12, 2010 3:04:20 PM
>Subject: [Geomoose-users] Feature Report
>Hello,
>I am working on getting a feature reportup and runningfor an additional site. However,I have get the following error:
>Fatal error: Call to a member function getAttribute() on a non-object inC:\ms4w\apps\MurrayMOOSE\htdocs\php\print_util.phpon line95.
>When I created the second site I copied the identify.html, mapbooks, and the feature report service.  However I noticed that the calls between the working site and not working site are slightly different. The calls to print.php are almost exactly the same except that the non working site hasfive%2C(periods)and the moosetimein the call.
>Working example:
>http://localhost/geomoose2/php/print.php?layers=%20%7B%22order%22%3A%5B%22ParcelReportLayers%22,%22StandardBackground%22%5D,%22ParcelReportLayers%22%3A%7B%22layers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D,%22StandardBackground%22%3A%7B%22layers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=329264.61988304%2C94540.935672515%2C672735.38011696%2C260459.06432749&mode=feature_report&padding=25&src=ParcelReportLayers%2Fparcels&PARCEL_ID=11-010002-0&title=Map&date=true&template=parcel&quality=2&scale=No
>non-working example:
>http://localhost/MurrayMoose/php/print.php?layers=%20%7B%22order%22%3A%5B%22ParcelReportLayers%22%2C%22StandardBackground%22%5D%2C%22ParcelReportLayers%22%3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%22%3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%2C%22StandardBackground%22%3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%22%3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=316170%2C75940%2C682830%2C253060&mode=feature_report&padding=25&src=ParcelReportLayers%2Fparcels&PID=15.019.002.0&title=Map&date=true&template=parcel&quality=2&scale=No&_moosetime=1273691480404
>Any help would be appreciated.  Thanks!
>Mark Volz
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100512/6e12d6dd/attachment.html
More information about the Geomoose-users mailing list
