[Geomoose-users] Geomoose-users Digest, Vol 32, Issue 6
Paul Wickman paul at northstargeographics.com
Wed May 12 18:48:48 EDT 2010
Doesn't OpenLayers support ArcGIS REST services?
http://dev.openlayers.org/releases/OpenLayers-2.9.1/doc/apidocs/files/OpenLayers/Layer/ArcGIS93Rest-js.html
Thanks,
Paul Wickman
Northstar Geographics
612.280.5850
On May 12, 2010, at 5:42 PM, geomoose-users-request at lists.sourceforge.net wrote:
> Send Geomoose-users mailing list submissions to
> 	geomoose-users at lists.sourceforge.net
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.sourceforge.net/lists/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	geomoose-users-owner at lists.sourceforge.net
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
>   1. Re: identify maps (Dieter Lehmann)
>   2. Feature Report (Mark Volz)
>   3. ArcGIS Services (Dave Misun)
>   4. Re: ArcGIS Services (Dan Little)
> Message: 1
> Date: Mon, 10 May 2010 21:38:55 +0200
> From: Dieter Lehmann <dieter.lehmann at hfwu.de>
> Subject: Re: [Geomoose-users] identify maps
> To: geomoose-users at lists.sourceforge.net
> Message-ID: <80E12B79-797D-4674-BBC3-D7218F929408 at hfwu.de>
> Content-Type: text/plain; charset="us-ascii"
> Hi Len,
> thanks for your reply. After your answer I looked through my files and found the error - I had a typo within the wms_onlineresource.
> Thanks,
> Dieter
> Am 03.05.2010 um 16:36 schrieb Len Kne:
>> If you can post your mapbook and relevant map file, we can take a further look.  The error is referring to the shape GM is sending to do the query.
>> Len
>> From: Dieter Lehmann [mailto:dieter.lehmann at hfwu.de]
>> Sent: Sunday, May 02, 2010 8:39 AM
>> Subject: [Geomoose-users] identify maps
>> Hello,
>> I' m having problems with the identify tool. I'm getting the following error:
>> Fatal error: Call to a member function queryByPoint() on a non-object in/var/www//temp/htdocs/php/identify.php on line 125
>> With the parcel - demo the identify is no problem.
>> Any hints?
>> Could the cause somehow be my projection? I'm using wgs84 (epsg:4326) for my application.
>> If someone have a cookbook for adding new layers plus identify them that would be great - in the wiki this is  missing for geomoose 2 or at least I couldn't find it.
>> Thanks,
>> Dieter
> -------------- next part --------------
> An HTML attachment was scrubbed...
> Message: 2
> Date: Wed, 12 May 2010 15:04:20 -0500
> From: "Mark Volz" <MarkVolz at co.lyon.mn.us>
> Subject: [Geomoose-users] Feature Report
> To: <geomoose-users at lists.sourceforge.net>
> Message-ID:
> 	<3D56274B4A7874468F58FADDBFD09801090C5E3E at llmhs02.r8nssis.local>
> Hello,
> I am working on getting a feature report up and running for an additional
> site.  However, I have get the following error:
> Fatal error: Call to a member function getAttribute() on a non-object in
> C:\ms4w\apps\MurrayMOOSE\htdocs\php\print_util.php on line 95.
> When I created the second site I copied the identify.html, mapbooks, and the
> feature report service.  However I noticed that the calls between the working
> site and not working site are slightly different.  The calls to print.php are
> almost exactly the same except that the non working site has five %2C
> (periods) and the moosetime in the call.
> Working example:
> http://localhost/geomoose2/php/print.php?layers=%20%7B%22order%22%3A%5B%22Par
> celReportLayers%22,%22StandardBackground%22%5D,%22ParcelReportLayers%22%3A%7B
> %22layers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22u
> rl%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D,%22StandardBackground%22%3A%7B%22la
> yers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22url%22
> %3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=329264.61988304%2C94540.935672
> 515%2C672735.38011696%2C260459.06432749&mode=feature_report&padding=25&src=Pa
> rcelReportLayers%2Fparcels&PARCEL_ID=11-010002-0&title=Map&date=true&template
> =parcel&quality=2&scale=No
> non-working example:
> http://localhost/MurrayMoose/php/print.php?layers=%20%7B%22order%22%3A%5B%22P
> arcelReportLayers%22%2C%22StandardBackground%22%5D%2C%22ParcelReportLayers%22
> %3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%22%
> 3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%2C%22StandardBackground
> %22%3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%
> 22%3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=316170%2C7
> 5940%2C682830%2C253060&mode=feature_report&padding=25&src=ParcelReportLayers%
> 2Fparcels&PID=15.019.002.0&title=Map&date=true&template=parcel&quality=2&scal
> e=No&_moosetime=1273691480404
> Any help would be appreciated.  Thanks!
> Mark Volz
> Message: 3
> Date: Wed, 12 May 2010 16:37:40 -0500
> From: Dave Misun <dmisun at kapur-assoc.com>
> Subject: [Geomoose-users] ArcGIS Services
> To: "geomoose-users at lists.sourceforge.net"
> 	<geomoose-users at lists.sourceforge.net>, 'Len Kne'
> 	<lkne at houstoneng.com>
> Message-ID:
> 	<5D6DB2B48B2DB64F91BE36639FE6127B02D3419D7F at mail1.kapur-assoc.com>
> Hi GM Users,
> Is there a way in GeoMOOSE to consume data published on the web as an ESRI ArcGIS Service? I know that WMS is a viable map source for GM, but I don't think that ESRI uses that convention in its services. Sigh, when will the proprietery software model become extinct...
> Any suggestions or advice?
> Thank you,
> Dave Misun
> Message: 4
> Date: Wed, 12 May 2010 15:42:17 -0700 (PDT)
> From: Dan Little <danlittle at yahoo.com>
> Subject: Re: [Geomoose-users] ArcGIS Services
> To: Dave Misun <dmisun at kapur-assoc.com>,
> 	<geomoose-users at lists.sourceforge.net>, Len Kne <lkne at houstoneng.com>
> Message-ID: <651689.27200.qm at web51401.mail.re2.yahoo.com>
> ArcGIS Server does, in fact, serve WMS... one of the guys actually running the server software may want to sound off on how to do that specifically...
>> To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; Len Kne <lkne at houstoneng.com>
>> Sent: Wed, May 12, 2010 4:37:40 PM
>> Hi GM
>> Users,
>> Is there a way in
>> become extinct...
>> Any suggestions or
>> advice?
>> Thank
>> you,
>> Dave Misun
> Geomoose-users at lists.sourceforge.net
> End of Geomoose-users Digest, Vol 32, Issue 6
More information about the Geomoose-users mailing list
