[Geomoose-users] Geocode and Identify Errors
Brent Fraser bfraser at geoanalytic.com
Fri May 21 20:16:13 EDT 2010
Wes,
  I was thinking of the FPDI PDF file "template" (the PDF files in
Geomoose/conf/print), not the Mapserver results HTML "template".  I
haven't done much with printing in GM 2, but its likely that there are
some restrictions as to the version of PDF and kinds/arrangement of
elements inside the PDF templates.
Brent
> I am using a custom template that was created and implemented in ms4w
> 2.3.1, there was no errors when using ms4w only when I switched to
> linux/FGS9.5. As well I am not at the office this moment, so I don't know
> the exact version of php, but I believe it is php5.3.something, whichever
> version is in the most current version of fgs9.5.
> Thanks for the help.
> Wes
> Sent on the Sprint® Now Network from my BlackBerry®
> -----Original Message-----
> From: Brent Fraser <bfraser at geoanalytic.com>
> Date: Fri, 21 May 2010 16:05:44
> To: Wes Cleland<wcleland at vanburencity.org>
> Cc: <geomoose-users at lists.sourceforge.net>
> Subject: Re: [Geomoose-users] Geocode and Identify Errors
> For the printing errors, it looks like its having problems with the
> template PDF
> file.  Is it the same as with the demo data or did you edit it?
> Which version of PHP are you using?
> Best Regards,
> Brent Fraser
> Wes Cleland wrote:
>> This is the error when attempting to print:
>> *Deprecated*: Assigning the return value of new by reference is
>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi.php* on line *88*
>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi_pdf_parser.php* on
>> line *244*
>> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on line
>> *102*
>> *285*
>> *437*
>> *Warning*: Cannot modify header information - headers already sent by
>> (output started at /opt/geomoose2/htdocs/php/fpdi/fpdi.php:88) in
>> */opt/geomoose2/htdocs/php/print.php* on line *136*
>> The identify error is this:
>> As previously stated, I can load the default mapbook.xml with the demo
>> data and the identify/select/buffer/search works fine, but when I load
>> the mapbook created with my data it gives me these errors. I even went
>> as far as rebuilding the mapbook ensuring that every little word was
>> typed correctly/etc.
>> v/r,
>> Wesley T. Cleland, GISP, CFM
>> GIS Coordinator
>> City of Van Buren, Arkansas
>> 479-471-5025
>> “One ought never to turn one's back on a threatened danger and try to
>> run away from it. If you do that, you will double the danger. But if you
>> meet it promptly and without flinching, you will reduce the danger by
>> half. Never run away from anything. Never!”
>> Winston Churchill
>> *From:* danlittle at yahoo.com [mailto:danlittle at yahoo.com]
>> *Sent:* Friday, May 21, 2010 8:21 AM
>> *To:* wcleland at vanburencity.org geomoose-users at lists.sourceforge.net
>> *Subject:* Re: [Geomoose-users] Geocode and Identify Errors
>> I'd suggest two things:
>> 1) File a bug in Trac.
>> 2) Edit both geocode.php and identify.php files and replace "split" with
>> "explode".  PHP does obnoxiously stupid things with strings and string
>> functions.
>>     *From:* Wes Cleland <wcleland at vanburencity.org>
>>     *To:* geomoose-users at lists.sourceforge.net
>>     *Sent:* Thu, May 20, 2010 4:04:06 PM
>>     *Subject:* [Geomoose-users] Geocode and Identify Errors
>>     First off, I would like to say thanks for the assistance; these
>>     mailing list are worth their weight in gold when it comes to
>> someone
>>     just starting out in a program such as myself. I started off using
>>     MS4W and GeoMoose and after an abundance of use, was authorized to
>>     move to a server. Due to funding issues Linux was the best route to
>>     go. So I am not only learning more about GeoMoose, I am learning
>>     linux as well. After some configuration and permission issues, I
>>     finally was able to get GeoMoose to display in a web browser using
>>     FGS9.5 on linux. I can pan, zoom-in, etc., however, when I search,
>>     identify, geocode, and print I get an error. Usually along the lines
>> of:
>>     *Deprecated*: Function split() is deprecated in
>>     */opt/geomoose2/htdocs/php/geocode.php* on line *22*
>>     by (output started at /opt/geomoose2/htdocs/php/geocode.php:22) in
>>     */opt/geomoose2/htdocs/php/geocode.php* on line *27*
>>     This particular error is specific to geocoding obviously, but they
>>     all contain the word deprecated and end in cannot modify header
>>     information. When I attempt to identify, select, buffer I get an
>>     unhandled request return Unknown error. I am stuck and any
>>     assistance would be greatly appreciated. Thanks in advance.
>>     v/r,
>>     Wes Cleland
>>_______________________________________________
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
