[Geomoose-users] Geocode and Identify Errors
Brent Fraser bfraser at geoanalytic.com
Wed May 26 11:03:09 EDT 2010
Wes,
   There could be a few reasons:
1. The layer is not searchable (it requires a TEMPLATE in the map file, or for
GM 2, an "identify_record" entry in the METADATA section of the map file.  And I
think the "identify_record" file must exist.
2. Coordinate system issues.  Is the map file PROJECTION and the LAYER
PROJECTION set properly?
Brent
Wes Cleland wrote:
> I installed firefox with firebug on my windows machine (this is the
> machine I have been testing the site with) and I believe I have isolated
> the error. On the right side it gives me OpenLayers.js line 1103, on the
> left is says
> GET http://gis-svr/geomoose2/php/identify.php?layers(and then it shows
> the layers and the shape I used to identify the
> point)&_moosetime=1274883453837
> no element found
> I am not good at this, but I believe it is telling me that even though
> it is searching through all the layers that are turned on, it is not
> finding something in particular it needs to show the files.
> If I take the original mapbook and create a shapefile from my postgis
> database named parcels.shp and replace the original parcels file, it
> gives me the error. It is only working with the original data.
> v/r,
> Wesley T. Cleland, GISP, CFM
> GIS Coordinator
> City of Van Buren, Arkansas
> 479-471-5025
> "One ought never to turn one's back on a threatened danger and try to
> run away from it. If you do that, you will double the danger. But if you
> meet it promptly and without flinching, you will reduce the danger by
> half. Never run away from anything. Never!"
> Winston Churchill
> -----Original Message-----
> From: bfraser at geoanalytic.com [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, May 25, 2010 11:28 AM
> To: Wes Cleland
> Subject: Re: [Geomoose-users] Geocode and Identify Errors
> looks ok.  is your web site accessible to the outside world?  Can you
> send me
> the URL?
> Wes Cleland wrote:
>> Brent,
>> <param name="mapfile_root">/opt/geomoose2/maps/</param>
>> <map-source name="parcels" type="mapserver"  reference="false">
>>     <file>./vanburen/landrecords/parcels_postgis.map</file>
>>     <layer name="parcels"/>
>>   </map-source>
>> METADATA
>> 	"identify_record"  "identify_parcel.html"
>>       "select_record"	"select_parcel.html"
>> 	"select_header" "select_header_parcels.html"
>> 	"popups" "parcels_popup.html"
>> 	"itemquery"	"parcels_itemquery.html"
>> 	qstring_validation_pattern '.'
>> 	# Feature reports are stored in the conf/feature_report
>> directory.
>> 	"feature_report" "parcel.xml"
>> END
>> v/r,
>> GIS Coordinator
>> 479-471-5025
> you
>> Winston Churchill
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> Date: Tue, 25 May 2010 09:25:16
>> To: Wes Cleland<wcleland at vanburencity.org>
>> Cc: <geomoose-users at lists.sourceforge.net>
>> Wes,
>>    Sounds like a file name, path(most likely), or permissions problem.
>> What does your mapfile_root and <map-source> for your data look like?
>> For
>> example, mine is:
>> <param name="mapfile_root">/MS4W30b11/apps/MyApp/maps/</param>
>> <map-source name="Basins" type="mapserver" default="false"
>> reference="false">
>>      <file>./Pathfinder/Basins.map</file>
>>      <layer name="Basins"/>
>> </map-source>
>> With the following in the Basins.map file:
>> METADATA
>>      'wms_title' 'Basins'
>>      "identify_record" "basins.html"
>> END
>> Where basins.html is in the same directory as the Basins.map file.
>> And the php.ini entry in the previous email was taken from the one
>> delivered
>> with MS4W's PHP so I'm assuming it's ok.
>> Best Regards,
>> Brent Fraser
>> Wes Cleland wrote:
>>> Brent,
>>> Here is where I stand after bashing my head into my computer screen
>>> yesterday. If I take the original mapbook.xml, and use the identify
>> tool
>>> with the original demo data, it works. If I change the settings.ini
>> file
>>> to read my new mapbook, I get the error. If I take the original
>> mapbook,
>>> and alter the coordinates then replace the original data with my
> data,
>>> it works. There is some configuration that is telling it to read the
>>> path /maps/demo/landrecords. I attempted to change the php5.ini file
>> and
>>> when I restart the server, it defaults to the original configuration
>> (I
>>> am assuming this is lack of experience). Also, I did not see the
> value
>>> 22519 in the link you provided. Thanks for the help!
>>> v/r,
>>> GIS Coordinator
>>> 479-471-5025
>> you
>>> Winston Churchill
>>> Date: Tue, 25 May 2010 08:17:15
>>> To: <wescleland at hotmail.com>
>>> Wes,
>>>    It looks like there's several ways to fix this, the easiest (and
>>> best?) being
>>> to set the error reporting level in the php.ini file to:
>>>      error_reporting = 22519 ;see values in
>>> http://ca2.php.net/manual/en/errorfunc.constants.php (all errors
> minus
>>> notices
>>> and deprecated)
>>> Best Regards,
>>> Brent Fraser
>>> wescleland at hotmail.com wrote:
>>>> I will look into this and see, I just copied the folders from the
>> ms4w
>>> folder so that could be missing something. The funny thing is, at the
>>> bottom of the errors, it has the print links and they work.
>>>> Sent on the Sprint(r) Now Network from my BlackBerry(r)
>>>> From: "Brent Fraser" <bfraser at geoanalytic.com>
>>>> Date: Fri, 21 May 2010 18:16:13
>>>> Wes,
>>>>   I was thinking of the FPDI PDF file "template" (the PDF files in
>>>> Geomoose/conf/print), not the Mapserver results HTML "template".  I
>>>> haven't done much with printing in GM 2, but its likely that there
>> are
>>>> some restrictions as to the version of PDF and kinds/arrangement of
>>>> elements inside the PDF templates.
>>>> Brent
>>>>> I am using a custom template that was created and implemented in
>> ms4w
>>>>> 2.3.1, there was no errors when using ms4w only when I switched to
>>>>> linux/FGS9.5. As well I am not at the office this moment, so I
> don't
>>> know
>>>>> the exact version of php, but I believe it is php5.3.something,
>>> whichever
>>>>> version is in the most current version of fgs9.5.
>>>>> Thanks for the help.
>>>>> Wes
>>>>> Date: Fri, 21 May 2010 16:05:44
>>>>> For the printing errors, it looks like its having problems with the
>>>>> template PDF
>>>>> file.  Is it the same as with the demo data or did you edit it?
>>>>> Which version of PHP are you using?
>>>>> Best Regards,
>>>>> Brent Fraser
>>>>> Wes Cleland wrote:
>>>>>> This is the error when attempting to print:
>>>>>> *Deprecated*: Assigning the return value of new by reference is
>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi.php* on line
>> *88*
>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi_pdf_parser.php*
>>> on
>>>>>> line *244*
>>>>>> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on
>>> line
>>>>>> *102*
>>> line
>>>>>> *285*
>>> line
>>>>>> *437*
>>>>>> *Warning*: Cannot modify header information - headers already sent
>>> by
>>>>>> (output started at /opt/geomoose2/htdocs/php/fpdi/fpdi.php:88) in
>>>>>> */opt/geomoose2/htdocs/php/print.php* on line *136*
>>>>>> The identify error is this:
>>>>>> As previously stated, I can load the default mapbook.xml with the
>>> demo
>>>>>> data and the identify/select/buffer/search works fine, but when I
>>> load
>>>>>> the mapbook created with my data it gives me these errors. I even
>>> went
>>>>>> as far as rebuilding the mapbook ensuring that every little word
>> was
>>>>>> typed correctly/etc.
>>>>>> v/r,
>>>>>> GIS Coordinator
>>>>>> 479-471-5025
>>> to
>> if
>>> you
>>> by
>>>>>> Winston Churchill
>>>>>> *From:* danlittle at yahoo.com [mailto:danlittle at yahoo.com]
>>>>>> *Sent:* Friday, May 21, 2010 8:21 AM
>>>>>> *To:* wcleland at vanburencity.org
>>>>>> *Subject:* Re: [Geomoose-users] Geocode and Identify Errors
>>>>>> I'd suggest two things:
>>>>>> 1) File a bug in Trac.
>>>>>> 2) Edit both geocode.php and identify.php files and replace
> "split"
>>> with
>>>>>> "explode".  PHP does obnoxiously stupid things with strings and
>>> string
>>>>>> functions.
>>>>>>     *From:* Wes Cleland <wcleland at vanburencity.org>
>>>>>>     *To:* geomoose-users at lists.sourceforge.net
>>>>>>     *Sent:* Thu, May 20, 2010 4:04:06 PM
>>>>>>     *Subject:* [Geomoose-users] Geocode and Identify Errors
>>>>>>     First off, I would like to say thanks for the assistance;
> these
>>>>>>     mailing list are worth their weight in gold when it comes to
>>>>>> someone
>>>>>>     just starting out in a program such as myself. I started off
>>> using
>>>>>>     MS4W and GeoMoose and after an abundance of use, was
> authorized
>>> to
>>>>>>     move to a server. Due to funding issues Linux was the best
>> route
>>> to
>>>>>>     go. So I am not only learning more about GeoMoose, I am
>> learning
>>>>>>     linux as well. After some configuration and permission issues,
>> I
>>>>>>     finally was able to get GeoMoose to display in a web browser
>>> using
>>>>>>     FGS9.5 on linux. I can pan, zoom-in, etc., however, when I
>>> search,
>>>>>>     identify, geocode, and print I get an error. Usually along the
>>> lines
>>>>>> of:
>>>>>>     *Deprecated*: Function split() is deprecated in
>>>>>>     */opt/geomoose2/htdocs/php/geocode.php* on line *22*
>>> sent
>>>>>>     by (output started at
> /opt/geomoose2/htdocs/php/geocode.php:22)
>>> in
>>>>>>     */opt/geomoose2/htdocs/php/geocode.php* on line *27*
>>>>>>     This particular error is specific to geocoding obviously, but
>>> they
>>>>>>     all contain the word deprecated and end in cannot modify
> header
>>>>>>     information. When I attempt to identify, select, buffer I get
>> an
>>>>>>     unhandled request return Unknown error. I am stuck and any
>>>>>>     assistance would be greatly appreciated. Thanks in advance.
>>>>>>     v/r,
>>>>>>     Wes Cleland
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.sourceforge.net
>>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
