[Geomoose-users] Scalebar & Measure
Dan Little danlittle at yahoo.com
Thu May 27 11:45:40 EDT 2010
Probably just make it the default setting inside of the tools.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Len Kne <lkne at houstoneng.com>
> Cc: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Thu, May 27, 2010 10:02:01 AM
> Subject: Re: [Geomoose-users] Scalebar & Measure
> Good.
   Should we just hard-code it within Geomoose (as below), or
> provide a
configuration parameter in the mapbook?
Brent
Len
> Kne wrote:
> Very nice!  Worked great and is much simpler than the
> way I was doing the calculation.
> Len
> -----Original Message-----
> From: Brent Fraser [mailto:
> ymailto="mailto:bfraser at geoanalytic.com"
> href="mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com]
> Sent: Wednesday, May 26, 2010 1:53 PM
> To: Len Kne
> Cc: '
> ymailto="mailto:geomoose-users at lists.sourceforge.net"
> href="mailto:geomoose-users at lists.sourceforge.net">geomoose-users at lists.sourceforge.net'
> Len(and
> others interested in measuring),
>    Here's my
> solution to the measure problem:
> In main.js somewhere around
> line 138 add the two lines below marked with a "//BWF":
>     Tools['measure'] = new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePath,
> measureToolOptions);
>     Tools['measure'].geodesic =
> true;  //BWF
>     Tools['measurearea'] = new
> OpenLayers.Control.GeoMooseMeasure(OpenLayers.Handler.MeasurePolygon,
> Tools['measurearea'].geodesic = true;  //BWF
> Thoughts?
> Brent
> Brent Fraser
> wrote:
>> Paul, Len,
>>    Our scale
> problem is a (mostly) map projection issue.  All map projections
>> introduce distortions in trying to represent a round(ish) Earth on
> a flat plane.
>>   Mercator is no different: it is like wrapping
> an up-right cylinder around the
>> Earth, projecting light from the
> center onto the cylinder
> (http://en.wikipedia.org/wiki/Mercator_projection).  As you can imagine the
>> distortions get "worse" the further from the equator.   The
> distortions can be
>> modeled as a Point Scale Factor.  At the
> equator the Point Scale Factor is 1.0,
>> at latitude 60 degrees North
> (or South), the scale factor is 0.5!
>>    So
> what's the solution?  Here's mine:
>>    1.
> Enhance Proj4 (and Proj4js) to return the Point Scale factor (given the
>> projection and a location)
>>    2. Enhance
> MapServer and Openlayers to use the Point Scale Factor in
> calculating distances and scale.
>> I'm trying to drum up
> interest, but so no takers....
> http://osgeo-org.1803224.n2.nabble.com/Point-Scale-factor-service-td4938743.html
> http://osgeo-org.1803224.n2.nabble.com/Re-3265-Scale-dependent-layer-switching-error-with-Mercator-td4966902.html
> Best Regards,
>> Brent Fraser
>> Len Kne
> wrote:
>>> The scale bar issue with the web Mercator projection is a
> limitation of
>>> OpenLayers, the application GeoMOOSE 2.x uses to
> render the map frame.
>>>   There has been discussion on the
> OpenLayers site about providing a
>>> patch (this link offers a
> patch http://trac.openlayers.org/ticket/1890 )
>>> in the next
> version 2.9.  I'm sure GM will upgrade to OL 2.9, but not
> sure there is any schedule in place to do
> this.
>>> The
> cursor issue is also kind of fun because it seems each browser
> handles the custom icons differently.  Here's the attribute in the
>>> mapbook which defines the query for the Identify
> service:
> cursor="url('cursors/identify2.cur') 9
> 9,url('cursors/identify2.cur'),auto"
>>> This makes three attempts to draw the cursor,
> the first offsets the
>>> mouse click 9 pixels from the top and the
> left.  Firefox can use this
>>> value and seems to line the
> mouse click up pretty good with the
>>> crosshair.  However,
> IE cannot handle the offset adjustment, so it reads
>>> the second
> cursor definition.  There are tools like AT File Mole which
>>> can be used to edit the hotspot of a cursor.  Attached is
> the latest
>>> version I have been using for Identify service,
> again this seems to line
>>> the crosshair up pretty well with the
> mouse click.  If you are using
>>> Safari or Chrome, these
> setting don't seem to work at all and I would
>>> recommend not
> using customer cursors with those
> browsers.
> Len
> *From:* Wirth, Paul [mailto:
> href="mailto:Paul.Wirth at kniferiver.com">Paul.Wirth at kniferiver.com]
> *Sent:* Saturday, May 01, 2010 9:03 PM
>>> *To:* '
> *Subject:* [Geomoose-users] Scalebar &
> Measure
> Two questions:
>>> 1.       I have a web Mercator
> application, and I noticed that the
>>> scalebar does not display
> the correct distance.  For instance, when the
>>> scalebar
> shows a distance of 20 miles, it measures only 13.8 miles.  I
>>> know the measure tools are working correctly, so I assume this
> is a
>>> scalebar issue.  Any thoughts on how to fix
> this?
>>> 2.       I think this
> question was asked before, but I can't seem to
>>> find it on the
> e-mail list.  With the measure tools, the cursor does not
> start measuring at the "crosshairs" when the user clicks, but rather in
>>> the NW quadrant of the crosshairs.  Is there a way to
> change it so the
>>> measure start point will be on the
> crosshairs?
>>> Geomoose-users
> mailing list
> ymailto="mailto:Geomoose-users at lists.sourceforge.net"
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
> target=_blank
> >https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> Geomoose-users
> mailing list
> target=_blank
Geomoose-users
> mailing list
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
More information about the Geomoose-users mailing list
