[Geomoose-users] fastcgi vs cgi
Dan Little danlittle at yahoo.com
Mon Nov 1 13:01:55 EDT 2010
GeoMOOSE can use pretty much anything that serves up a WMS.  Of course, FastCGI
is really only a way of optimizing MapServer's performance.  Most of GeoMOOSE is
static HTML/JS/Images that won't see any benefit from FastCGI and I would not
advise putting the PHP into FastCGI as PHP is already run as an Apache module.
You could set certain layers up as FastCGI, there is no limitation in GeoMOOSE.
 The only limitation is what you have the time/patience to configure.
>From: "Reynolds, Michael J. (DOT)" <Mike.Reynolds at state.mn.us>
>To: "geomoose-users at lists.sourceforge.net"
><geomoose-users at lists.sourceforge.net>
>Sent: Mon, November 1, 2010 10:58:15 AM
>Subject: [Geomoose-users]  fastcgi vs cgi
>Any comments about geomoose and fastcgi?
>It would seem to be that if fastcgi is configured correctly that geomoose could
>be configured to use it.  Once configured, ALL geomoose layers will be rendered
>using fastcgi.  Is there a way to set just certain layers to use it?  Is that
>necessary?
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101101/ef42d96e/attachment.html
More information about the Geomoose-users mailing list
