[Geomoose-users] Hide Layer
aborruso aborruso at gmail.com
Thu Nov 4 04:49:22 EDT 2010
Hi Len,
thank you very much.
Len Kne wrote:
> If you are using GeoMOOSE 2.x, you can set a map-source to always be
> visible.  For example:
> <map-source name="basemap" type="mapserver" visible="true" >
I have inserted this string in my mapbook:
    <map-source name="sfondo" type="mapserver" visible="true">
        <file>./vv/irvv_02.map</file>
        <layer name="Sfondo"/>
    </map-source>
The problem is that the layer I have in my map-source does not appear in my
map.
It appears if I add it in my layer-controls, but in this way it appears also
in my catalog tree and I can swith-on and swith-off it.
I would like to have it only as background, and I would not have visible it
in catalog tree.
Is it possible?
Thank you very much Len
View this message in context: http://geomoose-users.964460.n3.nabble.com/Hide-Layer-tp1836540p1840139.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users mailing list
