[Geomoose-users] Feature report
Len Kne lkne at houstoneng.com
Wed Nov 24 08:19:29 EST 2010
A couple things to look at depending on how the layer is being delivered.
If it is a MapServer layer from your server, make sure that MAXSIZE 10000 is in the MAP file or that you are including geomoose_globals.map.  Also, make sure that "server_name" is set properly in conf/settings.ini.  If the web server is not on port 80, you will need to include the port number with this server name (i.e. localhost:8080).
If it is a WMS layer, the provider may limit the size of the image returned and you may need to reduce the resolution or size of the map image.
Len
Sent: Tuesday, November 23, 2010 2:15 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Feature report
I am using version 2.2 and am having 2 issues.
  1.  I am having a hard time getting an aerial photo to show up in the feature report.  Is this possible without too much trouble?
  2.  Also, when using the print service I can get the fsa photo that came with the demo to work but when I add the counties photo it does not show up.  Any Ideas?
            <service name="feature_report" display="false">
                        <url>php/feature_report.php</url>
                        <input type="hidden" name="layers" value="lmic/fsa2008"/>
                        <input type="hidden" name="src"/>
                        <input type="hidden" name="TPPRCL"/>
            </service>
Jacob Rodel
GIS Technician
Todd County GIS & Land Services Dept.
347 Central Ave. Suite 1
Long Prairie, MN 56347
(320) 732-4248
More information about the Geomoose-users mailing list
