[Geomoose-users] Search Results zoom to, highlight etc not functioning
Sean Ziniker Sean.Ziniker at co.jefferson.or.us
Thu Sep 23 17:38:14 EDT 2010
When I do a taxlot search there are several services for each result;
"Zoom to taxlot", "Buffer taxlot", "Highlight taxlot" etc.  I can not
get any of these services to work correctly.  The zoom to function zooms
to the wrong location and usually the same every time and the buffer and
highlight functions are unresponsive.  I have modified my mapbook to
reflect my mapfiles, layer names and attribute value for the select
services as well as my select_taxlot.html.
Below I have added what I believe are the relevant service code in my
map book and the html:
Mapbook.xml code:
<service name="identify" title="Identify" display="false">
                        <url>php/identify.php</url>
                        <step type="spatial" name="shape"
show-tools="false" line="false" polygon="false" jump-start="true"
default="point">
                                    <input type="visiblelayers"
name="layers"/>
                        </step>
            </service>
            <service name="dualmaps" display="false" target="_blank"
title="Birdseye">
                        <url>php/dualmaps.php</url>
                        <step type="spatial" name="xy"
show-tools="false" box="false" pan="false" line="false" polygon="false"
jump-start="true" default="point" format="delim" reproject="EPSG:4326">
                        </step>
            </service>
            <service name="dynamicZoomTo">
                        <url>php/dynamicSelect.php</url>
                        <step type="input">
                                    <input type="ajax_select"
name="qstring" title="Zoom To"></input>
                                    <input type="hidden_object"
name="layer" title="layer"></input>
name="qitem" title="qitem"></input>
                                    <input type="hidden"
name="mode">map</input>
                        </step>
            </service>
            <service name="print" title="Print">
                        <step type="input">
                                    <url>php/print.php</url>
                                    <input type="print_info"
name="layers"/>
                                    <input type="extent" name="extent"/>
                                    <input type="sketches"
name="sketches"/>
                                    <input type="vector" name="vector"/>
                                    <input type="user" name="title"
title="Map Title">Map</input>
                                    <input type="hidden" name="date"
title="Map Date">true</input>
                                    <input type="select" name="template"
title="Output Template: ">
                                                <option
value="letter_landscape">Letter - Landscape</option>
                                                <option
value="letter_portrait">Letter - Portrait</option>
                                                <option
value="poster_landscape">11" x 17" - Landscape</option>
                                                <option
value="poster_portrait">11" x 17" - Portrait</option>
                                    </input>
                                    <input type="select" name="quality"
title="Image Quality: ">
                                                <option
value="2">Higher</option>
                                                <option
value="3">Highest</option>
                                                <option
value="1">Standard</option>
                                    </input>
                                    <input type="hidden" name="scale"
title="Preserve Scale: " value="no" />
                        </step>
            </service>
            <service name="select" title="Select">
                        <url>extensions/select_custom.php</url>
                        <!-- Send a selection shape + the visible layers
list to the service -->
                        <step type="spatial" showTools='true'
name="shape" line="true" polygon="true" point="true" default="polygon"
edit-polygon="false" pan="false">
                                    <header><![CDATA[Create a selection
area by clicking on the map.]]></header>
name="layers"/>
                                    <input type="hidden" name="id"
value="ACCOUNT_ID" />
                                                Option values should be
the mapbook path to the layer.
                                                This only supports
'mapserver'-type layers.
name="select_layer" title="Select:">
                                                <option
value="assessormap/Taxlots">Taxlots</option>
                                                <option
value="survey/surveywebi">Surveys</option>
                                    </input>
                                    <input type="user"
name="shape_buffer" title="Buffer Selection Shape (ft)">0</input>
name="query_layer" title="Using Features In">
                                                <option
                                                <option
                                    </input>
                                    <input type="user"
                                    <footnote><![CDATA[
                                    ]]></footnote>
                        </step>
            </service>
            <service name="mailing_labels" display="false"
target="_blank" title="Print Mailing Labels">
                        <url>php/mailing_labels_custom.php</url>
                        <step type="input">
                                    <input type="hidden" name="qstring"
                                    <input type="hidden" name="output"
value="csv" />
                                    <input type="hidden" name="qitem"
                                    <input type="hidden" name="qlayers"
value="assessormap/Taxlots" />
                        </step>
            </service>
            <service name="select_parcel" title="Select Taxlots"
display="true" >
name="shape" line="true" polygon="true" point="true" default="point"
edit-polygon="false" pan="false" jump-start="true" >
name="shape_is_object" value="false" />
                                    <header><![CDATA[Select a taxlot by
drawing a selection shape on the map.]]></header>
name="layers"/>
                                                This only supports
name="select_layer" title="Select:" value="assessormap/Taxlots" />
                                    <input type="user"
                                                <option
                                                <option
                                    </input>
name="shape_buffer" title="Buffer Selection Shape (ft)" value="0" />
                                    <footnote><![CDATA[
                                    ]]></footnote>
                        </step>
            </service>
            <!-- this is called after a standard select in order to
buffer the previous selection -->
            <service name="buffered_select_followup" title="Buffer
Taxlot">
                        <step type="input">
                                    <input type="hidden" name="shape"/>
name="shape_is_object"/>
<!--                               <input type="hidden"
name="query_layer"/> -->
name="select_layer" title="Using Features In">
                                                <option
                                                <option
                                    </input>
name="shape_buffer" title="Buffer Features By: "/> -->
                                    <input type="user"
name="shape_buffer" title="Buffer Features By (ft): "/>
                        </step>
            </service>
<service name="select_historic_taxlot" title="">
list to the service-->
                        <step type="input">
name="select_layer" value="historic_taxmap/PolkTaxlots" />
value="TAXLOTC1" />
name="shape_buffer">-1</input>
                                    <input type="hidden" name="shape" />
                                    <input type="hidden" name="parcel"
                        </step>
            </service>
            <service name="template_test_report" title="Template Test"
display="false">
                        <step type="input">
name="layers"/>
name="sketches"/>
                                    <input type="hidden" name="mode"
value="template_test_report"/>
                                    <input type="hidden" name="padding"
value="50"/>
                                    <input type="hidden" name="src"
                                    <input type="hidden" name="TAXLOT"/>
                                    <input type="hidden" name="title"
                                    <input type="hidden" name="template"
title="Output Template: " value="template_test"/>
                                    <input type="hidden" name="quality"
title="Image Quality: " value="Higher"/>
title="Preserve Scale: " value="Yes"/>
                        </step>
            </service>
            <service name="geocode_address" title="Geocode Address">
                        <url>php/geocode.php</url>
                        <step type="input">
                                    <header><![CDATA[
                                                This tool searches
Google's geocoder.  Search strings can be an address (e.g. 1060 W.
Addison Street, Chicago), a landmark (e.g. Empire State Building) or
intersection (e.g. Hennepin and Lake, Minneapolis).
                                    ]]></header>
                                    <input type="user" name="address"
title="Enter Address: "/>
name="googlekey"
value="ABQIAAAAQIpq5I8azu0hKAMlTu1zmxReCrxMK0wjSlowlOuMeIzwrJkJ8BQ-fBmqC
n24aFFeybJLxf_WNIPi1Q"/>
                                    <input type='hidden' name='map_proj'
value='+proj=utm +zone=14 +ellps=GRS80 +datum=NAD83 +units=m +no_defs'
                        </step>
            </service>
            <service name="search_parcels" title="Search Taxlots">
                        <url>extensions/query_custom.php</url>
                        <step type="input">
name="highlight" value="true"/>
value="search"/>
                                    <input type="hidden" name="layer0"
value="assessormap/Taxlots"/>
name="template0" value="itemquery"/>
name="fieldname0" title="Search By:">
                                                <option
value="ACCOUNT_ID">Account Number</option>
                                                <option
value="MAPNUM">Map</option>
                                                <option
value="TAXLOT">Taxlot</option>
                                                <option
value="MAPTAXLOT">Map and Taxlot</option>
                                                <option
value="OWNER">Owner</option>
                                                <option
value="AGENT">Agent</option>
                                                <option
value="M_ADDRESS">Mailing Add</option>
                                                <option
value="HOUSE_NUMB">Primary Situs</option>
                                    </input>
name="comparitor0" title="That: ">
                                                <option
value="like-icase">Contains</option>
                                                <option
value="right-like-icase">Begins With</option>
                                                <option
value="eq-str">Matches Exactly</option>
                                    </input>
                                    <input type="user" name="value0"
title=""/>
                        </step>
            </service>
            <service name="search_parcels_url">
                        <step type="input">
value="search"/>
                                    <input type="user" name="fieldname0"
                                    <input type="user"
name="comparitor0" value="like-icase" />
title=""/>
                                    <input type="user" name="operator1"
value="and" />
                                    <input type="user" name="fieldname1"
value="" />
                                    <input type="user"
name="comparitor1" value="like-icase" />
                                    <input type="user" name="value1"
title=""/>
                                    <input type="user" name="operator2"
value="and" />
                                    <input type="user" name="fieldname2"
value="" />
                                    <input type="user"
name="comparitor2" value="like-icase" />
                                    <input type="user" name="value2"
title=""/>
                        </step>
            </service>
            <service name="search_parcels_by_account">
                        <step type="input">
value="search"/>
                                    <input type="user"
name="comparitor0" value="eq" />
title=""/>
value="or" />
                                    <input type="user"
name="comparitor1" value="eq" />
title=""/>
value="or" />
                                    <input type="user"
name="comparitor2" value="eq" />
title=""/>
                                    <input type="user" name="operator3"
value="or" />
                                    <input type="user" name="fieldname3"
                                    <input type="user"
name="comparitor3" value="eq" />
                                    <input type="user" name="value3"
title=""/>
                                    <input type="user" name="operator4"
value="or" />
                                    <input type="user" name="fieldname4"
                                    <input type="user"
name="comparitor4" value="eq" />
                                    <input type="user" name="value4"
title=""/>
                                    <input type="user" name="operator5"
value="or" />
                                    <input type="user" name="fieldname5"
                                    <input type="user"
name="comparitor5" value="eq" />
                                    <input type="user" name="value5"
title=""/>
                                    <input type="user" name="operator6"
value="or" />
                                    <input type="user" name="fieldname6"
                                    <input type="user"
name="comparitor6" value="eq" />
                                    <input type="user" name="value6"
title=""/>
                                    <input type="user" name="operator7"
value="or" />
                                    <input type="user" name="fieldname7"
                                    <input type="user"
name="comparitor7" value="eq" />
                                    <input type="user" name="value7"
title=""/>
                                    <input type="user" name="operator8"
value="or" />
                                    <input type="user" name="fieldname8"
                                    <input type="user"
name="comparitor8" value="eq" />
                                    <input type="user" name="value8"
title=""/>
                                    <input type="user" name="operator9"
value="or" />
                                    <input type="user" name="fieldname9"
                                    <input type="user"
name="comparitor9" value="eq" />
                                    <input type="user" name="value9"
title=""/>
                                    <input type="user" name="operator10"
value="or" />
                                    <input type="user"
name="fieldname10" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor10" value="eq" />
                                    <input type="user" name="value10"
title=""/>
                                    <input type="user" name="operator11"
value="or" />
                                    <input type="user"
name="fieldname11" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor11" value="eq" />
                                    <input type="user" name="value11"
title=""/>
                                    <input type="user" name="operator12"
value="or" />
                                    <input type="user"
name="fieldname12" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor12" value="eq" />
                                    <input type="user" name="value12"
title=""/>
                                    <input type="user" name="operator13"
value="or" />
                                    <input type="user"
name="fieldname13" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor13" value="eq" />
                                    <input type="user" name="value13"
title=""/>
                                    <input type="user" name="operator14"
value="or" />
                                    <input type="user"
name="fieldname14" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor14" value="eq" />
                                    <input type="user" name="value14"
title=""/>
                                    <input type="user" name="operator15"
value="or" />
                                    <input type="user"
name="fieldname15" value="ACCOUNT_ID" />
                                    <input type="user"
name="comparitor15" value="eq" />
                                    <input type="user" name="value15"
title=""/>
                        </step>
            </service>
Select_taxlots.html code:
<!-- MapServer Template -->
<div id="div_[ACCOUNT_ID]">
<table border="0" cellpadding="1" cellspacing="2">
<tr><td colspan="2"><hr/></td></tr>
            <tr>
                        <td colspan=2
style="background-color:#DDDDDD;padding-left:4px;">
                                                <img
src='images/toolbar/zoomin.png' class='noborder' title='Zoom to taxlot'
alt='Zoom to taxlot'
onclick='highlight.zoomToExtent(highlight.getBounds("[ACCOUNT_ID]"));'
                                                <img
src='images/toolbar/select.png' class='noborder' alt='Buffer taxlot'
title='Buffer taxlot'
onclick='GeoMOOSE.startService("buffered_select_followup", {shape:
highlight.getShape("[ACCOUNT_ID]"),"shape_is_object":"false"})'/>
                                                <img
src='skins/polkcounty/images/services.png' class='noborder'
title='Highlight taxlot' alt='Highlight taxlot'
onclick='highlight.turnRed("[ACCOUNT_ID]");'/>
                                                <img
src='images/toolbar/clear.png' title='Remove from selection' alt='Remove
from selection'
onclick='removeFeature("[ACCOUNT_ID]");removeElement(document.getElement
ById("div_[ACCOUNT_ID]"));highlight.updateNumShapes();' />
                                                <img
src='images/toolbar/layout-edit.png' title='Template test' alt='Template
test' onclick='javascript:polkTemplate.renderHtml({shape:
highlight.getShape("[ACCOUNT_ID]")},"[ACCOUNT_ID]")' />
                        </td>
            </tr>
<tr>
<td align="right"><b>Account Number:</b></td>
<td>[ACCOUNT_ID]</td>
</tr>
<tr>
<td align="right"><b>Map Number:</b></td>
<td>[MAPNUM]</td>
</tr>
<tr>
<td align="right"><b>TaxLot:</b></td>
<td>[TAXLOT]</td>
</tr>
<tr>
<td align="right"><b>Map Taxlot:</b></td>
<td>[MAPTAXLOT]</td>
</tr>
<tr>
<td align="right"><b>Owner:</b></td>
<td>[OWNER]</td>
</tr>
<tr>
<td align="right"><b>Agent:</b></td>
<td>[AGENT]</td>
</tr>
<tr>
<td align="right"><b>Mailing Add:</b></td>
<td>[M_ADDRESS]</td>
</tr>
<tr>
<td align="right"><b>City:</b></td>
<td>[M_CITY]</td>
</tr>
<tr>
<td align="right"><b>St:</b></td>
<td>[M_STATE]</td>
</tr>
<tr>
<td align="right"><b>ZIP:</b></td>
<td>[M_ZIP]</td>
</tr>
<tr>
<td align="right"><b>Primary Situs:</b></td>
<td>[HOUSE_NUMB] [PRE_DIRECT] [STREET_NAM] [STREET_TYP] [DIRECTION]
[UNIT_NUMBE]</td>
</tr>
<tr>
<td align="right"><b>City/State/Zip:</b></td>
<td>[CITY] [STATE] [ZIP]</td>
</tr>
<tr>
<td align="right"><b>Acre:</b></td>
<td>[ACRES]</td>
<tr>
<td align="right"><b>Zoning:</b></td>
<td>[PLAN_ZONE]</td>
</tr>
</tr>
</table>
</div>
Thanks,
Sean
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100923/d837eae9/attachment.html
More information about the Geomoose-users mailing list
