[Geomoose-users] Print Function Error
Len Kne
lkne at houstoneng.com
Wed Sep 29 13:38:37 EDT 2010
I'd try to troubleshoot the issue with Firefox first using Firebug. Look to see what the post and response are for the call to print.php, there should be some clues there. Also, check that "server_name" is set correctly in conf/settings.ini. If this is on a server, the server_name needs to be a name (or IP address) that the server sees itself as - this gets a little tricky with a firewall (Network Address Translation) and servers with multiple web sites. If it is on a local machine, the server_name is usually localhost, but you could try the computer name or IP address. Also, if your website is not on port 80, you will need to include the port in the server name (i.e. localhost:8080).
Len
From: Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent: Wednesday, September 29, 2010 12:23 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Print Function Error
I am having a problem when I go to print my map. When I click on the "Download PDF" in Google Chrome it saves it as a .php file instead of a .pdf. Also when I use Firefox it doesn't display the links at all. On a side note I can't get my map to display at all on IE, but most everything works fine on Chrome and Firefox. Any suggestions would be greatly appreciated.
Thanks,
Sean
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100929/03eebbf7/attachment.html
More information about the Geomoose-users
