[Geomoose-users] Regular Expression error on Search
geo3d geomatrix3d at gmail.com
Mon Aug 1 11:07:57 EDT 2011
I have a repeated error as identified in Firebug whenever I do a search that
contains a space - ie., a search on address /"254"/ - search results fine
but when i do a combined search such as /"254 Walker"/ the following error
persists:
"/loadForm(): Web application error. Parameter 'id' value fails to validate.
msEvalRegex(): Regular expression error. String failed expression test. /"
My search parameters as per my itemquery.php:
LAYER # Parcels Polygon Layer
  	    NAME 'ParcelsAddressSearch'
  	    DATA 'landrecords/parcels.shp'
  	    STATUS DEFAULT
  	    TYPE POLYGON
  	    TEMPLATE 'landrecords/itemquery_parcels.html'
  	    FILTERITEM 'STREET_2'
  	    FILTER /.*%id%.*/i #non case sesensitve contains regular expression
  END
So, anyone know the expression to include space?
View this message in context: http://geomoose-users.964460.n3.nabble.com/Regular-Expression-error-on-Search-tp3216194p3216194.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users mailing list
