[Geomoose-users] Identify Feture not working on layers
Dan Little danlittle at yahoo.com
Thu Aug 11 11:15:13 EDT 2011
I'm thinking you'll need to specify the projection in the layer entry.
LAYER
 PROJECTION
   'init=esri:102743'
 END
END
>________________________________
>From: Clinton Olsen <clinton at co.emery.ut.us>
>To: 'Dan Little' <danlittle at yahoo.com>; 'Brian Fischer' <bfischer at houstoneng.com>; geomoose-users at lists.sourceforge.net
>Sent: Thursday, August 11, 2011 9:58 AM
>Subject: RE: [Geomoose-users] Identify Feture not working on layers
>Message
>Dan Little,
>Here are the contents of the identify tool using firebug and firefox.I hope this is what you wanted to look at.
><results><script/><html><![CDATA[<!-- MapServer Template --> Detailed information for the area you clicked on the map... <table border="0"> <tr> <td colspan="2"><b><u>Ground Coordinates</u></b> <br> <b>X: </b>1751465 <br> <b>Y: </b>6901114.5</td> </tr> <tr> <td>&nbsp;</td> <td>&nbsp;</td> </tr> </table> <table border="0" cellpadding="1" cellspacing="2"> <!-- MapServer Template --> <tr> <td colspan="2">Disclaimer: This information is being distributed as demonstation data only.  You shouldnot use the data for any other purposes.</td> </tr> </table> ]]></html></results>
>Brian Fischer,
>The projection in my mapbook.xml is EPSG:2281.  The ESRI projection I am using for the shape files is ESRI:102743.
>Not sure what the EPSG equivalent is for that ESRI projection.  Maybe that is why when I use the print feature it only prints a blank page.
>-----Original Message-----
>>From: Dan Little  [mailto:danlittle at yahoo.com]
>>Sent: Wednesday, August 10, 2011 7:43  PM
>>To: neslonotnilc;  geomoose-users at lists.sourceforge.net
>>Subject: Re: [Geomoose-users]  Identify Feture not working on layers
>>Do you happen to have Firefox with Firebug installed?
>>I'd like to see the actual contents being sent back.  I'm not  100% sure what's going wrong yet...
>>> From: neslonotnilc  <clinton at co.emery.ut.us>
>>>To: geomoose-users at lists.sourceforge.net
>>>Sent: Wednesday, August 10, 2011 2:45  PM
>>>Subject: [Geomoose-users] Identify Feture not working on  layers
>>>Hi,
>>>I am doing an upgrade from a 1.x geomoose
    install.  I have my esri layers
>>>showing up in geomoose, but when I
    try to do an identify on the layers I
>>>only return the default X and Y
    coordinate template.  I have looked through
>>>the wiki, the online
    forum, and online searches and tried to make my data
>>>fit with what is
    presented but I still can't get identify to work.  Also a
>>>wierd
    thing that happens when I try to do a identify I get 1kb PNG files
>>>that
    populate the folder that contains the layer mapbook file.  Please
    point
>>>me in the right direction.  The identify tool is great for
    what we are
>>>trying to do with Geomoose, but if it is temperamental then
    maybe I should
>>>stick with the working 1.x install.  Only problem
    with that is some of the
>>>features don't work in the newer browsers.
    Thanks.  Clinton
>>>This is what I have in the mapbook.xml
    file:
>>><service name="identify" title="Identify"
    display="false">
>>><url>php/identify.php</url>
>>><step
    type="spatial" name="shape" line="false"
    polygon="false"
>>>jump-start="true" default="point">
>>><input
    type="visiblelayers"
    name="layers"/>
>>></step>
>>></service>
>>>__________
>>><tool
    name="identify" title="Identify" type="service"
    service="identify"/>
>>>__________
>>>In the layer mapbook I
    have:
>>>LAYER
>>>NAME
        "PRECINCTS"
    DATA
    "./PRECINCTS.shp"
>>>    STATUS
        DEFAULT
>>>    TYPE
            POLYGON
    TOLERANCE        3
    CLASSITEM        "NAME"
    LABELITEM        "NAME"
>>>    CLASS
        EXPRESSION 'Orangeville #5.09'
        NAME    'Orangeville
    #5.09'
    STYLE
        COLOR 255 102 0
            OUTLINECOLOR 0 0
    255
        SIZE 2
        END
    LABEL
        TYPE TRUETYPE
              FONT
    vera_sans-bold
            SIZE 8
                  ANTIALIAS
    true
        COLOR 153 0 153
                OUTLINECOLOR 254 254
    254
        BUFFER 3
              MINFEATURESIZE
    auto
        PARTIALS FALSE
              POSITION ul
              END
    END
>>>METADATA
    'identify_record'
    'identify_precincts.html'
>>>END
>>>END
>>>View this
    message in context: http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-layers-tp3243706p3243706.html
>>>Sent
    from the Geomoose-users mailing list archive at
    Nabble.com.
>>>uberSVN's
    rich system and user administration capabilities and model
>>>configuration
    take the hassle out of deploying and managing Subversion and
>>>the tools
    developers use with it. Learn more about uberSVN and get a free
>>>download
    at:  http://p.sf.net/sfu/wandisco-dev2dev
>>>_______________________________________________
>>>Geomoose-users
>>>Geomoose-users at lists.sourceforge.net
>>>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110811/bd4264bc/attachment.html
More information about the Geomoose-users mailing list
