[Geomoose-users] Problem trying to get the Identify tool to work
Ed Boesenberg, III eboesenberg at niraengineers.com
Wed Aug 17 13:33:27 EDT 2011
I am using GM 2.4 and MS4W 2.3.1.  When I try and use the identify tool I
get the following error within the information tab: "Fatal error: Call to
undefined function ms_shapeObjFromWkt() in
D:\ms4w\apps\geomoose2\htdocs\php\identify.php on line 83".  May map file
has the following code:
                                METADATA
                                                'identify_record'
'identify_ftma_waterlines.html'
                                                'qstring_validation_pattern'
                                END
I also created 'identify_ftma_waterlines.html', which has the following
code:
<tr>
<td colspan="2"><b>FTMA Waterlines:</b></td>
</tr>
<tr>
<td align="right">As-built PDF:</td>
<td>[AB_PDF]</td>
</tr>
<tr><td colspan="2"><hr></td></tr>
Thanks,
Ed Boesenberg, III
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110817/4c79cce6/attachment.html
More information about the Geomoose-users mailing list
