[Geomoose-users] error occur while trying to make a search function using itemquery.php
Brent Fraser bfraser at geoanalytic.com
Thu Aug 25 22:16:08 EDT 2011
Which version of mapserver are you using?  getFeature() was removed in v6.0.
Best Regards,
Brent Fraser
On 8/25/2011 8:00 PM, zye wrote:
> Hello,
> Right now i'm trying to make a search using itemquery.php. I use GM 2.4 and
> mapserver version 3.0.3. Can you guys give me a solution for this matter?
> Why i got this error?
> Fatal error: Call to undefined method layerObj::getFeature() in
> C:\ms4w\apps\geomoose2\htdocs\php\itemquery.php on line 106
> Here my *mapbook.xml:*
> <?xml version="1.0"?>
> <mapbook version="2.0">
> 	<configuration>
> 		EPSG:3377
> 		-120311.3508, -93138.3527, 220252.0581, 96147.8017
> 		-173234.0000, -90583.0000, 161701.0000 , 91811.0000
> 		false
> 		/cgi-bin/mapserv.exe
> 		/ms4w/apps/geomoose2/maps/
> 		false
> 		false
> 		true
> 		red
> 		yellow
> 		1
> 		false
> 		Catalog
> 		Catalog
> 		Information
> 		Information
> 		m
> 		.5,1,4,8,16,24,32,64,128,270,550,1000
> 		false
> 		false
> 	</configuration>
>      <map-source name="jalanpontian" type="mapserver" reference="true">
> 		<file>./demo/data/jalanpontian.map</file>
> 		<layer name="all" reference="true"/>
> 	</map-source>
> 	<map-source name="kmyarat" type="mapserver" reference="true">
> 		<file>./demo/data/kmyarat.map</file>
> 	</map-source>
> 	<map-source name="daerah" type="mapserver" reference="true">
> 		<file>./demo/data/daerah.map</file>
> 	</map-source>
> 	<map-source name="lot" type="mapserver" reference="true">
> 		<file>./demo/data/lot.map</file>
> 	</map-source>
> 	<map-source name="negeri" type="mapserver" reference="false">
> 		<file>./demo/data/negeri.map</file>
> 	</map-source>
> 	<service name="print" title="Print Map">
> 		<step type="input">
> 			<url>php/print.php</url>
> 			<input type="print_info" name="layers"/>
> 			<input type="extent" name="extent"/>
> 			<input type="sketches" name="sketches"/>
> 			<input type="user" name="title" title="Map Title">Map</input>
> 			<input type="hidden" name="date" title="Map Date">true</input>
> 			<input type="select" name="template" title="Output Template: ">
> 				<option value="letter_landscape">Letter - Landscape</option>
> 				<option value="letter_portrait">Letter - Portrait</option>
> 				<option value="poster_landscape">11" x 17" - Landscape</option>
> 				<option value="poster_portrait">11" x 17" - Portrait</option>
> 			</input>
> 			<input type="select" name="quality" title="Image Quality: ">
> 				<option value="2">Higher</option>
> 				<option value="3">Highest</option>
> 				<option value="1">Standard</option>
> 			</input>
> 			<input type="select" name="scale" title="Print Scale: ">
> 				<option value="map">Current Map Scale</option>
> 				<option value="1000">1:1000</option>
> 				<option value="5000">1:5000</option>
> 				<option value="10000">1:10000</option>
> 			</input>
> 		</step>
> 	</service>
> 	<service name="identify" title="Identify" display="false">
> 		<url>php/identify.php</url>
> 		<step type="spatial" name="shape" line="false" polygon="false"
> jump-start="true" default="point">
> 			<input type="visiblelayers" name="layers"/>
> 		</step>
> 	</service>
> 	<service name="birdseye" display="false" target="_blank">
> 		<url>php/birdseye.php</url>
> 		<step type="spatial" name="xy" line="false" polygon="false"
> jump-start="true" default="point" format="delim" reproject="EPSG:4326">
> 		</step>
> 	</service>
> 	<service name="streetview" display="false" target="_blank">
> 		<url>php/streetview.php</url>
> 		</step>
> 	</service>
> 	<service name="feature_report" display="false">
> 		<url>php/feature_report.php</url>
> 		<input type="hidden" name="layers" value="lmic/fsa"/>
> 		<input type="hidden" name="src"/>
> 		<input type="hidden" name="PIN"/>
> 	</service>
> 	<service name="select" title="Select">
> 		<url>php/select.php</url>
> 		<step type="spatial" showTools="true" name="shape" line="true"
> polygon="true" point="true" default="polygon" edit-polygon="false"
> pan="false" jump-start="true">
> 			<header></header>
> 			<input type="select" name="select_layer" title="Select:">
> 				<option value="parcels/parcels">Parcels</option>
> 			</input>
> 			<input type="user" name="shape_buffer" title="Buffer Selection Shape
> (ft)">0</input>
> 			<footnote></footnote>
> 		</step>
> 	</service>
> 	<service name="buffered_select_followup" title="Buffered Select">
> 		<step type="input">
> 			<input type="hidden" name="shape"/>
> 			<input type="hidden" name="select_layer"/>
> 			<input type="hidden" name="query_layer"/>
> 			<input type="hidden" name="shape_buffer"/>
> 			<input type="user" name="selection_buffer" title="Buffer Features By: "/>
> 		</step>
> 	</service>
> 	<service name="buffered_select" title="Buffered Select">
> pan="false">
> 			<header></header>
> 			<input type="select" name="select_layer" title="Select features from:">
> 			</input>
> 			<input type="user" name="selection_buffer" title="Buffer Selected
> Features (ft)">0</input>
> 			<input type="select" name="query_layer" title="Using Features In">
> 			</input>
> 		</step>
> 	</service>
> 	<service name="popups" display="false">
> 		<url>php/popups.php</url>
> 			<header></header>
> 			<input type="hidden" name="layer"/>
> 		</step>
> 	</service>
> 	<service name="geocode_address" title="Geocode Address">
> 		<url>php/geocode.php</url>
> 		<step type="input">
> 			<input type="user" name="address" title="Enter Address: "/>
> 			<input type="hidden" name="googlekey"
> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
> 		</step>
> 	</service>
> 	<service name="search_parcels">
> 		<url>php/itemquery.php</url>
> 		<step type="input">
> 			<input type="select" name="qitem" title="Search By: ">
>               <option value="DAERAH">Daerah</option>
>               </input>
>               <input type="user" name="qstring" title=""/>
>               <input type="hidden" name="layer" value="daerah/all"/>
>               <input type="hidden" name="zoom_to_first" value="false"/>
>               <input type="hidden" name="highlight" value="true"/>
> 			<input type="hidden" name="mode" value="search"/>
> 		</step>
> 	</service>
> 	<layer-controls>
> 		<layer-control name="popups" service-name="popups" layer-input="layer"
> on="false" tip="Show Popups for %LAYER%"/>
> 	</layer-controls>
> 	<catalog>
> 	<layer title="Jalan" src="jalanpontian/all" status="on"/>
> 	<layer title="Daerah" src="daerah/all" status="off"/>
>      <layer title="Kemudahan Masyarakat" src="KMYARAT/all" status="off"/>
> 	<layer title="Lot" src="lot/all" status="off"/>
> 	<layer title="Negeri" src="negeri/all" status="on" show-legend="true"
> minscale="0" maxscale="500000" />
> 	</catalog>
> 	<toolbar>
> 		<tool name="previous" title="Previous Extent" type="internal"
> action="previous" selectable="false"/>
> 		<tool name="next" title="Next Extent" type="internal" action="next"
> 		<tool name="fullextent" title="Zoom to Full Extent" type="internal"
> action="fullextent" selectable="false"/>
> 		<tool name="pan" title="Pan" type="internal" action="pan"
> selected="true"/>
> 		<tool name="zoomin" title="Zoom In" type="internal" action="zoomin"/>
> 		<tool name="zoomout" title="Zoom Out" type="internal" action="zoomout"/>
> 		<tool name="identify" title="Identify" type="service" service="identify"
> cursor="url('cursors/identify2.cur') 9 9,url('cursors/identify2.cur'),auto"
> 		<tool name="buffered_select" title="Buffered Select" type="service"
> service="buffered_select"/>
> 		<tool name="clear" title="Clear Selection" type="javascript"
> selectable="false">
> 			GeoMOOSE.changeLayerVisibility('highlight/all', false);
> 		</tool>
> 		<tool name="measure" title="Measure" type="internal" action="measure"/>
> 		<tool name="measurearea" title="Measure Area" type="internal"
> action="measurearea"/>
> 		<tool name="search_parcels" title="Carian" type="service"
> service="search_parcels" selectable="false"/>
> 		<tool name="print" title="Print" type="service" service="print"
> 		<tool name="birdseye" title="Bird's Eye View" type="service"
> selectable="true" service="birdseye"/>
> 		<tool name="streetview" title="Google Street View" type="service"
> service="streetview" selectable="true"/>
> 		<tool name="geocode" title="Geocode Address" type="service"
> service="geocode_address" selectable="true"/>
> 		<drawer>
> 			<tool name="markup_tools" title="Sketch Tools" type="internal"
> action="none" selectable="false"/>
> 			<tool name="draw_polygon" title="Draw Polygon" type="internal"
> action="draw_polygon"/>
> 			<tool name="draw_line" title="Draw Line" type="internal"
> action="draw_line"/>
> 			<tool name="draw_point" title="Draw Point" type="internal"
> action="draw_point"/>
> 			<tool name="draw_remove" title="Remove Drawing" type="internal"
> action="draw_remove"/>
> 			<tool name="draw_edit" title="Edit Drawing" type="internal"
> action="draw_edit_shapes"/>
> 			<tool name="draw_edit_attributes" title="Edit Attributes" type="internal"
> action="draw_edit_attributes"/>
> 			<tool name="clear_drawings" title="Clear Drawings" type="internal"
> action="clear_drawings" selectable="false"/>
> 		</drawer>
> 	</toolbar>
> </mapbook>
> *My Daerah.map*
> MAP
>    NAME 'daerah'
>    SIZE 800 650
>    UNITS meters
>    STATUS ON
>    EXTENT -142106.613606 -91674.819239 131302.257393 90719.114676
>    TRANSPARENT TRUE
>    MAXSIZE 10000
>    IMAGETYPE PNG
>     QUERYMAP
> 	STATUS ON
> 	STYLE SELECTED
>     END
>     LEGEND
>       IMAGECOLOR 255 255 255
>       STATUS ON
>     END
>    PROJECTION
> 	'proj=cass'
> 	'lat_0=2.121679744444445'
> 	'lon_0=103.4279362361111'
> 	'x_0=-14810.562'
> 	'y_0=8758.32'
> 	'ellps=GRS80'
> 	'units=m'
> 	'no_defs'
>    END
>    LAYER
>      NAME 'daerah'
>      DATA './daerah.shp'
>      TYPE POLYGON
>      STATUS ON
>    LABELCACHE ON
>      CLASS
>          NAME 'daerah'
>          STYLE
>           WIDTH 0.91
>           OUTLINECOLOR 85 85 127
>           COLOR 104 160 87
>         END
>        END
> 	    METADATA
> 	      	'identify_record'	'identify_daerah.html'
> 	      	'select_record'	'select_daerah.html'
> 			'popups' 'daerah_popup.html'
> 			'itemquery'	'daerah_itemquery.html'
> 			'itemquery-filteritem' 'OBJECTID'
> 			'itemquery-filter'	'/.*[qstring].*/i'
> 			'qstring_validation_pattern' '.'
> 	   END
> END
> END
> View this message in context: http://geomoose-users.964460.n3.nabble.com/error-occur-while-trying-to-make-a-search-function-using-itemquery-php-tp3285645p3285645.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> EMC VNX: the world's simplest storage, starting under $10K
> The only unified storage solution that offers unified management
> Up to 160% more powerful than alternatives and 25% more efficient.
> Guaranteed. http://p.sf.net/sfu/emc-vnx-dev2dev
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
