[Geomoose-users] feature editing - able to add polygons, not able to delete or edit.
Atif Butt matifbutt at gmail.com
Fri Dec 2 03:33:48 EST 2011
FYI
On Fri, Dec 2, 2011 at 3:32 AM, Atif Butt <matifbutt at gmail.com> wrote:
> I have change this in the map file, but no success.
> Could you please check the URL of my mapserver running geomoose2.
> http://99.243.192.221/geomoose2/geomoose.html
> In this way you might understand whats wrong in this feature editing.
> Regards
> Atif
> On Tue, Nov 29, 2011 at 3:54 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Ah, this is actually kinda an easy one.  There is a projections conflict
>> for MapServer.
>> I'd try editing your mapfile and changing:
>> DATA 'wkb_geometry from (select polygon_id, title, owner,
>> astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as
>> mytable using unique polygon_id'
>> To:
>> mytable using unique polygon_id using srid=-1'
>> I might be a little off on the syntax.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111202/8371d750/attachment-0001.html
More information about the Geomoose-users mailing list
