[Geomoose-users] feature editing - able to add polygons, not able to delete or edit.
Atif Butt matifbutt at gmail.com
Sat Dec 3 02:22:47 EST 2011
Hi
Is there any other steps needs to do (except written inside the feature
editor document) for "polygon_update and ploygon_delete". Because after
doing these steps, when I use update polygon feature I am getting this
message (1No Feature ID available for update.) and when I use
delete_polygon tool, it says "No Feature ID specified to delete."
I think something is missing.
kindly check (http://99.243.192.221/geomoose2/geomoose.html) and give me
your suggestions.
Best Regards
Atif
On Fri, Dec 2, 2011 at 2:29 PM, Atif Butt <matifbutt at gmail.com> wrote:
> Yes Dora, Finally, feature editor is started working. Now I can start
> other feature editors thing like delete, modify, etc.
> But I wasnt aware of this error, why this geomoose not opening inside the
> IE 7 and IE8, same green background nothing else is showing up.
> Kindly check http://99.243.192.221/geomoose2/geomoose.html
> Regards
> On Fri, Dec 2, 2011 at 2:04 PM, Atif Butt <matifbutt at gmail.com> wrote:
>> Hi Dora
>> The URL dose work, but its not working inside Internet Explorer (I dont
>> know why). But if you can try inside firefox, or any other borwser then it
>> should be fine.
>> Try again Please: http://99.243.192.221/geomoose2/geomoose.html
>> Secondly, as Dan Little pointed me the same error. so I changed my map
>> file with this code
>> 'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry)
>> as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique
>> polygon_id using srid=-1'
>> Regards
>> Atif
>>   On Fri, Dec 2, 2011 at 9:37 AM, Dara Olson <dolson at glifwc.org> wrote:
>>> Your URL won't work - I don't think you are online and just running
>>> through your local network.
>>> What projection is your data in (SRID)? What projection is your
>>> application in (SRID)? Try below and insert your SRID where the XXXXX are,
>>> but make sure that your application and data are in the same SRID.
>>> DATA "'wkb_geometry FROM (SELECT polygon_id, title, owner,
>>> astext(wkb_geometry) as wkt_geometry FROM
>>> from test_polygons) as mytable using unique polygon_id using srid=XXXXX"
>>> Dara
>>> ----- Original Message -----
>>> *From:* Atif Butt <matifbutt at gmail.com>
>>> *To:* Dan Little <danlittle at yahoo.com>
>>> *Cc:* Brent Fraser <bfraser at geoanalytic.com> ;
>>> geomoose-users at lists.osgeo.org ; dolson at glifwc.org
>>> *Sent:* Friday, December 02, 2011 2:33 AM
>>>  *Subject:* Re: [Geomoose-users] feature editing - able to add
>>>  FYI
>>> On Fri, Dec 2, 2011 at 3:32 AM, Atif Butt <matifbutt at gmail.com> wrote:
>>>> I have change this in the map file, but no success.
>>>> Could you please check the URL of my mapserver running geomoose2.
>>>> In this way you might understand whats wrong in this feature editing.
>>>> Regards
>>>> Atif
>>>> On Tue, Nov 29, 2011 at 3:54 PM, Dan Little <danlittle at yahoo.com>wrote:
>>>>>  Ah, this is actually kinda an easy one.  There is a projections
>>>>> conflict for MapServer.
>>>>> I'd try editing your mapfile and changing:
>>>>>  DATA 'wkb_geometry from (select polygon_id, title, owner,
>>>>> astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as
>>>>> mytable using unique polygon_id'
>>>>> To:
>>>>> mytable using unique polygon_id using srid=-1'
>>>>> I might be a little off on the syntax.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111203/8baf8c38/attachment-0001.html
More information about the Geomoose-users mailing list
