[Geomoose-users] Re: Identify & popup issues
Dan Little danlittle at yahoo.com
Mon Dec 5 11:14:06 EST 2011
That looks like PHP cannot find MapScript.
Edit "config.php" and uncomment the line that starts with "dl(" and has "MapScript" or "mapscript" in it.  I can't remember off hand which exact line it is.
>________________________________
> From: Efstathios Arapostathis <e.arapostathis at gmail.com>
>To: Dan Little <danlittle at yahoo.com>
>Cc: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Saturday, December 3, 2011 11:16 AM
>Subject: Re: [Geomoose-users] Re: Identify & popup issues
>Ok I'm trying the link you gave me to university's server and I'm getting this error:
>Fatal error: Call to undefined function ms_shapeObjFromWkt() in C:\ms4w\apps\museum_geomoose2\htdocs\php\popups.php on line 32
>   I'm also experiencing problems in loading my postgis layers. I'm geting pink images and when I try to see the error
>by executing the query  (I found it under Mozilla's menu tools-->page info --> multimedia) I'm not getting any error message. Only
>a blank screen.
>   I can see my database though, by loading it in QGIS so it's not a database's problem.
>Server's software is: MS4W 2.2.6 with PHP 5.2.4 and postgresql 8.3.
>I'm probably using geomoose2 or geomoose2.2  (I'm not sure about the version cause this app was developed about 18 months ago and I don't know how to check it)
>Any ideas?
>best regards,
>Stathis
>On Tue, Nov 29, 2011 at 8:35 PM, Dan Little <danlittle at yahoo.com> wrote:
>Something nasty is dying on your server:
>>When this URL returns something, ANYTHING, things will be "working":
>>http://www.hellas-gis.com/museum_geomoose2/htdocs/php/popups.php?layer=perioxesgmerc%2Fperioxesgmerc&shape=POINT(2406849.1463086%204745210.7152832)&_moosetime=1322591692504
>>You'll need to check the server's error logs as to why the PHP script is dying.
>>>To: geomoose-users at lists.osgeo.org
>>>Sent: Sunday, November 27, 2011 1:43 PM
>>>Subject: [Geomoose-users] Re: Identify & popup issues
>>>I've corrected the temp folder path in settings.ini and now when trying to use identify I'm receiving a popup window with this message:
>>>"No valid response"
>>>Maybe you could check it by youself in this url:
>>>http://www.hellas-gis.com/museum_geomoose2/htdocs/#
>>>Thanks again,
>>>Stathis
>>>On Sun, Nov 27, 2011 at 8:47 PM, Efstathios Arapostathis <e.arapostathis at gmail.com> wrote:
>>>Hi,
>>>>   I've uploaded a geomoose app to a server, but I'm having troubles using identify and popup services.
>>>>I'm receiving this message:
>>>>"Fatal error: Call to a member function queryByShape() on a non-object in /var/www/vhosts/hellas-gis.com/httpdocs/museum_geomoose2/htdocs/php/identify.php on line 129"
>>>>Any ideas on what is wrong?
>>>>Thanks,
>>>>Stathis
>>>_______________________________________________
>>>Geomoose-users mailing list
>>>Geomoose-users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111205/fbc7adb2/attachment.html
More information about the Geomoose-users mailing list
