[Geomoose-users] Re: Identify & popup issues
Brent Fraser bfraser at geoanalytic.com
Wed Dec 7 11:56:49 EST 2011
Using a command line (in the directory containing mapserver executed by
your webserver) what does the command "mapserv -v" show?
Best Regards,
Brent Fraser
On 12/7/2011 9:38 AM, Efstathios Arapostathis wrote:
> It's already  uncommented..
> Any ideas?
> /*Config.php:*/
> <?php
> /*Copyright (c) 2009, Dan "Ducky" Little & GeoMOOSE.org
> Permission is hereby granted, free of charge, to any person obtaining
> a copy
> of this software and associated documentation files (the "Software"),
> to deal
> in the Software without restriction, including without limitation the
> rights
> to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
> copies of the Software, and to permit persons to whom the Software is
> furnished to do so, subject to the following conditions:
> The above copyright notice and this permission notice shall be included in
> all copies or substantial portions of the Software.
> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT
> SHALL THE
> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
> ARISING FROM,
> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
> THE SOFTWARE.*/
> # This is meant to allow specific environmental includes for
> # GeoMOOSE 2 PHP Services.  Substantive configuraiton options
> # should be added to settings.ini
> /* Check for the required libraries
>  * g2/curl are used for printing. If you're not using printing
>  * you can avoid using these modules.
>  * mapscript and dbase are used for most operations using them
>  * cannot be avoided
> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
>     dl('php_gd2.'.PHP_SHLIB_SUFFIX);
> if(!extension_loaded('curl')) {
>     dl('php_curl.'.PHP_SHLIB_SUFFIX);
> if(!extension_loaded('MapScript')) {
>     dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
> if(!extension_loaded('dbase')) {
>     dl('php_dbase.'.PHP_SHLIB_SUFFIX);
> # Load the configration file
> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
> function getMapbook() {
>     global $CONFIGURATION;
>     $mapbook = new DOMDocument();
>     $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>     return $mapbook;
> function getUsername() {
>     session_start();
>     return $_SESSION['username'];
> # Select Functionality ONLY works for Mapserver Layers
> function getMapfile($mb, $layerName) {
>     $services = $mb->getElementsByTagName('map-source');
>     $mapfiles = array();
>     for($i = 0; $i < $services->length; $i++) {
>         $service = $services->item($i);
>         $root = $service->getAttribute('name');
>         $layers = $service->getElementsByTagName('layer');
>         for($l = 0; $l < $layers->length; $l++) {
>             $layer = $layers->item($l);
>             $path = $root.'/'.$layer->getAttribute('name');
>             if($path == $layerName) {
>                 return
> $service->getElementsByTagName('file')->item(0)->nodeValue;
>     return null;
> # get a source based on it's name
> function getMapSource($mb, $layerName) {
>         if($services->item($i)->getAttribute('name') == $layerName) {
>             return $services->item($i);
>     return null;
> On Mon, Dec 5, 2011 at 6:52 PM, Eli Adam <eadam at co.lincoln.or.us
> <mailto:eadam at co.lincoln.or.us>> wrote:
>     Since you are using PHP 5.2.4 I don't think that is an issue, but in
>     later PHP versions, dl has been removed,
>     http://us2.php.net/manual/en/function.dl.php
>     Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111207/e6c474ec/attachment.html
More information about the Geomoose-users mailing list
