[Geomoose-users] Re: Identify & popup issues
Jim Klassen klassen.js at gmail.com
Thu Dec 8 13:49:21 EST 2011
I don't know if this is related, but I doubt anyone has tested against MapServer 5.0.0 in a long time.
On Dec 8, 2011, at 11:25, Brent Fraser <bfraser at geoanalytic.com> wrote:
>    The important part is that is has "SUPPORTS=GEOS", so that's good (from Googling, this is the component that supplies the ms_shapeObjFromWkt function to mapserver).
>   You've got a serious and uncommon mapserver configuration problem.  To figure out why the function is not available, I'd recommend making a simple PHP script containing ms_shapeObjFromWkt and executing it from command line.  Or use PHP's get_extension_funcs('MapScript')  function to list the function names that are available in mapserver's MapScript:
> <?php
> if(!extension_loaded('MapScript')) {
>     dl('php_mapscript.'.PHP_SHLIB_SUFFIX);
> echo implode('<br /> ', get_extension_funcs('MapScript') ), '<br />';
> Best Regards,
> Brent Fraser
> On 12/8/2011 9:47 AM, Efstathios Arapostathis wrote:
>> Hi,
>> The following message appears:
>> MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE  SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
>> SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
>> On Wed, Dec 7, 2011 at 6:56 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Using a command line (in the directory containing mapserver executed by your webserver) what does the command "mapserv -v" show?
>> Best Regards,
>> Brent Fraser
>> On 12/7/2011 9:38 AM, Efstathios Arapostathis wrote:
>>> It's already  uncommented..
>>> Any ideas?
>>> Config.php:
>>> <?php
>>> /*Copyright (c) 2009, Dan "Ducky" Little & GeoMOOSE.org
>>> Permission is hereby granted, free of charge, to any person obtaining a copy
>>> of this software and associated documentation files (the "Software"), to deal
>>> in the Software without restriction, including without limitation the rights
>>> to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
>>> copies of the Software, and to permit persons to whom the Software is
>>> furnished to do so, subject to the following conditions:
>>> The above copyright notice and this permission notice shall be included in
>>> all copies or substantial portions of the Software.
>>> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
>>> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
>>> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.                   IN NO EVENT SHALL THE
>>> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,                   DAMAGES OR OTHER
>>> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
>>> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
>>> THE SOFTWARE.*/
>>> # This is meant to allow specific environmental includes for
>>> # GeoMOOSE 2 PHP Services.  Substantive configuraiton options
>>> # should be added to settings.ini
>>> /* Check for the required libraries
>>>  * g2/curl are used for printing. If you're not using printing
>>>  * you can avoid using these modules.
>>>  * mapscript and dbase are used for most operations using them
>>>  * cannot be avoided
>>> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
>>>     dl('php_gd2.'.PHP_SHLIB_SUFFIX);
>>> if(!extension_loaded('curl')) {
>>>     dl('php_curl.'.PHP_SHLIB_SUFFIX);
>>> if(!extension_loaded('dbase')) {
>>>     dl('php_dbase.'.PHP_SHLIB_SUFFIX);
>>> # Load the configration file
>>> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
>>> function getMapbook() {
>>>     global $CONFIGURATION;
>>>     $mapbook = new DOMDocument();
>>>     $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>>>     return $mapbook;
>>> function getUsername() {
>>>     session_start();
>>>     return $_SESSION['username'];
>>> # Select Functionality ONLY works for Mapserver Layers
>>> function getMapfile($mb, $layerName) {
>>>     $services = $mb->getElementsByTagName('map-source');
>>>     $mapfiles = array();
>>>     for($i = 0; $i < $services->length; $i++) {
>>>         $service = $services->item($i);
>>>         $root = $service->getAttribute('name');
>>>         $layers = $service->getElementsByTagName('layer');
>>>         for($l = 0; $l < $layers->length; $l++) {
>>>             $layer = $layers->item($l);
>>>             $path = $root.'/'.$layer->getAttribute('name');
>>>             if($path == $layerName) {
>>>                 return $service->getElementsByTagName('file')->item(0)->nodeValue;
>>>     return null;
>>> # get a source based on it's name
>>> function getMapSource($mb, $layerName) {
>>>         if($services->item($i)->getAttribute('name') == $layerName) {
>>>             return $services->item($i);
>>>     return null;
>>> On Mon, Dec 5, 2011 at 6:52 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>>> Since you are using PHP 5.2.4 I don't think that is an issue, but in
>>> later PHP versions, dl has been removed,
>>> http://us2.php.net/manual/en/function.dl.php
>>> Eli
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111208/7427f72b/attachment-0001.html
More information about the Geomoose-users mailing list
