[Geomoose-users] feature editing in geomoose
sana b sana.openmeetings at gmail.com
Wed Dec 21 15:14:56 EST 2011
Hi Brent Thanks for reply
When click my delete polygon Button it should ask me (Are you sure you want
to delete this?) according to following function
   javascript:if(confirm('Are you sure you want to delete this?')) {
GeoMOOSE.startService('delete_
> polygon', {'feature:polygon_id' :
> '[polygon_id]'}); } Delete
but it does nothing, not even selected the stored polygon or highlighted
the polygon.
similarly, when i use the modify polygon feature i have nothing return from
the identify. html file. its seems its not connected or call properly or
may be not stored at proper place.
Paths where my files are stored  related to feature editor configuration:
test_polygons.ini
path stored at: \ms4w\apps\geomoose2\conf\
editor\test_polygons.ini
test_polygon.map  And identify.html
path stored at :
\ms4w\apps\geomoose2\maps\development\test_polygons\identify.html
When I run identify.html file only, its out put is like as:
*[title] ([polygon_id])* Owner:[owner] Edit Delete
Regards
Sana
On Tue, Dec 13, 2011 at 3:45 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
> When you do an Identify on the polygon, what is returned?
> Best Regards,
> Brent Fraser
> On 12/13/2011 1:30 PM, sana.openmeetings wrote:
>> I am a new user of geoMoose and I am trying to use its feature editor
>> function. I have configured all the steps mentioned in the feature editor
>> guide and able to add into the database new polygon features only whereas
>> I
>> cant edit or delete the polygon features.
>> I guess my identify.html (shown as follow, template comes with the
>> geomoose)
>> needs something to configure.
>> <tr bgcolor="#AA55AA">
>>        <td colspan="2">*[title] ([polygon_id])*</td>
>> </tr>
>> <tr>
>>        <td>Owner:</td><td>[owner]</**td>
>> </tr>
>> <tr>
>> <td>
>>        javascript:GeoMOOSE.**startService('modify_polygon',
>> '[polygon_id]','feature:wkb_**geometry' : '[wkt_geometry]',
>> 'feature:title' :
>> '[title]', 'feature:owner' : '[owner]'}) Edit
>> </td>
>> <td>
>> GeoMOOSE.startService('delete_**polygon', {'feature:polygon_id' :
>> </td>
>> </tr>
>> I havent started with point feature at this moment as I require only
>> polygon
>> feature first.
>> Anybody, who configure all the steps related to polygon feature and able
>> to
>> delete and update polygon feature as well?
>> Could you please help me how to configure identify.html file ?
>> Originally in the map file identify.html file is defined as
>>                 METADATA
>>                        'identify_record' 'identify.html'
>>                END
>> Is that only step needs to performed for calling identify.html file within
>> map file?
>> looking forward for the response who already did this configuration
>> Sana
>> View this message in context: http://geomoose-users.964460.**
>> n3.nabble.com/Geomoose-users-**feature-editing-in-geomoose-**
>> tp2276648p3583520.html<http://geomoose-users.964460.n3.nabble.com/Geomoose-users-feature-editing-in-geomoose-tp2276648p3583520.html>
>> Sent from the Geomoose-users mailing list archive at Nabble.com.
>> ______________________________**_________________
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/geomoose-**users<http://lists.osgeo.org/mailman/listinfo/geomoose-users>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111221/c44fb3cf/attachment.html
More information about the Geomoose-users mailing list
