[Geomoose-users] Identify service - GDB v. Shapefile
Dan Little danlittle at yahoo.com
Mon Feb 7 18:40:28 EST 2011
Not a ton of experience with the GDB stuff.  The problem may be with the OGR
source type.
>From: "Johnson, Jeremy" <JJohnson at ci.blaine.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Mon, February 7, 2011 3:34:00 PM
>Subject: [Geomoose-users] Identify service - GDB v. Shapefile
>I have a polygon  layer in my personal geodatabase that is a reference layer for
>our record  drawings.  I have been able to add the layer and display it just
>fine, but  I am unable to use the identify tool on the dataset.  However, if I
>convert  the GDB dataset to a shapefile, the identify tool works just fine.  Has
>anyone else run across this issue?  Any help would be greatly  appreciated.
>----------------MAPFILE----------------
>MAP
> NAME 'stormref'
> SIZE 800  650
> STATUS ON
> EXTENT  474400 4995000 494000 5007000
> UNITS METERS
> INCLUDE "../../geomoose_globals.map"
> PROJECTION
>    "init=epsg:26915"
> END
>     LAYER
> NAME  'stormref'
> CONNECTIONTYPE ogr
> CONNECTION  '/ms4w/data/storm_water.mdb'
> DATA 'storm_reference'
> STATUS  DEFAULT
> TYPE POLYGON
> MAXSCALE  6000
> PROJECTION
>    "init=epsg:99999"
> END
>             CLASS
>           NAME 'Storm Rec  Drwg'
>           STYLE
>              SYMBOL  'plainline'
>              SIZE 2
>              COLOR 254 254  254
>              OUTLINECOLOR 254 0  0
>               END
>         END
>  METADATA
>         'identify_record' 'identify_stormref.html'
>  END
>  TOLERANCEUNITS  FEET
>  TOLERANCE 0
>     END
>     LAYER
> NAME  storm_anno
> CONNECTIONTYPE ogr
> DATA  'storm_reference_annotation'
> STATUS DEFAULT
> TYPE  annotation
> MAXSCALE 6000
> PROJECTION
>    "init=epsg:99999"
> END
>     LABELITEM  'TextString'
>      CLASS
>        LABEL
>  TYPE  TRUETYPE
>  FONT vera_sans-bold-italic
>  SIZE  8
>  #ANTIALIAS TRUE
>  COLOR 254 0  0
>  OUTLINECOLOR 254 254 254
>  BUFFER  2
>         END
>      END
> END
>END ## end Map
>------------------IDENTIFY HTML----------------
><tr>
><td colspan="2"><b>Storm  Sewer Record Drawing</b></td>
></tr>
><tr>
><td  align="left"><u>Sheet Number:</u></td>
><td><a  href="/utilimoose/record_drawings/[DIRECTORY]/[SHEETNAME]"
>target="_blank">[SHEETNAME]</a></td>
></tr>
><tr><td  colspan="2"><hr></td></tr>
>Jeremy Johnson,  GISP
>G.I.S. Coordinator
>City of Blaine
>10801 Town Square Dr Ne
>Blaine, MN  55449
>(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110207/38fff36b/attachment.html
More information about the Geomoose-users mailing list
