[Geomoose-users] URL parameters
Carl Burn burnsy at northcountrywoods.co.uk
Wed Feb 9 09:22:28 EST 2011
Hello,
yep thanks, missing two actually once put in place it all works well.
No doubt I will run into more problems as I go.
Thanks to all
Carl
On Wed, Feb 9, 2011 at 2:16 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Are you missing a dot?
> $_COOKIE['UU_USERID'].'_'
> Best Regards,
> Brent Fraser
> On 2/9/2011 5:07 AM, Carl Burn wrote:
> Hello again,
>  took a stab at this and I have set up two cookies for the purpose of
> passing across my values for the mapbook I want to use and building the file
> name to be used from two elements which are separated with an underscore.
>  I have replaced the getmapbook function with the new code as follows:
>  function getMapbook() {
>         global $CONFIGURATION;
>         $mapbook = new DOMDocument();
>        if($_COOKIE['UU_MAPBOOK']) {
>  $mapbook->load('../../conf/'.$_COOKIE['UU_USERID']'_'.$_COOKIE['UU_MAPBOOK']'.xml');
>         # $mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
>         } else {
>         # load the default...
>         return $mapbook;
>  This results in an empty application (not showing any layers or toolbar),
> first thing I did was to check the cookies
> I guess I have something wrong in the way that I build up the file name as
> the mapbook is not called, I know that the code is seeing the cookie and
> have tested this by simply putting in a test file name instead of the values
> from the cookies and then the mapbook is read and the application works.
>  So the error lies here I think:
>  anybody see my error?
>  Many thanks
>  Carl
> On Tue, Feb 8, 2011 at 4:08 PM, Dan Little <danlittle at yahoo.com> wrote:
>>  You are correct, check out my previous post.
>>  *From:* Carl Burn <burnsy at northcountrywoods.co.uk>
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Tue, February 8, 2011 10:05:19 AM
>> *Subject:* Re: [Geomoose-users] URL parameters
>> Hello again,
>>  I took a look at this and the code I think I need to alter is pretty
>> much this section of the config.php file:
>>  # Load the configration file
>> $CONFIGURATION = parse_ini_file('../../conf/settings.ini');
>>  return $mapbook;
>>  I am a CF person not a php person (so bear with me) but this looks like
>> it gets the mapbook from the settings.ini, reads it and then puts the
>> content into a variable called mapbook. So if I can modify this
>> functionality to take the details from the url parameter I am passing in
>> then that should be it, the security I can handle in other ways.
>>  Is this making sense?
>>  Carl
>> On Tue, Feb 8, 2011 at 3:43 PM, Carl Burn <burnsy at northcountrywoods.co.uk
>> > wrote:
>>> Hello all,
>>>  one thought occurs, how do I go about changing the name of the index
>>> file that is called when geomoose starts up, at the moment this is
>>> geomoose.html.
>>> Is this simply a case of changing the file name or is it wired into the
>>> setup of geomoose, if I can alter the file extension then I can see a way to
>>> solve this easily.
>>>  Carl
>>> On Tue, Feb 8, 2011 at 3:39 PM, Carl Burn <
>>> burnsy at northcountrywoods.co.uk> wrote:
>>>> Hi,
>>>>  mid afternoon here, still a while to go before I head off...and I
>>>> think that may be extended so I can resolve this one.
>>>>  I am passing in the parameter for map book every time a user accesses
>>>> geomoose as they all have unique files...and just to be really fun they are
>>>> likely to be unique on every visit, so I am generating a mapbook on the fly
>>>> as the user attempts to access geomoose.
>>>>  Not to sure I understand what you mean by 1 or 2 but I think I may
>>>> head over and get a copy of 1.x
>>>>  Cheers
>>>>  Carl
>>>> On Tue, Feb 8, 2011 at 3:24 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>>>  Good morning (at least for me, you're probably trying to leave the
>>>>> office about now)!
>>>>>  GM2.2 doesn't directly support passing in a mapbook parameter as did
>>>>> the 1.X series.  The reason for this is three-fold:
>>>>> 1) It wasn't a terribly popular functionality.
>>>>> 2) It was a gaping security hole.
>>>>> 3) It requires all of the subsequent services to know they need to
>>>>> switch mapbooks.
>>>>>  There are some options, and they all center around modifying the
>>>>> getMapbook function of config.php.  Two popular solutions:
>>>>> 1) Parser the "referrer url" from the HTTP header and get the mapbook
>>>>> parameter from that.
>>>>> 2) Read a cookie for a login/authorization schema and select the
>>>>> appropriate mapbook.
>>>>> *Sent:* Tue, February 8, 2011 9:18:01 AM
>>>>> *Subject:* [Geomoose-users] URL parameters
>>>>> Hi All,
>>>>>  I am passing across a url parameter of mapbook to geomoose and it
>>>>> looks like it is simply being ignored, for example:
>>>>> http://www.aqua3.com:2112/geomoose2/geomoose.html?mapbook=62_1364345175.xml
>>>>>  The system simply uses the default mapbook as defined in the
>>>>> config.ini file and ignores the url parameter totally, I checked the
>>>>> documentation link for this and my call looks correct. The mapbook file is
>>>>> valid and works if I put it into the config.ini. I also tried not setting a
>>>>> mapbook in the config.ini..this results in no map even when the mapbook is
>>>>> specified on the url as a  parameter.
>>>>> I know its going to be an obvious one but can someone point out what I
>>>>> have missed please.
>>>>>  Best
>>>>>  Carl
> The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
> Pinpoint memory and threading errors before they happen.
> Find and fix more than 250 security defects in the development cycle.
> Locate bottlenecks in serial and parallel code that limit performance.http://p.sf.net/sfu/intel-dev2devfeb
> Geomoose-users mailing listGeomoose-users at lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110209/300c73fe/attachment.html
More information about the Geomoose-users mailing list
