[Geomoose-users] Setting up first geomoose app
Carl Burn burnsy at northcountrywoods.co.uk
Thu Jan 13 12:02:58 EST 2011
trying to get a basic app working in geomoose using our own data and I am
getting a blank map area. I have set up a simple map file in the standard
ms4w maps folder in a folder called ArcView, I have put my map file in to
that folder and have tested it using a browser and can see a map and am able
to download an xml document when I do a get capabilities request.
The map file is as follows:
============== MAP FILE =======================
MAP
  NAME "TESTMAP"
  # Map image size
  SIZE 800 800
  UNITS INCHES
  EXTENT -990487.465830 -31957.211592 1696934.624449 1261986.757801
  FONTSET     "../fonts/fontset.list"
    SYMBOLSET    "../symbols/symbol.sym"
  PROJECTION
     'init=epsg:4326'
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE jpeg
  OUTPUTFORMAT
    NAME jpeg
    DRIVER 'GD/JPEG'
    MIMETYPE 'image/jpeg'
    IMAGEMODE RGBA
    EXTENSION 'jpeg'
  END
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  WEB
    IMAGEPATH '/tmp/'
    IMAGEURL '/tmp/'
    METADATA
      'ows_title'           'TESTMAP'
      'ows_onlineresource'  'http://www.*ourserver*
.com:2112/cgi-bin/mapserv.exe?map=testshp.map'
      'ows_srs'             'EPSG:4326'
    END
    TEMPLATE 'foo'
  END
  LAYER
    NAME 'RECTANGLES'
    TYPE POLYGON
    DUMP true
    TEMPLATE fooOnlyForWMSGetFeatureInfo
    DATA 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
    METADATA
      'ows_title' 'rectangles'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
    'init=epsg:4326'
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       NAME 'seamless_rectangle'
       STYLE
         WIDTH 1
         OUTLINECOLOR 0 0 0
         COLOR 149 170 154
       END
    END
  END
END
=============== END OF MAP FILE=================
The map book .xml is as follows, just a commented out version of the
original one:
============== MAPBOOK.XML ===================
<?xml version="1.0"?>
<mapbook version="2.0">
    <configuration>
            <param name="links_bar_html"><![CDATA[Perfect timing for some
damn CDATA "all" of 'its' here <&>]]></param>
            <param name="layer_controls.unfade.on">false</param>
        <!--    <param name="zoomto['Jump To:']"><![CDATA[
            'Dakota County' :
[521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
            'Parcel Data' :
[497205.409367,4923984.423582,477595.805945,4941970.52988],
            'Full State of MN' :
[189783.560000,4816309.330000,761653.524114,5472346.500000]
        ]]></param> -->
        <param
name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
        <param
name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
        <param name="layer_controls.legend.on">false</param>
        <param name="mapserver_url">/cgi-bin/mapserv.exe</param>
        <param name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
        <param name="projection">EPSG:4326</param>
        <param name="layer_controls.up.on">false</param>
        <param name="layer_controls.down.on">false</param>
        <param name="layer_controls.legend.on">true</param>
        <param name="drawing_tools.default_fill">red</param>
        <param name="drawing_tools.default_stroke">yellow</param>
        <param name="drawing_tools.default_opacity">1</param>
        <param name="group_checkboxes">false</param>
        <param name="default_tab">Catalog</param>
        <param name="catalog_name">Catalog</param>
        <param name="show_service_settings_in">Information</param>
        <param name="show_results_in">Information</param>
        <param name="tabs"><![CDATA[
             'Catalog' : 'catalog-tab',
             'Information' : 'information-tab',
             'Custom' : 'custom-tab'
         ]]></param>
        <param name="ground_units">km</param>
        <param name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
        <param name="reference_map.enabled">false</param>
        <param name="coordinate_display.usng">false</param>
        <param name="jumpto_scales"><![CDATA[
            '1:50000' : 50000,
            '1:24000' : 24000,
            '1:10000' : 10000,
            '1:5000' : 5000
    ]]></param>
    </configuration>
        The mapping services define the source of the mapping data.
    <map-source name="highlight" type="mapserver">
        <file/>
        <layer name="all"/>
    </map-source>
    <map-source name="TESTMAP" type="mapserver">
        <file>./ArcView/testshp.map</file>
        <layer name="rectangles"/>
    </map-source>
    <!--    <map-source name="borders" type="mapserver" reference="true">
        <file>./demo/statedata/basemap.map</file>
        <layer name="all"/>
    </map-source>
    <map-source name="iastate" type="wms" tiled="false"
projection="EPSG:900913" width="512" height="512">
        <url>http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
</url>
        <layer name="nexrad-n0r"/>
        <param name="format" value="image/jpeg"/>
        <param name="TRANSPARENT" value="TRUE"/>
    </map-source>
    <map-source name="metbase" type="ags" >
        <url>
http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
</url>
        <layer name="Met Council Base Map Layers" />
        <param name="FORMAT" value="JPG"/>
    </map-source>
    <map-source name="lmic" type="wms" tiled="false">
        <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
        <layer name="fsa2008"/>
        <layer name="bw1997"/>
    </map-source>
    <map-source name="usgs_doq" type="wms" tiled="false"
projection='EPSG:26915'>
        <url>http://terraservice.net/ogcmap.ashx?</url>
        <layer name="DOQ"/>
    </map-source>
    <map-source name="usgs_drg" type="wms" tiled="false"
        <layer name="DRG"/>
    </map-source>
    <map-source name="reference" type="wms" tiled="false" reference="true">
        <layer name="fsa2008" reference="true" />
    </map-source> -->
    <service name="print" title="Print Map">
        <step type="input">
            <url>php/print.php</url>
            <input type="print_info" name="layers"/>
            <input type="extent" name="extent"/>
            <input type="sketches" name="sketches"/>
            <input type="user" name="title" title="Map Title">Map</input>
            <input type="hidden" name="date" title="Map Date">true</input>
            <input type="select" name="template" title="Output Template: ">
                <option value="letter_landscape">Letter - Landscape</option>
                <option value="letter_portrait">Letter - Portrait</option>
                <option value="poster_landscape">11" x 17" -
Landscape</option>
                <option value="poster_portrait">11" x 17" -
Portrait</option>
            </input>
            <input type="select" name="quality" title="Image Quality: ">
                <option value="2">Higher</option>
                <option value="3">Highest</option>
                <option value="1">Standard</option>
            </input>
            <input type="select" name="scale" title="Preserve Scale: ">
                <option value="preserve">Yes</option>
                <option value="no">No</option>
            </input>
        </step>
    </service>
    <service name="identify" title="Identify" display="false">
        <url>php/identify.php</url>
        <step type="spatial" name="shape" line="false" polygon="false"
jump-start="true" default="point">
            <input type="visiblelayers" name="layers"/>
        </step>
    </service>
    <service name="birdseye" display="false" target="_blank">
        <url>php/birdseye.php</url>
        <step type="spatial" name="xy" line="false" polygon="false"
jump-start="true" default="point" format="delim" reproject="EPSG:4326">
        </step>
    </service>
    <service name="streetview" display="false" target="_blank">
        <url>php/streetview.php</url>
        </step>
    </service>
    <service name="feature_report" display="false">
        <url>php/feature_report.php</url>
        <input type="hidden" name="layers" value="lmic/fsa"/>
        <input type="hidden" name="src"/>
        <input type="hidden" name="PIN"/>
    </service>
    <service name="select" title="Select">
        <url>php/select.php</url>
        <!-- Send a selection shape + the visible layers list to the service
        <step type="spatial" showTools="true" name="shape" line="true"
polygon="true" point="true" default="polygon" edit-polygon="false"
pan="false" jump-start="true">
            <header><![CDATA[Create a selection area by clicking on the
map.]]></header>
                Option values should be the mapbook path to the layer.
                This only supports 'mapserver'-type layers.
            <input type="select" name="select_layer" title="Select:">
                <option value="parcels/parcels">Parcels</option>
            </input>
            <input type="user" name="shape_buffer" title="Buffer Selection
Shape (ft)">0</input>
            <input type="select" name="query_layer" title="Using Features
In">
            </input>
            <footnote><![CDATA[
            ]]></footnote>
        </step>
    </service>
    <!-- this is called after a standard select in order to buffer the
previous selection -->
    <service name="buffered_select_followup" title="Buffered Select">
        <step type="input">
            <input type="hidden" name="shape"/>
            <input type="hidden" name="select_layer"/>
            <input type="hidden" name="query_layer"/>
            <input type="hidden" name="shape_buffer"/>
            <input type="user" name="selection_buffer" title="Buffer
Features By: "/>
        </step>
    </service>
    <service name="buffered_select" title="Buffered Select">
pan="false">
map.]]></header>
            <input type="select" name="select_layer" title="Select features
            </input>
Selected Features (ft)">0</input>
<!--            <input type="user" name="shape_buffer" title="Buffer
Selection Shape (ft)">0</input>
In">
            </input>
            <footnote><![CDATA[
            ]]></footnote>
        </step>
    </service>
    <service name="popups" display="false">
        <url>php/popups.php</url>
            <header><![CDATA[
            Click on the map to show a popup about the features.
            ]]></header>
            <input type="hidden" name="layer"/>
        </step>
    </service>
    <service name="geocode_address" title="Geocode Address">
        <url>php/geocode.php</url>
        <step type="input">
            <input type="user" name="address" title="Enter Address: "/>
            <input type="hidden" name="googlekey"
value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
        </step>
    </service>
    <service name="search_parcels">
        <url>php/query.php</url>
        <step type="input">
            <input type="hidden" name="highlight" value="true"/>
            <input type="hidden" name="mode" value="search"/>
            <input type="hidden" name="layer0" value="parcels/parcels"/>
            <input type="hidden" name="template0" value="itemquery"/>
            <input type="select" name="fieldname0" title="Search By:">
                <option value="OWNER_NAME">Owner</option>
                <option value="PIN">Parcel ID</option>
            </input>
            <input type="select" name="comparitor0" title="That: ">
                <option value="like-icase">Contains</option>
                <option value="right-like-icase">Begins With</option>
                <option value="eq-str">Matches Exactly</option>
            </input>
            <input type="user" name="value0" title=""/>
            <input type="hidden" name="fieldname1" value="FIN_SQ_FT"/>
            <input type="select" name="operator1">
                <option value="or">OR</option>
                <option value="and">AND</option>
            </input>
            <input type="select" name="comparitor1" title="Having Fin. Sq.
Ft. ">
                <option value="gt">Greater Than</option>
                <option value="eq">Equal To</option>
                <option value="lt">Less Than</option>
            </input>
            <input type="user" name="value1" title=""/>
        </step>
    </service>
        The catalog defines how the layers will be displayed in the catalog
tab.
    <layer-controls>
        <layer-control name="popups" service-name="popups"
layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
    </layer-controls>
    <catalog>
    <!--     <layer title="overallmap" src="parcels/parcels" status="on"
popups="true" minscale="0" maxscale="150000" metadata="true" >
            <metadata>http://www.aqua3.com</metadata>
        </layer>
        <layer title="City and County Boundaries" src="borders/all"
status="on"/>
        <layer title="Weather Radar" src="iastate/nexrad-n0r" status="off"
legend="false"/>
        <group title="Backgrounds" expand="true" multiple="false">
            <layer title="Metro Base Map" src="metbase/Met Council Base Map
Layers" status="on" legend="false" />
            <layer title="2008 Aerial Photographs" src="lmic/fsa2008"
status="off" legend="false" />
            <layer title="1997 Aerial Photographs" src="lmic/bw1997"
            <layer title="USGS DOQs" src="usgs_doq/DOQ" status="off"
fade="true" unfade="true" legend="false" />
            <layer title="USGS Topo Quads" src="usgs_drg/DRG" status="off"
            <layer title="None" src=" " status="off" legend="false"
fade="false" unfade="false" />
        </group> -->
    </catalog>
        The toolbar defines which services are referneces in the toolbar
    <toolbar>
        <tool name="previous" title="Previous Extent" type="internal"
action="previous" selectable="false"/>
        <tool name="next" title="Next Extent" type="internal" action="next"
        <tool name="fullextent" title="Zoom to Full Extent" type="internal"
action="fullextent" selectable="false"/>
        <tool name="pan" title="Pan" type="internal" action="pan"/>
        <tool name="zoomin" title="Zoom In" type="internal" action="zoomin"
selected="true"/>
        <tool name="zoomout" title="Zoom Out" type="internal"
action="zoomout"/>
        <!--    <tool name="identify" title="Identify" type="service"
service="identify" cursor="url('cursors/identify2.cur') 9
9,url('cursors/identify2.cur'),auto" /> -->
<!--        <tool name="select" title="Select" type="service"
service="select"/> -->
        <!--    <tool name="buffered_select" title="Buffered Select"
type="service" service="buffered_select"/> -->
        <!--    <tool name="clear" title="Clear Selection" type="javascript"
selectable="false">
            GeoMOOSE.changeLayerVisibility('highlight/all', false);
        </tool> -->
        <tool name="measure" title="Measure" type="internal"
action="measure"/>
        <tool name="measurearea" title="Measure Area" type="internal"
action="measurearea"/>
        <!-- <tool name="search_parcels" title="Search Parcels"
type="service" service="search_parcels" selectable="false"/> -->
        <!-- <tool name="print" title="Print" type="service" service="print"
        <!-- <tool name="birdseye" title="Bird's Eye View" type="service"
selectable="true" service="birdseye"/> -->
        <!-- <tool name="streetview" title="Google Street View"
type="service" service="streetview" selectable="true"/> -->
        <!-- <tool name="geocode" title="Geocode Address" type="service"
service="geocode_address" selectable="true"/>  -->
        <!-- <drawer>
            <tool name="markup_tools" title="Sketch Tools" type="internal"
action="none" selectable="false"/>
            <tool name="draw_polygon" title="Draw Polygon" type="internal"
action="draw_polygon"/>
            <tool name="draw_line" title="Draw Line" type="internal"
action="draw_line"/>
            <tool name="draw_point" title="Draw Point" type="internal"
action="draw_point"/>
            <tool name="draw_remove" title="Remove Drawing" type="internal"
action="draw_remove"/>
            <tool name="draw_edit" title="Edit Drawing" type="internal"
action="draw_edit_shapes"/>
            <tool name="draw_edit_attributes" title="Edit Attributes"
type="internal" action="draw_edit_attributes"/>
            <tool name="clear_drawings" title="Clear Drawings"
type="internal" action="clear_drawings" selectable="false"/>
        </drawer> -->
    </toolbar>
</mapbook>
============= END OF MAPBOOK.XML =============
I have tried getting some error reporting out of firebug with little
success, if anyone can help me spot what I have done wrong it would be much
appreciated and I would be happy to supply the real url's to the server
off-list.
Cheers
Carl
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110113/62ee6437/attachment.html
More information about the Geomoose-users mailing list
