[Geomoose-users] Setting up first geomoose app
Brent Fraser bfraser at geoanalytic.com
Thu Jan 13 16:32:53 EST 2011
And while you've got a <map-source> defined, I don't think there's a
<Layer> set up to reference it.
Brent
> Carl,
> One problem is that the coordinate system is defined as longlat, but the
> extent is given is something other than decimal degrees:
>   EXTENT -990487.465830 -31957.211592 1696934.624449 1261986.757801
>   PROJECTION
>      'init=epsg:4326'
>     'proj=longlat'
>     'ellps=WGS84'
>     'datum=WGS84'
>     'no_defs'
>   END
> And in the mapbook as well.
> Brent
>> Hi,
>> trying to get a basic app working in geomoose using our own data and I
>> am
>> getting a blank map area. I have set up a simple map file in the
>> standard
>> ms4w maps folder in a folder called ArcView, I have put my map file in
>> to
>> that folder and have tested it using a browser and can see a map and am
>> able
>> to download an xml document when I do a get capabilities request.
>> The map file is as follows:
>> ============== MAP FILE =======================
>> MAP
>>   NAME "TESTMAP"
>>   # Map image size
>>   SIZE 800 800
>>   UNITS INCHES
>>   FONTSET     "../fonts/fontset.list"
>>     SYMBOLSET    "../symbols/symbol.sym"
>>   PROJECTION
>>      'init=epsg:4326'
>>     'proj=longlat'
>>     'ellps=WGS84'
>>     'datum=WGS84'
>>     'no_defs'
>>   END
>>   IMAGECOLOR 255 255 255
>>   IMAGEQUALITY 95
>>   IMAGETYPE jpeg
>>   OUTPUTFORMAT
>>     NAME jpeg
>>     DRIVER 'GD/JPEG'
>>     MIMETYPE 'image/jpeg'
>>     IMAGEMODE RGBA
>>     EXTENSION 'jpeg'
>>   END
>>   LEGEND
>>     STATUS ON
>>     KEYSIZE 18 12
>>     LABEL
>>       TYPE BITMAP
>>       SIZE MEDIUM
>>       COLOR 0 0 89
>>     END
>>   END
>>   WEB
>>     IMAGEPATH '/tmp/'
>>     IMAGEURL '/tmp/'
>>     METADATA
>>       'ows_title'           'TESTMAP'
>>       'ows_onlineresource'  'http://www.*ourserver*
>> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>>       'ows_srs'             'EPSG:4326'
>>     END
>>     TEMPLATE 'foo'
>>   END
>>   LAYER
>>     NAME 'RECTANGLES'
>>     TYPE POLYGON
>>     DUMP true
>>     TEMPLATE fooOnlyForWMSGetFeatureInfo
>>     DATA 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>>     METADATA
>>       'ows_title' 'rectangles'
>>     END
>>     STATUS OFF
>>     TRANSPARENCY 100
>>     PROJECTION
>>     'init=epsg:4326'
>>     'proj=longlat'
>>     'ellps=WGS84'
>>     'datum=WGS84'
>>     'no_defs'
>>     END
>>     CLASS
>>        NAME 'seamless_rectangle'
>>        STYLE
>>          WIDTH 1
>>          OUTLINECOLOR 0 0 0
>>          COLOR 149 170 154
>>        END
>>     END
>>   END
>> END
>> =============== END OF MAP FILE=================
>> The map book .xml is as follows, just a commented out version of the
>> original one:
>> ============== MAPBOOK.XML ===================
>> <?xml version="1.0"?>
>> <mapbook version="2.0">
>>     <configuration>
>>             <param name="links_bar_html"><![CDATA[Perfect timing for
>> some
>> damn CDATA "all" of 'its' here <&>]]></param>
>>             <param name="layer_controls.unfade.on">false</param>
>>         <!--    <param name="zoomto['Jump To:']"><![CDATA[
>>             'Dakota County' :
>> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
>>             'Parcel Data' :
>> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>>             'Full State of MN' :
>> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>>         ]]></param> -->
>>         <param
>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
>>         <param
>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
>>         <param name="layer_controls.legend.on">false</param>
>>         <param name="mapserver_url">/cgi-bin/mapserv.exe</param>
>>         <param name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>>         <param name="projection">EPSG:4326</param>
>>         <param name="layer_controls.up.on">false</param>
>>         <param name="layer_controls.down.on">false</param>
>>         <param name="layer_controls.legend.on">true</param>
>>         <param name="drawing_tools.default_fill">red</param>
>>         <param name="drawing_tools.default_stroke">yellow</param>
>>         <param name="drawing_tools.default_opacity">1</param>
>>         <param name="group_checkboxes">false</param>
>>         <param name="default_tab">Catalog</param>
>>         <param name="catalog_name">Catalog</param>
>>         <param name="show_service_settings_in">Information</param>
>>         <param name="show_results_in">Information</param>
>>         <param name="tabs"><![CDATA[
>>              'Catalog' : 'catalog-tab',
>>              'Information' : 'information-tab',
>>              'Custom' : 'custom-tab'
>>          ]]></param>
>>         <param name="ground_units">km</param>
>>         <param
>> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>>         <param name="reference_map.enabled">false</param>
>>         <param name="coordinate_display.usng">false</param>
>>         <param name="jumpto_scales"><![CDATA[
>>             '1:50000' : 50000,
>>             '1:24000' : 24000,
>>             '1:10000' : 10000,
>>             '1:5000' : 5000
>>     ]]></param>
>>     </configuration>
>>         The mapping services define the source of the mapping data.
>>     <map-source name="highlight" type="mapserver">
>>         <file/>
>>         <layer name="all"/>
>>     </map-source>
>>     <map-source name="TESTMAP" type="mapserver">
>>         <file>./ArcView/testshp.map</file>
>>         <layer name="rectangles"/>
>>     </map-source>
>>     <!--    <map-source name="borders" type="mapserver"
>> reference="true">
>>         <file>./demo/statedata/basemap.map</file>
>>         <layer name="all"/>
>>     </map-source>
>>     <map-source name="iastate" type="wms" tiled="false"
>> projection="EPSG:900913" width="512" height="512">
>>         <url>http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>> </url>
>>         <layer name="nexrad-n0r"/>
>>         <param name="format" value="image/jpeg"/>
>>         <param name="TRANSPARENT" value="TRUE"/>
>>     </map-source>
>>     <map-source name="metbase" type="ags" >
>>         <url>
>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
>> </url>
>>         <layer name="Met Council Base Map Layers" />
>>         <param name="FORMAT" value="JPG"/>
>>     </map-source>
>>     <map-source name="lmic" type="wms" tiled="false">
>>         <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>>         <layer name="fsa2008"/>
>>         <layer name="bw1997"/>
>>     </map-source>
>>     <map-source name="usgs_doq" type="wms" tiled="false"
>> projection='EPSG:26915'>
>>         <url>http://terraservice.net/ogcmap.ashx?</url>
>>         <layer name="DOQ"/>
>>     </map-source>
>>     <map-source name="usgs_drg" type="wms" tiled="false"
>>         <layer name="DRG"/>
>>     </map-source>
>>     <map-source name="reference" type="wms" tiled="false"
>> reference="true">
>>         <layer name="fsa2008" reference="true" />
>>     </map-source> -->
>>     <service name="print" title="Print Map">
>>         <step type="input">
>>             <url>php/print.php</url>
>>             <input type="print_info" name="layers"/>
>>             <input type="extent" name="extent"/>
>>             <input type="sketches" name="sketches"/>
>>             <input type="user" name="title" title="Map
>> Title">Map</input>
>>             <input type="hidden" name="date" title="Map
>> Date">true</input>
>>             <input type="select" name="template" title="Output Template:
>>                 <option value="letter_landscape">Letter -
>> Landscape</option>
>>                 <option value="letter_portrait">Letter -
>> Portrait</option>
>>                 <option value="poster_landscape">11" x 17" -
>> Landscape</option>
>>                 <option value="poster_portrait">11" x 17" -
>> Portrait</option>
>>             </input>
>>             <input type="select" name="quality" title="Image Quality: ">
>>                 <option value="2">Higher</option>
>>                 <option value="3">Highest</option>
>>                 <option value="1">Standard</option>
>>             </input>
>>             <input type="select" name="scale" title="Preserve Scale: ">
>>                 <option value="preserve">Yes</option>
>>                 <option value="no">No</option>
>>             </input>
>>         </step>
>>     </service>
>>     <service name="identify" title="Identify" display="false">
>>         <url>php/identify.php</url>
>>         <step type="spatial" name="shape" line="false" polygon="false"
>> jump-start="true" default="point">
>>             <input type="visiblelayers" name="layers"/>
>>         </step>
>>     </service>
>>     <service name="birdseye" display="false" target="_blank">
>>         <url>php/birdseye.php</url>
>>         <step type="spatial" name="xy" line="false" polygon="false"
>> jump-start="true" default="point" format="delim" reproject="EPSG:4326">
>>         </step>
>>     </service>
>>     <service name="streetview" display="false" target="_blank">
>>         <url>php/streetview.php</url>
>>         </step>
>>     </service>
>>     <service name="feature_report" display="false">
>>         <url>php/feature_report.php</url>
>>         <input type="hidden" name="layers" value="lmic/fsa"/>
>>         <input type="hidden" name="src"/>
>>         <input type="hidden" name="PIN"/>
>>     </service>
>>     <service name="select" title="Select">
>>         <url>php/select.php</url>
>>         <!-- Send a selection shape + the visible layers list to the
>> service
>>         <step type="spatial" showTools="true" name="shape" line="true"
>> polygon="true" point="true" default="polygon" edit-polygon="false"
>> pan="false" jump-start="true">
>>             <header><![CDATA[Create a selection area by clicking on the
>> map.]]></header>
>>                 Option values should be the mapbook path to the layer.
>>                 This only supports 'mapserver'-type layers.
>>             <input type="select" name="select_layer" title="Select:">
>>                 <option value="parcels/parcels">Parcels</option>
>>             </input>
>>             <input type="user" name="shape_buffer" title="Buffer
>> Selection
>> Shape (ft)">0</input>
>>             <input type="select" name="query_layer" title="Using
>> Features
>> In">
>>             </input>
>> Selection
>>             <footnote><![CDATA[
>>             ]]></footnote>
>>         </step>
>>     </service>
>>     <!-- this is called after a standard select in order to buffer the
>> previous selection -->
>>     <service name="buffered_select_followup" title="Buffered Select">
>>         <step type="input">
>>             <input type="hidden" name="shape"/>
>>             <input type="hidden" name="select_layer"/>
>>             <input type="hidden" name="query_layer"/>
>>             <input type="hidden" name="shape_buffer"/>
>>             <input type="user" name="selection_buffer" title="Buffer
>> Features By: "/>
>>         </step>
>>     </service>
>>     <service name="buffered_select" title="Buffered Select">
>> service
>> pan="false">
>> map.]]></header>
>> features
>> from:">
>>             </input>
>> Selected Features (ft)">0</input>
>> <!--            <input type="user" name="shape_buffer" title="Buffer
>> Selection Shape (ft)">0</input>
>> Features
>> In">
>>             </input>
>>             <footnote><![CDATA[
>>             ]]></footnote>
>>         </step>
>>     </service>
>>     <service name="popups" display="false">
>>         <url>php/popups.php</url>
>>             <header><![CDATA[
>>             Click on the map to show a popup about the features.
>>             ]]></header>
>>             <input type="hidden" name="layer"/>
>>         </step>
>>     </service>
>>     <service name="geocode_address" title="Geocode Address">
>>         <url>php/geocode.php</url>
>>         <step type="input">
>>             <input type="user" name="address" title="Enter Address: "/>
>>             <input type="hidden" name="googlekey"
>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>>         </step>
>>     </service>
>>     <service name="search_parcels">
>>         <url>php/query.php</url>
>>         <step type="input">
>>             <input type="hidden" name="highlight" value="true"/>
>>             <input type="hidden" name="mode" value="search"/>
>>             <input type="hidden" name="layer0" value="parcels/parcels"/>
>>             <input type="hidden" name="template0" value="itemquery"/>
>>             <input type="select" name="fieldname0" title="Search By:">
>>                 <option value="OWNER_NAME">Owner</option>
>>                 <option value="PIN">Parcel ID</option>
>>             </input>
>>             <input type="select" name="comparitor0" title="That: ">
>>                 <option value="like-icase">Contains</option>
>>                 <option value="right-like-icase">Begins With</option>
>>                 <option value="eq-str">Matches Exactly</option>
>>             </input>
>>             <input type="user" name="value0" title=""/>
>>             <input type="hidden" name="fieldname1" value="FIN_SQ_FT"/>
>>             <input type="select" name="operator1">
>>                 <option value="or">OR</option>
>>                 <option value="and">AND</option>
>>             </input>
>>             <input type="select" name="comparitor1" title="Having Fin.
>> Sq.
>> Ft. ">
>>                 <option value="gt">Greater Than</option>
>>                 <option value="eq">Equal To</option>
>>                 <option value="lt">Less Than</option>
>>             </input>
>>             <input type="user" name="value1" title=""/>
>>         </step>
>>     </service>
>>         The catalog defines how the layers will be displayed in the
>> catalog
>> tab.
>>     <layer-controls>
>>         <layer-control name="popups" service-name="popups"
>> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
>>     </layer-controls>
>>     <catalog>
>>     <!--     <layer title="overallmap" src="parcels/parcels" status="on"
>> popups="true" minscale="0" maxscale="150000" metadata="true" >
>>             <metadata>http://www.aqua3.com</metadata>
>>         </layer>
>>         <layer title="City and County Boundaries" src="borders/all"
>> status="on"/>
>>         <layer title="Weather Radar" src="iastate/nexrad-n0r"
>> status="off"
>> legend="false"/>
>>         <group title="Backgrounds" expand="true" multiple="false">
>>             <layer title="Metro Base Map" src="metbase/Met Council Base
>> Map
>> Layers" status="on" legend="false" />
>>             <layer title="2008 Aerial Photographs" src="lmic/fsa2008"
>> status="off" legend="false" />
>>             <layer title="1997 Aerial Photographs" src="lmic/bw1997"
>>             <layer title="USGS DOQs" src="usgs_doq/DOQ" status="off"
>> fade="true" unfade="true" legend="false" />
>>             <layer title="USGS Topo Quads" src="usgs_drg/DRG"
>> status="off"
>>             <layer title="None" src=" " status="off" legend="false"
>> fade="false" unfade="false" />
>>         </group> -->
>>     </catalog>
>>         The toolbar defines which services are referneces in the toolbar
>>     <toolbar>
>>         <tool name="previous" title="Previous Extent" type="internal"
>> action="previous" selectable="false"/>
>>         <tool name="next" title="Next Extent" type="internal"
>> action="next"
>>         <tool name="fullextent" title="Zoom to Full Extent"
>> type="internal"
>> action="fullextent" selectable="false"/>
>>         <tool name="pan" title="Pan" type="internal" action="pan"/>
>>         <tool name="zoomin" title="Zoom In" type="internal"
>> action="zoomin"
>> selected="true"/>
>>         <tool name="zoomout" title="Zoom Out" type="internal"
>> action="zoomout"/>
>>         <!--    <tool name="identify" title="Identify" type="service"
>> service="identify" cursor="url('cursors/identify2.cur') 9
>> 9,url('cursors/identify2.cur'),auto" /> -->
>> <!--        <tool name="select" title="Select" type="service"
>> service="select"/> -->
>>         <!--    <tool name="buffered_select" title="Buffered Select"
>> type="service" service="buffered_select"/> -->
>>         <!--    <tool name="clear" title="Clear Selection"
>> type="javascript"
>> selectable="false">
>>             GeoMOOSE.changeLayerVisibility('highlight/all', false);
>>         </tool> -->
>>         <tool name="measure" title="Measure" type="internal"
>> action="measure"/>
>>         <tool name="measurearea" title="Measure Area" type="internal"
>> action="measurearea"/>
>>         <!-- <tool name="search_parcels" title="Search Parcels"
>> type="service" service="search_parcels" selectable="false"/> -->
>>         <!-- <tool name="print" title="Print" type="service"
>> service="print"
>>         <!-- <tool name="birdseye" title="Bird's Eye View"
>> type="service"
>> selectable="true" service="birdseye"/> -->
>>         <!-- <tool name="streetview" title="Google Street View"
>> type="service" service="streetview" selectable="true"/> -->
>>         <!-- <tool name="geocode" title="Geocode Address" type="service"
>> service="geocode_address" selectable="true"/>  -->
>>         <!-- <drawer>
>>             <tool name="markup_tools" title="Sketch Tools"
>> type="internal"
>> action="none" selectable="false"/>
>>             <tool name="draw_polygon" title="Draw Polygon"
>> type="internal"
>> action="draw_polygon"/>
>>             <tool name="draw_line" title="Draw Line" type="internal"
>> action="draw_line"/>
>>             <tool name="draw_point" title="Draw Point" type="internal"
>> action="draw_point"/>
>>             <tool name="draw_remove" title="Remove Drawing"
>> type="internal"
>> action="draw_remove"/>
>>             <tool name="draw_edit" title="Edit Drawing" type="internal"
>> action="draw_edit_shapes"/>
>>             <tool name="draw_edit_attributes" title="Edit Attributes"
>> type="internal" action="draw_edit_attributes"/>
>>             <tool name="clear_drawings" title="Clear Drawings"
>> type="internal" action="clear_drawings" selectable="false"/>
>>         </drawer> -->
>>     </toolbar>
>> </mapbook>
>> ============= END OF MAPBOOK.XML =============
>> I have tried getting some error reporting out of firebug with little
>> success, if anyone can help me spot what I have done wrong it would be
>> much
>> appreciated and I would be happy to supply the real url's to the server
>> off-list.
>> Cheers
>> Carl
>> Protect Your Site and Customers from Malware Attacks
>> Learn about various malware tactics and how to avoid them. Understand
>> malware threats, the impact they can have on your business, and how you
>> can protect your company and customers by using code signing.
>> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Best Regards
> Brent Fraser
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
