[Geomoose-users] Setting up first geomoose app
Brent Fraser bfraser at geoanalytic.com
Fri Jan 14 10:21:03 EST 2011
Carl,
  You still haven't corrected the extents to match your projection.  Until
you do it won't work.
Which coordinate system do you want to use for display? longlat or tmerc?
Brent
> Hi,
> yep sorry my error, I have altered the units to DD but am not really any
> further forward, I took a look at the data for the layers I need to add
> and
> I think I may need to either alter the projections section in the map file
> or reproject the data.
> When I check the properties of the file in qgis I get the following:
> +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
> +ellps=airy +datum=OSGB36 +units=m +no_defs
> Luckily I only need to worry about three data files and they are all
> identical in terms of the projection information I can see from the
> properties dialogue boxes in qgis.
> Does this sound reasonable?
> Cheers
> Carl
> On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman <Johan.Forsman at la.gov>
> wrote:
>> The extent sections in both of your attached files are still in units
>> incompatible with your chosen projection. Did you perhaps attach
>> uncorrected
>> versions?
>> You indicate units of INCHES in the MAP file but WGS84 is defined by
>> decimal degrees (DD). If you are in the UK you ought to be inside a box
>> described by (-11 49 2 61), or something similar to that provided I have
>> the
>> bottom-left top-right sequence correct.
>> /Johan.
>> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
>> *Sent:* Friday, January 14, 2011 5:35 AM
>> *To:* geomoose-users at lists.sourceforge.net
>> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
>> Hi, still banging up against a brick wall with this one. I have taken
>> some
>> advice and resolved the extent issues in my map file and xml file. I
>> have
>> also modified the map and xml files so that they are considerably
>> simpler,
>> figuring that if its simpler it will be easier to spot my mistakes. I
>> have
>> attached the two files to this mail, not sure if this is allowed on the
>> listserver.
>> Here is what else I have tried:
>> 1. Ran the mapfile through shp2img and it is not generating any error
>> messages at all, though the time to draw the layer comes in at 0.000s
>> which
>> seems odd to me.
>> 2. Ran a get capabilities request on the map file and got the xml back,
>> this is not reporting any errors.
>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:\ms4w\apps\geomoose2\maps\arcview\testshp.map<http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png>
>> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>> 3. Ran a get map request to generate a map image, again I can see this
>> without any errors.
>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png<http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png>
>> 4. Connected to the wms layer with QGIS as my client, the map image
>> appears
>> with no errors.
>> I am totally lost at this point and have no idea why the map image is
>> not
>> appearing, any clues would be most welcome.
>> Carl
>> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>> And while you've got a <map-source> defined, I don't think there's a
>> <Layer> set up to reference it.
>> Brent
>> > Carl,
>> > One problem is that the coordinate system is defined as longlat, but
>> the
>> > extent is given is something other than decimal degrees:
>> >   EXTENT -990487.465830 -31957.211592 1696934.624449 1261986.757801
>> >   PROJECTION
>> >      'init=epsg:4326'
>> >     'proj=longlat'
>> >     'ellps=WGS84'
>> >     'datum=WGS84'
>> >     'no_defs'
>> >   END
>> > And in the mapbook as well.
>> > Brent
>> >> Hi,
>> >> trying to get a basic app working in geomoose using our own data and
>> I
>> >> am
>> >> getting a blank map area. I have set up a simple map file in the
>> >> standard
>> >> ms4w maps folder in a folder called ArcView, I have put my map file
>> in
>> >> to
>> >> that folder and have tested it using a browser and can see a map and
>> am
>> >> able
>> >> to download an xml document when I do a get capabilities request.
>> >> The map file is as follows:
>> >> ============== MAP FILE =======================
>> >> MAP
>> >>   NAME "TESTMAP"
>> >>   # Map image size
>> >>   SIZE 800 800
>> >>   UNITS INCHES
>> >>   FONTSET     "../fonts/fontset.list"
>> >>     SYMBOLSET    "../symbols/symbol.sym"
>> >>   PROJECTION
>> >>      'init=epsg:4326'
>> >>     'proj=longlat'
>> >>     'ellps=WGS84'
>> >>     'datum=WGS84'
>> >>     'no_defs'
>> >>   END
>> >>   IMAGECOLOR 255 255 255
>> >>   IMAGEQUALITY 95
>> >>   IMAGETYPE jpeg
>> >>   OUTPUTFORMAT
>> >>     NAME jpeg
>> >>     DRIVER 'GD/JPEG'
>> >>     MIMETYPE 'image/jpeg'
>> >>     IMAGEMODE RGBA
>> >>     EXTENSION 'jpeg'
>> >>   END
>> >>   LEGEND
>> >>     STATUS ON
>> >>     KEYSIZE 18 12
>> >>     LABEL
>> >>       TYPE BITMAP
>> >>       SIZE MEDIUM
>> >>       COLOR 0 0 89
>> >>     END
>> >>   END
>> >>   WEB
>> >>     IMAGEPATH '/tmp/'
>> >>     IMAGEURL '/tmp/'
>> >>     METADATA
>> >>       'ows_title'           'TESTMAP'
>> >>       'ows_onlineresource'  'http://www.*ourserver*
>> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>> >>       'ows_srs'             'EPSG:4326'
>> >>     END
>> >>     TEMPLATE 'foo'
>> >>   END
>> >>   LAYER
>> >>     NAME 'RECTANGLES'
>> >>     TYPE POLYGON
>> >>     DUMP true
>> >>     TEMPLATE fooOnlyForWMSGetFeatureInfo
>> >>     DATA 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>> >>     METADATA
>> >>       'ows_title' 'rectangles'
>> >>     END
>> >>     STATUS OFF
>> >>     TRANSPARENCY 100
>> >>     PROJECTION
>> >>     'init=epsg:4326'
>> >>     'proj=longlat'
>> >>     'ellps=WGS84'
>> >>     'datum=WGS84'
>> >>     'no_defs'
>> >>     END
>> >>     CLASS
>> >>        NAME 'seamless_rectangle'
>> >>        STYLE
>> >>          WIDTH 1
>> >>          OUTLINECOLOR 0 0 0
>> >>          COLOR 149 170 154
>> >>        END
>> >>     END
>> >>   END
>> >> END
>> >> =============== END OF MAP FILE=================
>> >> The map book .xml is as follows, just a commented out version of the
>> >> original one:
>> >> ============== MAPBOOK.XML ===================
>> >> <?xml version="1.0"?>
>> >> <mapbook version="2.0">
>> >>     <configuration>
>> >>             <param name="links_bar_html"><![CDATA[Perfect timing for
>> >> some
>> >> damn CDATA "all" of 'its' here <&>]]></param>
>> >>             <param name="layer_controls.unfade.on">false</param>
>> >>         <!--    <param name="zoomto['Jump To:']"><![CDATA[
>> >>             'Dakota County' :
>> >> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
>> >>             'Parcel Data' :
>> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>> >>             'Full State of MN' :
>> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>> >>         ]]></param> -->
>> >>         <param
>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
>> >>         <param
>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
>> >>         <param name="layer_controls.legend.on">false</param>
>> >>         <param name="mapserver_url">/cgi-bin/mapserv.exe</param>
>> >>         <param name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>> >>         <param name="projection">EPSG:4326</param>
>> >>         <param name="layer_controls.up.on">false</param>
>> >>         <param name="layer_controls.down.on">false</param>
>> >>         <param name="layer_controls.legend.on">true</param>
>> >>         <param name="drawing_tools.default_fill">red</param>
>> >>         <param name="drawing_tools.default_stroke">yellow</param>
>> >>         <param name="drawing_tools.default_opacity">1</param>
>> >>         <param name="group_checkboxes">false</param>
>> >>         <param name="default_tab">Catalog</param>
>> >>         <param name="catalog_name">Catalog</param>
>> >>         <param name="show_service_settings_in">Information</param>
>> >>         <param name="show_results_in">Information</param>
>> >>         <param name="tabs"><![CDATA[
>> >>              'Catalog' : 'catalog-tab',
>> >>              'Information' : 'information-tab',
>> >>              'Custom' : 'custom-tab'
>> >>          ]]></param>
>> >>         <param name="ground_units">km</param>
>> >>         <param
>> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>> >>         <param name="reference_map.enabled">false</param>
>> >>         <param name="coordinate_display.usng">false</param>
>> >>         <param name="jumpto_scales"><![CDATA[
>> >>             '1:50000' : 50000,
>> >>             '1:24000' : 24000,
>> >>             '1:10000' : 10000,
>> >>             '1:5000' : 5000
>> >>     ]]></param>
>> >>     </configuration>
>> >>         The mapping services define the source of the mapping data.
>> >>     <map-source name="highlight" type="mapserver">
>> >>         <file/>
>> >>         <layer name="all"/>
>> >>     </map-source>
>> >>     <map-source name="TESTMAP" type="mapserver">
>> >>         <file>./ArcView/testshp.map</file>
>> >>         <layer name="rectangles"/>
>> >>     </map-source>
>> >>     <!--    <map-source name="borders" type="mapserver"
>> >> reference="true">
>> >>         <file>./demo/statedata/basemap.map</file>
>> >>         <layer name="all"/>
>> >>     </map-source>
>> >>     <map-source name="iastate" type="wms" tiled="false"
>> >> projection="EPSG:900913" width="512" height="512">
>> >>         <url>
>> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>> >> </url>
>> >>         <layer name="nexrad-n0r"/>
>> >>         <param name="format" value="image/jpeg"/>
>> >>         <param name="TRANSPARENT" value="TRUE"/>
>> >>     </map-source>
>> >>     <map-source name="metbase" type="ags" >
>> >>         <url>
>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
>> >> </url>
>> >>         <layer name="Met Council Base Map Layers" />
>> >>         <param name="FORMAT" value="JPG"/>
>> >>     </map-source>
>> >>     <map-source name="lmic" type="wms" tiled="false">
>> >>         <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>> >>         <layer name="fsa2008"/>
>> >>         <layer name="bw1997"/>
>> >>     </map-source>
>> >>     <map-source name="usgs_doq" type="wms" tiled="false"
>> >> projection='EPSG:26915'>
>> >>         <url>http://terraservice.net/ogcmap.ashx?</url>
>> >>         <layer name="DOQ"/>
>> >>     </map-source>
>> >>     <map-source name="usgs_drg" type="wms" tiled="false"
>> >>         <layer name="DRG"/>
>> >>     </map-source>
>> >>     <map-source name="reference" type="wms" tiled="false"
>> >> reference="true">
>> >>         <layer name="fsa2008" reference="true" />
>> >>     </map-source> -->
>> >>     <service name="print" title="Print Map">
>> >>         <step type="input">
>> >>             <url>php/print.php</url>
>> >>             <input type="print_info" name="layers"/>
>> >>             <input type="extent" name="extent"/>
>> >>             <input type="sketches" name="sketches"/>
>> >>             <input type="user" name="title" title="Map
>> >> Title">Map</input>
>> >>             <input type="hidden" name="date" title="Map
>> >> Date">true</input>
>> >>             <input type="select" name="template" title="Output
>> Template:
>> >>                 <option value="letter_landscape">Letter -
>> >> Landscape</option>
>> >>                 <option value="letter_portrait">Letter -
>> >> Portrait</option>
>> >>                 <option value="poster_landscape">11" x 17" -
>> >> Landscape</option>
>> >>                 <option value="poster_portrait">11" x 17" -
>> >> Portrait</option>
>> >>             </input>
>> >>             <input type="select" name="quality" title="Image Quality:
>> >>                 <option value="2">Higher</option>
>> >>                 <option value="3">Highest</option>
>> >>                 <option value="1">Standard</option>
>> >>             </input>
>> >>             <input type="select" name="scale" title="Preserve Scale:
>> >>                 <option value="preserve">Yes</option>
>> >>                 <option value="no">No</option>
>> >>             </input>
>> >>         </step>
>> >>     </service>
>> >>     <service name="identify" title="Identify" display="false">
>> >>         <url>php/identify.php</url>
>> >>         <step type="spatial" name="shape" line="false"
>> polygon="false"
>> >> jump-start="true" default="point">
>> >>             <input type="visiblelayers" name="layers"/>
>> >>         </step>
>> >>     </service>
>> >>     <service name="birdseye" display="false" target="_blank">
>> >>         <url>php/birdseye.php</url>
>> >>         <step type="spatial" name="xy" line="false" polygon="false"
>> >> jump-start="true" default="point" format="delim"
>> reproject="EPSG:4326">
>> >>         </step>
>> >>     </service>
>> >>     <service name="streetview" display="false" target="_blank">
>> >>         <url>php/streetview.php</url>
>> >>         </step>
>> >>     </service>
>> >>     <service name="feature_report" display="false">
>> >>         <url>php/feature_report.php</url>
>> >>         <input type="hidden" name="layers" value="lmic/fsa"/>
>> >>         <input type="hidden" name="src"/>
>> >>         <input type="hidden" name="PIN"/>
>> >>     </service>
>> >>     <service name="select" title="Select">
>> >>         <url>php/select.php</url>
>> >>         <!-- Send a selection shape + the visible layers list to the
>> >> service
>> >>         <step type="spatial" showTools="true" name="shape"
>> line="true"
>> >> polygon="true" point="true" default="polygon" edit-polygon="false"
>> >> pan="false" jump-start="true">
>> >>             <header><![CDATA[Create a selection area by clicking on
>> the
>> >> map.]]></header>
>> >>                 Option values should be the mapbook path to the
>> layer.
>> >>                 This only supports 'mapserver'-type layers.
>> >>             <input type="select" name="select_layer" title="Select:">
>> >>                 <option value="parcels/parcels">Parcels</option>
>> >>             </input>
>> >>             <input type="user" name="shape_buffer" title="Buffer
>> >> Selection
>> >> Shape (ft)">0</input>
>> >>             <input type="select" name="query_layer" title="Using
>> >> Features
>> >> In">
>> >>             </input>
>> >> Selection
>> >>             <footnote><![CDATA[
>> >>             ]]></footnote>
>> >>         </step>
>> >>     </service>
>> >>     <!-- this is called after a standard select in order to buffer
>> the
>> >> previous selection -->
>> >>     <service name="buffered_select_followup" title="Buffered Select">
>> >>         <step type="input">
>> >>             <input type="hidden" name="shape"/>
>> >>             <input type="hidden" name="select_layer"/>
>> >>             <input type="hidden" name="query_layer"/>
>> >>             <input type="hidden" name="shape_buffer"/>
>> >>             <input type="user" name="selection_buffer" title="Buffer
>> >> Features By: "/>
>> >>         </step>
>> >>     </service>
>> >>     <service name="buffered_select" title="Buffered Select">
>> >> service
>> line="true"
>> >> pan="false">
>> the
>> >> map.]]></header>
>> layer.
>> >> features
>> >> from:">
>> >>             </input>
>> >> Selected Features (ft)">0</input>
>> >> <!--            <input type="user" name="shape_buffer" title="Buffer
>> >> Selection Shape (ft)">0</input>
>> >> Features
>> >> In">
>> >>             </input>
>> >>             <footnote><![CDATA[
>> >>             ]]></footnote>
>> >>         </step>
>> >>     </service>
>> >>     <service name="popups" display="false">
>> >>         <url>php/popups.php</url>
>> polygon="false"
>> >>             <header><![CDATA[
>> >>             Click on the map to show a popup about the features.
>> >>             ]]></header>
>> >>             <input type="hidden" name="layer"/>
>> >>         </step>
>> >>     </service>
>> >>     <service name="geocode_address" title="Geocode Address">
>> >>         <url>php/geocode.php</url>
>> >>         <step type="input">
>> >>             <input type="user" name="address" title="Enter Address:
>> >>             <input type="hidden" name="googlekey"
>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>> >>         </step>
>> >>     </service>
>> >>     <service name="search_parcels">
>> >>         <url>php/query.php</url>
>> >>         <step type="input">
>> >>             <input type="hidden" name="highlight" value="true"/>
>> >>             <input type="hidden" name="mode" value="search"/>
>> >>             <input type="hidden" name="layer0"
>> value="parcels/parcels"/>
>> >>             <input type="hidden" name="template0" value="itemquery"/>
>> >>             <input type="select" name="fieldname0" title="Search
>> By:">
>> >>                 <option value="OWNER_NAME">Owner</option>
>> >>                 <option value="PIN">Parcel ID</option>
>> >>             </input>
>> >>             <input type="select" name="comparitor0" title="That: ">
>> >>                 <option value="like-icase">Contains</option>
>> >>                 <option value="right-like-icase">Begins With</option>
>> >>                 <option value="eq-str">Matches Exactly</option>
>> >>             </input>
>> >>             <input type="user" name="value0" title=""/>
>> >>             <input type="hidden" name="fieldname1"
>> value="FIN_SQ_FT"/>
>> >>             <input type="select" name="operator1">
>> >>                 <option value="or">OR</option>
>> >>                 <option value="and">AND</option>
>> >>             </input>
>> >>             <input type="select" name="comparitor1" title="Having
>> Fin.
>> >> Sq.
>> >> Ft. ">
>> >>                 <option value="gt">Greater Than</option>
>> >>                 <option value="eq">Equal To</option>
>> >>                 <option value="lt">Less Than</option>
>> >>             </input>
>> >>             <input type="user" name="value1" title=""/>
>> >>         </step>
>> >>     </service>
>> >>         The catalog defines how the layers will be displayed in the
>> >> catalog
>> >> tab.
>> >>     <layer-controls>
>> >>         <layer-control name="popups" service-name="popups"
>> >> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
>> >>     </layer-controls>
>> >>     <catalog>
>> >>     <!--     <layer title="overallmap" src="parcels/parcels"
>> status="on"
>> >> popups="true" minscale="0" maxscale="150000" metadata="true" >
>> >>             <metadata>http://www.aqua3.com</metadata>
>> >>         </layer>
>> >>         <layer title="City and County Boundaries" src="borders/all"
>> >> status="on"/>
>> >>         <layer title="Weather Radar" src="iastate/nexrad-n0r"
>> >> status="off"
>> >> legend="false"/>
>> >>         <group title="Backgrounds" expand="true" multiple="false">
>> >>             <layer title="Metro Base Map" src="metbase/Met Council
>> Base
>> >> Map
>> >> Layers" status="on" legend="false" />
>> >>             <layer title="2008 Aerial Photographs" src="lmic/fsa2008"
>> >> status="off" legend="false" />
>> >>             <layer title="1997 Aerial Photographs" src="lmic/bw1997"
>> >>             <layer title="USGS DOQs" src="usgs_doq/DOQ" status="off"
>> >> fade="true" unfade="true" legend="false" />
>> >>             <layer title="USGS Topo Quads" src="usgs_drg/DRG"
>> >> status="off"
>> >>             <layer title="None" src=" " status="off" legend="false"
>> >> fade="false" unfade="false" />
>> >>         </group> -->
>> >>     </catalog>
>> >>         The toolbar defines which services are referneces in the
>> toolbar
>> >>     <toolbar>
>> >>         <tool name="previous" title="Previous Extent" type="internal"
>> >> action="previous" selectable="false"/>
>> >>         <tool name="next" title="Next Extent" type="internal"
>> >> action="next"
>> >>         <tool name="fullextent" title="Zoom to Full Extent"
>> >> type="internal"
>> >> action="fullextent" selectable="false"/>
>> >>         <tool name="pan" title="Pan" type="internal" action="pan"/>
>> >>         <tool name="zoomin" title="Zoom In" type="internal"
>> >> action="zoomin"
>> >> selected="true"/>
>> >>         <tool name="zoomout" title="Zoom Out" type="internal"
>> >> action="zoomout"/>
>> >>         <!--    <tool name="identify" title="Identify" type="service"
>> >> service="identify" cursor="url('cursors/identify2.cur') 9
>> >> 9,url('cursors/identify2.cur'),auto" /> -->
>> >> <!--        <tool name="select" title="Select" type="service"
>> >> service="select"/> -->
>> >>         <!--    <tool name="buffered_select" title="Buffered Select"
>> >> type="service" service="buffered_select"/> -->
>> >>         <!--    <tool name="clear" title="Clear Selection"
>> >> type="javascript"
>> >> selectable="false">
>> >>             GeoMOOSE.changeLayerVisibility('highlight/all', false);
>> >>         </tool> -->
>> >>         <tool name="measure" title="Measure" type="internal"
>> >> action="measure"/>
>> >>         <tool name="measurearea" title="Measure Area" type="internal"
>> >> action="measurearea"/>
>> >>         <!-- <tool name="search_parcels" title="Search Parcels"
>> >> type="service" service="search_parcels" selectable="false"/> -->
>> >>         <!-- <tool name="print" title="Print" type="service"
>> >> service="print"
>> >>         <!-- <tool name="birdseye" title="Bird's Eye View"
>> >> type="service"
>> >> selectable="true" service="birdseye"/> -->
>> >>         <!-- <tool name="streetview" title="Google Street View"
>> >> type="service" service="streetview" selectable="true"/> -->
>> >>         <!-- <tool name="geocode" title="Geocode Address"
>> type="service"
>> >> service="geocode_address" selectable="true"/>  -->
>> >>         <!-- <drawer>
>> >>             <tool name="markup_tools" title="Sketch Tools"
>> >> type="internal"
>> >> action="none" selectable="false"/>
>> >>             <tool name="draw_polygon" title="Draw Polygon"
>> >> type="internal"
>> >> action="draw_polygon"/>
>> >>             <tool name="draw_line" title="Draw Line" type="internal"
>> >> action="draw_line"/>
>> >>             <tool name="draw_point" title="Draw Point"
>> type="internal"
>> >> action="draw_point"/>
>> >>             <tool name="draw_remove" title="Remove Drawing"
>> >> type="internal"
>> >> action="draw_remove"/>
>> >>             <tool name="draw_edit" title="Edit Drawing"
>> type="internal"
>> >> action="draw_edit_shapes"/>
>> >>             <tool name="draw_edit_attributes" title="Edit Attributes"
>> >> type="internal" action="draw_edit_attributes"/>
>> >>             <tool name="clear_drawings" title="Clear Drawings"
>> >> type="internal" action="clear_drawings" selectable="false"/>
>> >>         </drawer> -->
>> >>     </toolbar>
>> >> </mapbook>
>> >> ============= END OF MAPBOOK.XML =============
>> >> I have tried getting some error reporting out of firebug with little
>> >> success, if anyone can help me spot what I have done wrong it would
>> be
>> >> much
>> >> appreciated and I would be happy to supply the real url's to the
>> server
>> >> off-list.
>> >> Cheers
>> >> Carl
>> >> Protect Your Site and Customers from Malware Attacks
>> >> Learn about various malware tactics and how to avoid them. Understand
>> >> malware threats, the impact they can have on your business, and how
>> you
>> >> can protect your company and customers by using code signing.
>> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
>> >> Geomoose-users mailing list
>> >> Geomoose-users at lists.sourceforge.net
>> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> > Best Regards
>> > Brent Fraser
>> you
>> Best Regards
>> Brent Fraser
> malware threats, the impact they can have on your business, and how you
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
