[Geomoose-users] Setting up first geomoose app
Brent Fraser bfraser at geoanalytic.com
Fri Jan 14 10:38:07 EST 2011
Then I'd recommend changing all the projection references in your map file
and mapbook to be:
EPSG:27700
since that matches the definition you gave for the data.  See
http://spatialreference.org/ref/epsg/27700/  for more info...
> Hi, Brent,
> I have no preferences as to the system, the files are delivered in tmerc
> so
> I guess I might as well use that as then I will not have to convert them
> should new ones become available.
> Carl
> On Fri, Jan 14, 2011 at 3:21 PM, Brent Fraser
> <bfraser at geoanalytic.com>wrote:
>> Carl,
>>  You still haven't corrected the extents to match your projection.
>> Until
>> you do it won't work.
>> Which coordinate system do you want to use for display? longlat or
>> tmerc?
>> Brent
>> > Hi,
>> > yep sorry my error, I have altered the units to DD but am not really
>> any
>> > further forward, I took a look at the data for the layers I need to
>> add
>> > and
>> > I think I may need to either alter the projections section in the map
>> file
>> > or reproject the data.
>> > When I check the properties of the file in qgis I get the following:
>> > +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
>> +y_0=-100000
>> > +ellps=airy +datum=OSGB36 +units=m +no_defs
>> > Luckily I only need to worry about three data files and they are all
>> > identical in terms of the projection information I can see from the
>> > properties dialogue boxes in qgis.
>> > Does this sound reasonable?
>> > Cheers
>> > Carl
>> > On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman <Johan.Forsman at la.gov>
>> > wrote:
>> >> The extent sections in both of your attached files are still in units
>> >> incompatible with your chosen projection. Did you perhaps attach
>> >> uncorrected
>> >> versions?
>> >> You indicate units of INCHES in the MAP file but WGS84 is defined by
>> >> decimal degrees (DD). If you are in the UK you ought to be inside a
>> box
>> >> described by (-11 49 2 61), or something similar to that provided I
>> have
>> >> the
>> >> bottom-left top-right sequence correct.
>> >> /Johan.
>> >> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
>> >> *Sent:* Friday, January 14, 2011 5:35 AM
>> >> *To:* geomoose-users at lists.sourceforge.net
>> >> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
>> >> Hi, still banging up against a brick wall with this one. I have taken
>> >> some
>> >> advice and resolved the extent issues in my map file and xml file. I
>> >> have
>> >> also modified the map and xml files so that they are considerably
>> >> simpler,
>> >> figuring that if its simpler it will be easier to spot my mistakes. I
>> >> have
>> >> attached the two files to this mail, not sure if this is allowed on
>> the
>> >> listserver.
>> >> Here is what else I have tried:
>> >> 1. Ran the mapfile through shp2img and it is not generating any error
>> >> messages at all, though the time to draw the layer comes in at 0.000s
>> >> which
>> >> seems odd to me.
>> >> 2. Ran a get capabilities request on the map file and got the xml
>> back,
>> >> this is not reporting any errors.
>> >> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d
>> :\ms4w\apps\geomoose2\maps\arcview\testshp.map<
>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png
>> >> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>> >> 3. Ran a get map request to generate a map image, again I can see
>> this
>> >> without any errors.
>> :\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png<
>> >> 4. Connected to the wms layer with QGIS as my client, the map image
>> >> appears
>> >> with no errors.
>> >> I am totally lost at this point and have no idea why the map image is
>> >> not
>> >> appearing, any clues would be most welcome.
>> >> Carl
>> >> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser
>> >> wrote:
>> >> And while you've got a <map-source> defined, I don't think there's a
>> >> <Layer> set up to reference it.
>> >> Brent
>> >> > Carl,
>> >> > One problem is that the coordinate system is defined as longlat,
>> but
>> >> the
>> >> > extent is given is something other than decimal degrees:
>> >> >   EXTENT -990487.465830 -31957.211592 1696934.624449 1261986.757801
>> >> >   PROJECTION
>> >> >      'init=epsg:4326'
>> >> >     'proj=longlat'
>> >> >     'ellps=WGS84'
>> >> >     'datum=WGS84'
>> >> >     'no_defs'
>> >> >   END
>> >> > And in the mapbook as well.
>> >> > Brent
>> >> >> Hi,
>> >> >> trying to get a basic app working in geomoose using our own data
>> and
>> >> I
>> >> >> am
>> >> >> getting a blank map area. I have set up a simple map file in the
>> >> >> standard
>> >> >> ms4w maps folder in a folder called ArcView, I have put my map
>> file
>> >> in
>> >> >> to
>> >> >> that folder and have tested it using a browser and can see a map
>> and
>> >> am
>> >> >> able
>> >> >> to download an xml document when I do a get capabilities request.
>> >> >> The map file is as follows:
>> >> >> ============== MAP FILE =======================
>> >> >> MAP
>> >> >>   NAME "TESTMAP"
>> >> >>   # Map image size
>> >> >>   SIZE 800 800
>> >> >>   UNITS INCHES
>> 1261986.757801
>> >> >>   FONTSET     "../fonts/fontset.list"
>> >> >>     SYMBOLSET    "../symbols/symbol.sym"
>> >> >>   PROJECTION
>> >> >>      'init=epsg:4326'
>> >> >>     'proj=longlat'
>> >> >>     'ellps=WGS84'
>> >> >>     'datum=WGS84'
>> >> >>     'no_defs'
>> >> >>   END
>> >> >>   IMAGECOLOR 255 255 255
>> >> >>   IMAGEQUALITY 95
>> >> >>   IMAGETYPE jpeg
>> >> >>   OUTPUTFORMAT
>> >> >>     NAME jpeg
>> >> >>     DRIVER 'GD/JPEG'
>> >> >>     MIMETYPE 'image/jpeg'
>> >> >>     IMAGEMODE RGBA
>> >> >>     EXTENSION 'jpeg'
>> >> >>   END
>> >> >>   LEGEND
>> >> >>     STATUS ON
>> >> >>     KEYSIZE 18 12
>> >> >>     LABEL
>> >> >>       TYPE BITMAP
>> >> >>       SIZE MEDIUM
>> >> >>       COLOR 0 0 89
>> >> >>     END
>> >> >>   END
>> >> >>   WEB
>> >> >>     IMAGEPATH '/tmp/'
>> >> >>     IMAGEURL '/tmp/'
>> >> >>     METADATA
>> >> >>       'ows_title'           'TESTMAP'
>> >> >>       'ows_onlineresource'  'http://www.*ourserver*
>> >> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>> >> >>       'ows_srs'             'EPSG:4326'
>> >> >>     END
>> >> >>     TEMPLATE 'foo'
>> >> >>   END
>> >> >>   LAYER
>> >> >>     NAME 'RECTANGLES'
>> >> >>     TYPE POLYGON
>> >> >>     DUMP true
>> >> >>     TEMPLATE fooOnlyForWMSGetFeatureInfo
>> 1261986.757801
>> >> >>     DATA
>> 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>> >> >>     METADATA
>> >> >>       'ows_title' 'rectangles'
>> >> >>     END
>> >> >>     STATUS OFF
>> >> >>     TRANSPARENCY 100
>> >> >>     PROJECTION
>> >> >>     'init=epsg:4326'
>> >> >>     'proj=longlat'
>> >> >>     'ellps=WGS84'
>> >> >>     'datum=WGS84'
>> >> >>     'no_defs'
>> >> >>     END
>> >> >>     CLASS
>> >> >>        NAME 'seamless_rectangle'
>> >> >>        STYLE
>> >> >>          WIDTH 1
>> >> >>          OUTLINECOLOR 0 0 0
>> >> >>          COLOR 149 170 154
>> >> >>        END
>> >> >>     END
>> >> >>   END
>> >> >> END
>> >> >> =============== END OF MAP FILE=================
>> >> >> The map book .xml is as follows, just a commented out version of
>> the
>> >> >> original one:
>> >> >> ============== MAPBOOK.XML ===================
>> >> >> <?xml version="1.0"?>
>> >> >> <mapbook version="2.0">
>> >> >>     <configuration>
>> >> >>             <param name="links_bar_html"><![CDATA[Perfect timing
>> for
>> >> >> some
>> >> >> damn CDATA "all" of 'its' here <&>]]></param>
>> >> >>             <param name="layer_controls.unfade.on">false</param>
>> >> >>         <!--    <param name="zoomto['Jump To:']"><![CDATA[
>> >> >>             'Dakota County' :
>> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
>> >> >>             'Parcel Data' :
>> >> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>> >> >>             'Full State of MN' :
>> >> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>> >> >>         ]]></param> -->
>> >> >>         <param
>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
>> >> >>         <param
>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
>> >> >>         <param name="layer_controls.legend.on">false</param>
>> >> >>         <param name="mapserver_url">/cgi-bin/mapserv.exe</param>
>> >> >>         <param
>> name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>> >> >>         <param name="projection">EPSG:4326</param>
>> >> >>         <param name="layer_controls.up.on">false</param>
>> >> >>         <param name="layer_controls.down.on">false</param>
>> >> >>         <param name="layer_controls.legend.on">true</param>
>> >> >>         <param name="drawing_tools.default_fill">red</param>
>> >> >>         <param name="drawing_tools.default_stroke">yellow</param>
>> >> >>         <param name="drawing_tools.default_opacity">1</param>
>> >> >>         <param name="group_checkboxes">false</param>
>> >> >>         <param name="default_tab">Catalog</param>
>> >> >>         <param name="catalog_name">Catalog</param>
>> >> >>         <param name="show_service_settings_in">Information</param>
>> >> >>         <param name="show_results_in">Information</param>
>> >> >>         <param name="tabs"><![CDATA[
>> >> >>              'Catalog' : 'catalog-tab',
>> >> >>              'Information' : 'information-tab',
>> >> >>              'Custom' : 'custom-tab'
>> >> >>          ]]></param>
>> >> >>         <param name="ground_units">km</param>
>> >> >>         <param
>> >> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>> >> >>         <param name="reference_map.enabled">false</param>
>> >> >>         <param name="coordinate_display.usng">false</param>
>> >> >>         <param name="jumpto_scales"><![CDATA[
>> >> >>             '1:50000' : 50000,
>> >> >>             '1:24000' : 24000,
>> >> >>             '1:10000' : 10000,
>> >> >>             '1:5000' : 5000
>> >> >>     ]]></param>
>> >> >>     </configuration>
>> >> >>         The mapping services define the source of the mapping
>> data.
>> >> >>     <map-source name="highlight" type="mapserver">
>> >> >>         <file/>
>> >> >>         <layer name="all"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="TESTMAP" type="mapserver">
>> >> >>         <file>./ArcView/testshp.map</file>
>> >> >>         <layer name="rectangles"/>
>> >> >>     </map-source>
>> >> >>     <!--    <map-source name="borders" type="mapserver"
>> >> >> reference="true">
>> >> >>         <file>./demo/statedata/basemap.map</file>
>> >> >>         <layer name="all"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="iastate" type="wms" tiled="false"
>> >> >> projection="EPSG:900913" width="512" height="512">
>> >> >>         <url>
>> >> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>> >> >> </url>
>> >> >>         <layer name="nexrad-n0r"/>
>> >> >>         <param name="format" value="image/jpeg"/>
>> >> >>         <param name="TRANSPARENT" value="TRUE"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="metbase" type="ags" >
>> >> >>         <url>
>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
>> >> >> </url>
>> >> >>         <layer name="Met Council Base Map Layers" />
>> >> >>         <param name="FORMAT" value="JPG"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="lmic" type="wms" tiled="false">
>> >> >>         <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>> >> >>         <layer name="fsa2008"/>
>> >> >>         <layer name="bw1997"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="usgs_doq" type="wms" tiled="false"
>> >> >> projection='EPSG:26915'>
>> >> >>         <url>http://terraservice.net/ogcmap.ashx?</url>
>> >> >>         <layer name="DOQ"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="usgs_drg" type="wms" tiled="false"
>> >> >>         <layer name="DRG"/>
>> >> >>     </map-source>
>> >> >>     <map-source name="reference" type="wms" tiled="false"
>> >> >> reference="true">
>> >> >>         <layer name="fsa2008" reference="true" />
>> >> >>     </map-source> -->
>> >> >>     <service name="print" title="Print Map">
>> >> >>         <step type="input">
>> >> >>             <url>php/print.php</url>
>> >> >>             <input type="print_info" name="layers"/>
>> >> >>             <input type="extent" name="extent"/>
>> >> >>             <input type="sketches" name="sketches"/>
>> >> >>             <input type="user" name="title" title="Map
>> >> >> Title">Map</input>
>> >> >>             <input type="hidden" name="date" title="Map
>> >> >> Date">true</input>
>> >> >>             <input type="select" name="template" title="Output
>> >> Template:
>> >> >>                 <option value="letter_landscape">Letter -
>> >> >> Landscape</option>
>> >> >>                 <option value="letter_portrait">Letter -
>> >> >> Portrait</option>
>> >> >>                 <option value="poster_landscape">11" x 17" -
>> >> >> Landscape</option>
>> >> >>                 <option value="poster_portrait">11" x 17" -
>> >> >> Portrait</option>
>> >> >>             </input>
>> >> >>             <input type="select" name="quality" title="Image
>> Quality:
>> >> >>                 <option value="2">Higher</option>
>> >> >>                 <option value="3">Highest</option>
>> >> >>                 <option value="1">Standard</option>
>> >> >>             </input>
>> >> >>             <input type="select" name="scale" title="Preserve
>> Scale:
>> >> >>                 <option value="preserve">Yes</option>
>> >> >>                 <option value="no">No</option>
>> >> >>             </input>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="identify" title="Identify" display="false">
>> >> >>         <url>php/identify.php</url>
>> >> >>         <step type="spatial" name="shape" line="false"
>> >> polygon="false"
>> >> >> jump-start="true" default="point">
>> >> >>             <input type="visiblelayers" name="layers"/>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="birdseye" display="false" target="_blank">
>> >> >>         <url>php/birdseye.php</url>
>> >> >>         <step type="spatial" name="xy" line="false"
>> polygon="false"
>> >> >> jump-start="true" default="point" format="delim"
>> >> reproject="EPSG:4326">
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="streetview" display="false" target="_blank">
>> >> >>         <url>php/streetview.php</url>
>> polygon="false"
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="feature_report" display="false">
>> >> >>         <url>php/feature_report.php</url>
>> >> >>         <input type="hidden" name="layers" value="lmic/fsa"/>
>> >> >>         <input type="hidden" name="src"/>
>> >> >>         <input type="hidden" name="PIN"/>
>> >> >>     </service>
>> >> >>     <service name="select" title="Select">
>> >> >>         <url>php/select.php</url>
>> >> >>         <!-- Send a selection shape + the visible layers list to
>> the
>> >> >> service
>> >> >>         <step type="spatial" showTools="true" name="shape"
>> >> line="true"
>> >> >> polygon="true" point="true" default="polygon" edit-polygon="false"
>> >> >> pan="false" jump-start="true">
>> >> >>             <header><![CDATA[Create a selection area by clicking
>> on
>> >> the
>> >> >> map.]]></header>
>> >> >>                 Option values should be the mapbook path to the
>> >> layer.
>> >> >>                 This only supports 'mapserver'-type layers.
>> >> >>             <input type="select" name="select_layer"
>> title="Select:">
>> >> >>                 <option value="parcels/parcels">Parcels</option>
>> >> >>             </input>
>> >> >>             <input type="user" name="shape_buffer" title="Buffer
>> >> >> Selection
>> >> >> Shape (ft)">0</input>
>> >> >>             <input type="select" name="query_layer" title="Using
>> >> >> Features
>> >> >> In">
>> >> >>             </input>
>> >> >> Selection
>> >> >>             <footnote><![CDATA[
>> >> >>             ]]></footnote>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <!-- this is called after a standard select in order to buffer
>> >> the
>> >> >> previous selection -->
>> >> >>     <service name="buffered_select_followup" title="Buffered
>> Select">
>> >> >>         <step type="input">
>> >> >>             <input type="hidden" name="shape"/>
>> >> >>             <input type="hidden" name="select_layer"/>
>> >> >>             <input type="hidden" name="query_layer"/>
>> >> >>             <input type="hidden" name="shape_buffer"/>
>> >> >>             <input type="user" name="selection_buffer"
>> title="Buffer
>> >> >> Features By: "/>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="buffered_select" title="Buffered Select">
>> the
>> >> >> service
>> >> line="true"
>> >> >> pan="false">
>> on
>> >> the
>> >> >> map.]]></header>
>> >> layer.
>> >> >>             <input type="select" name="select_layer" title="Select
>> >> >> features
>> >> >> from:">
>> >> >>             </input>
>> title="Buffer
>> >> >> Selected Features (ft)">0</input>
>> >> >> <!--            <input type="user" name="shape_buffer"
>> title="Buffer
>> >> >> Selection Shape (ft)">0</input>
>> >> >> Features
>> >> >> In">
>> >> >>             </input>
>> >> >>             <footnote><![CDATA[
>> >> >>             ]]></footnote>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="popups" display="false">
>> >> >>         <url>php/popups.php</url>
>> >> polygon="false"
>> >> >>             <header><![CDATA[
>> >> >>             Click on the map to show a popup about the features.
>> >> >>             ]]></header>
>> >> >>             <input type="hidden" name="layer"/>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="geocode_address" title="Geocode Address">
>> >> >>         <url>php/geocode.php</url>
>> >> >>         <step type="input">
>> >> >>             <input type="user" name="address" title="Enter
>> Address:
>> >> >>             <input type="hidden" name="googlekey"
>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>     <service name="search_parcels">
>> >> >>         <url>php/query.php</url>
>> >> >>         <step type="input">
>> >> >>             <input type="hidden" name="highlight" value="true"/>
>> >> >>             <input type="hidden" name="mode" value="search"/>
>> >> >>             <input type="hidden" name="layer0"
>> >> value="parcels/parcels"/>
>> >> >>             <input type="hidden" name="template0"
>> value="itemquery"/>
>> >> >>             <input type="select" name="fieldname0" title="Search
>> >> By:">
>> >> >>                 <option value="OWNER_NAME">Owner</option>
>> >> >>                 <option value="PIN">Parcel ID</option>
>> >> >>             </input>
>> >> >>             <input type="select" name="comparitor0" title="That:
>> >> >>                 <option value="like-icase">Contains</option>
>> >> >>                 <option value="right-like-icase">Begins
>> With</option>
>> >> >>                 <option value="eq-str">Matches Exactly</option>
>> >> >>             </input>
>> >> >>             <input type="user" name="value0" title=""/>
>> >> >>             <input type="hidden" name="fieldname1"
>> >> value="FIN_SQ_FT"/>
>> >> >>             <input type="select" name="operator1">
>> >> >>                 <option value="or">OR</option>
>> >> >>                 <option value="and">AND</option>
>> >> >>             </input>
>> >> >>             <input type="select" name="comparitor1" title="Having
>> >> Fin.
>> >> >> Sq.
>> >> >> Ft. ">
>> >> >>                 <option value="gt">Greater Than</option>
>> >> >>                 <option value="eq">Equal To</option>
>> >> >>                 <option value="lt">Less Than</option>
>> >> >>             </input>
>> >> >>             <input type="user" name="value1" title=""/>
>> >> >>         </step>
>> >> >>     </service>
>> >> >>         The catalog defines how the layers will be displayed in
>> the
>> >> >> catalog
>> >> >> tab.
>> >> >>     <layer-controls>
>> >> >>         <layer-control name="popups" service-name="popups"
>> >> >> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
>> >> >>     </layer-controls>
>> >> >>     <catalog>
>> >> >>     <!--     <layer title="overallmap" src="parcels/parcels"
>> >> status="on"
>> >> >> popups="true" minscale="0" maxscale="150000" metadata="true" >
>> >> >>             <metadata>http://www.aqua3.com</metadata>
>> >> >>         </layer>
>> >> >>         <layer title="City and County Boundaries"
>> src="borders/all"
>> >> >> status="on"/>
>> >> >>         <layer title="Weather Radar" src="iastate/nexrad-n0r"
>> >> >> status="off"
>> >> >> legend="false"/>
>> >> >>         <group title="Backgrounds" expand="true" multiple="false">
>> >> >>             <layer title="Metro Base Map" src="metbase/Met Council
>> >> Base
>> >> >> Map
>> >> >> Layers" status="on" legend="false" />
>> >> >>             <layer title="2008 Aerial Photographs"
>> src="lmic/fsa2008"
>> >> >> status="off" legend="false" />
>> >> >>             <layer title="1997 Aerial Photographs"
>> src="lmic/bw1997"
>> >> >>             <layer title="USGS DOQs" src="usgs_doq/DOQ"
>> status="off"
>> >> >> fade="true" unfade="true" legend="false" />
>> >> >>             <layer title="USGS Topo Quads" src="usgs_drg/DRG"
>> >> >> status="off"
>> >> >>             <layer title="None" src=" " status="off"
>> legend="false"
>> >> >> fade="false" unfade="false" />
>> >> >>         </group> -->
>> >> >>     </catalog>
>> >> >>         The toolbar defines which services are referneces in the
>> >> toolbar
>> >> >>     <toolbar>
>> >> >>         <tool name="previous" title="Previous Extent"
>> type="internal"
>> >> >> action="previous" selectable="false"/>
>> >> >>         <tool name="next" title="Next Extent" type="internal"
>> >> >> action="next"
>> >> >>         <tool name="fullextent" title="Zoom to Full Extent"
>> >> >> type="internal"
>> >> >> action="fullextent" selectable="false"/>
>> >> >>         <tool name="pan" title="Pan" type="internal"
>> action="pan"/>
>> >> >>         <tool name="zoomin" title="Zoom In" type="internal"
>> >> >> action="zoomin"
>> >> >> selected="true"/>
>> >> >>         <tool name="zoomout" title="Zoom Out" type="internal"
>> >> >> action="zoomout"/>
>> >> >>         <!--    <tool name="identify" title="Identify"
>> type="service"
>> >> >> service="identify" cursor="url('cursors/identify2.cur') 9
>> >> >> 9,url('cursors/identify2.cur'),auto" /> -->
>> >> >> <!--        <tool name="select" title="Select" type="service"
>> >> >> service="select"/> -->
>> >> >>         <!--    <tool name="buffered_select" title="Buffered
>> Select"
>> >> >> type="service" service="buffered_select"/> -->
>> >> >>         <!--    <tool name="clear" title="Clear Selection"
>> >> >> type="javascript"
>> >> >> selectable="false">
>> >> >>             GeoMOOSE.changeLayerVisibility('highlight/all',
>> false);
>> >> >>         </tool> -->
>> >> >>         <tool name="measure" title="Measure" type="internal"
>> >> >> action="measure"/>
>> >> >>         <tool name="measurearea" title="Measure Area"
>> type="internal"
>> >> >> action="measurearea"/>
>> >> >>         <!-- <tool name="search_parcels" title="Search Parcels"
>> >> >> type="service" service="search_parcels" selectable="false"/> -->
>> >> >>         <!-- <tool name="print" title="Print" type="service"
>> >> >> service="print"
>> >> >>         <!-- <tool name="birdseye" title="Bird's Eye View"
>> >> >> type="service"
>> >> >> selectable="true" service="birdseye"/> -->
>> >> >>         <!-- <tool name="streetview" title="Google Street View"
>> >> >> type="service" service="streetview" selectable="true"/> -->
>> >> >>         <!-- <tool name="geocode" title="Geocode Address"
>> >> type="service"
>> >> >> service="geocode_address" selectable="true"/>  -->
>> >> >>         <!-- <drawer>
>> >> >>             <tool name="markup_tools" title="Sketch Tools"
>> >> >> type="internal"
>> >> >> action="none" selectable="false"/>
>> >> >>             <tool name="draw_polygon" title="Draw Polygon"
>> >> >> type="internal"
>> >> >> action="draw_polygon"/>
>> >> >>             <tool name="draw_line" title="Draw Line"
>> type="internal"
>> >> >> action="draw_line"/>
>> >> >>             <tool name="draw_point" title="Draw Point"
>> >> type="internal"
>> >> >> action="draw_point"/>
>> >> >>             <tool name="draw_remove" title="Remove Drawing"
>> >> >> type="internal"
>> >> >> action="draw_remove"/>
>> >> >>             <tool name="draw_edit" title="Edit Drawing"
>> >> type="internal"
>> >> >> action="draw_edit_shapes"/>
>> >> >>             <tool name="draw_edit_attributes" title="Edit
>> Attributes"
>> >> >> type="internal" action="draw_edit_attributes"/>
>> >> >>             <tool name="clear_drawings" title="Clear Drawings"
>> >> >> type="internal" action="clear_drawings" selectable="false"/>
>> >> >>         </drawer> -->
>> >> >>     </toolbar>
>> >> >> </mapbook>
>> >> >> ============= END OF MAPBOOK.XML =============
>> >> >> I have tried getting some error reporting out of firebug with
>> little
>> >> >> success, if anyone can help me spot what I have done wrong it
>> would
>> >> be
>> >> >> much
>> >> >> appreciated and I would be happy to supply the real url's to the
>> >> server
>> >> >> off-list.
>> >> >> Cheers
>> >> >> Carl
>> >> >> Protect Your Site and Customers from Malware Attacks
>> >> >> Learn about various malware tactics and how to avoid them.
>> Understand
>> >> >> malware threats, the impact they can have on your business, and
>> how
>> >> you
>> >> >> can protect your company and customers by using code signing.
>> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
>> >> >> Geomoose-users mailing list
>> >> >> Geomoose-users at lists.sourceforge.net
>> >> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> >> > Best Regards
>> >> > Brent Fraser
>> Understand
>> >> > malware threats, the impact they can have on your business, and how
>> >> you
>> >> Best Regards
>> >> Brent Fraser
>> > Learn about various malware tactics and how to avoid them. Understand
>> you
>> Best Regards
>> Brent Fraser
> malware threats, the impact they can have on your business, and how you
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
